Question about M&S Systems M & S SYSTEMS DMC1CDB Whole House CD Player for DMC1 CD Player
My radio on the mc602 stopped working. The entire system still works except for the radio. any ideas?
  • 54 Answers
Sounds like a internal fuse look in your manual and see if it may have a heatsink switch that disables the radio if the heat levels get too high.
Posted on May 27, 2010
Buzzing or static noise on AM radio; is there a fix?
AM radio signals are very susceptible to what is called spurious radiation that is to say for instance high power electrical lines, noise from the car's electrical system like the alternator and the ignition system. I would have to hear the noise to know which you have. You also may just have a defective radio. Check one thing make sure the antenna is well grounded to the chassis of the car where it is mounted.
Jun 10, 2016 | Cars & Trucks
Have M&S systems Model MC602 Can't seem to reset after power outage.
I called the company and this is what they said:
Based on the problem description, there is nothing you can check to try and get the radio to work again. The most likely cause is a Tuner Module failure due to electrical surge. You will need to send the MC602 to us for service. We will need you full address, phone number, and the serial number or date code from the back of the MC602. The serial number/date code will be on a white sticker and may have a barcode on the sticker as well. When receive you information, we will issue you a Return of Product Authorization (RPA) number and instructions for returning the unit. There will be a repair charge and that can be provided with the RPA number.
Sincerely,
James Williams
Senior Applications Engineer
Linear LLC
Technical Services
(800) 421-1587
Sep 23, 2010 | M&S Systems Audio Players & Recorders
MC602 intercom system locked up
I don't have a solution, however, I do have the same problem. When it happened originally, I smelled electrical wires burning. someone checked it and said that a wire had shorted. The electrician checked it out but could not find out what was wrong with it. The radio comes on, but we cannot use any of the buttons.
Sep 03, 2009 | M&S Systems M & S SYSTEMS DMC1CDB Whole...
M & S MC602 intercom system locked up
Mine does the exact same thing, except mine isn't set up to change stations from rooms..did you ever find a fix?
Aug 09, 2009 | M&S Systems M & S SYSTEMS DMC1CDB Whole...
Gas tank won't open, trunk won't open, radio stopped working, left tail lamp won't work
It's the body control module. It's located under the dash to the left of the steering column. I had same problem, went to the junk yard and bought one and the problem went away. Dealer wants $600.00-700.00 for the BCM, I paid $30.00
May 30, 2009 | 2001 Cadillac Catera
1988 Corvette Bose Radio Front Speakers only work periodically
try different speaker if works .its the speaker. if another speaker does the same .your radio is the problem.
May 01, 2009 | 1988 Chevrolet Corvette
AM radio tuner set as MW tuner. How to switch to U.S.A. AM mode?
AM is just another name for MW. The Radio should tune to a strong signal regardless of the frequency the radio is set to. It should also sweep the entire frequency looking for stations. I'm assuming it has a channel scan setting, plus options to set a number for the station. AM/MW are very much dependent on the position of the either internal or external Ariel. If you have the radio in the wrong position or you have some electrical equipment nearby it could block the signal for the station you want, but not affect the others. Which might explain why it can't find the station you want.
May 05, 2017 | Philips DCM230/37 iPod Docking Executive...
M&S Systems MC602 Master Unit and M&S MCD6 6-disc CD Player
mc 602 system---volume stuck on 32 and not playing main speaker
Mar 05, 2008 | Audio Players & Recorders
720 people viewed this question
Top M&S Systems Audio Players & Recorders Experts
Colin Stickland
Colin Stickland
woodzowl307
Are you a M&S Systems Audio Player and Recorder Expert? Answer questions, earn points and help others
