Question about Cameras
My camera software wont work, nothing comes up on the screen, i have tried to add the camera with the ad a device tool in the scanner and camera folder, but the soft ware will not come up when i put the disc in. My pc had a virus and after that the camera wouldnt work so i am trying to reinstall the camera now, i have downloaded the driver of the samsung website
  • 1 more comment
  • pscemum Apr 07, 2008
    oops sorry ! my camera is a samsung digimax D53 serial number 966003455
    Hi how do i uninstall the driver?
    Aww thankyou so much, i uninstalled the driver and then reinstalled it then did something else but i'm not sure what, but i clicked on the dnew driver and it started to install so thinkyou ever so much for that!
    Genius:
  • 3,422 Answers
Can you please give the make and the model no. of the camera so that i can help you fix your problem.
Waiting for your reply..
Posted on Apr 07, 2008
  • 2 more comments
  • Priya darshan Apr 07, 2008
    Alright here is what you have to do.
    First uninstall the previous driver and then reinstall it.If you still face the same problem then run a virus scan again with the camera connected to your PC..
    Goodluck,
    Please don't forget to rate the solution.
    It is really simple. Go to control panel>ADD OR REMOVE PROGRAM.
    Now just select the name of the driver software and click on remove that's it your done..
    Please don't forget to rate the solution as fixya if this helped..
    Master:
  • 377 Answers
Uninstall first all the previous driver that you have installed, then affter that install you new downloaded software for your cam.
Thanks
    Master:
  • 555 Answers
What is the maker and model of your camera?
Acer 640 p xp driver not found
Hi dsdss
For this driver to work in XP you must install the MiraScan software then install the scanner manually.
Step 1. Download MiraScan v3.424 from the web :
Mirascan_v3424p.exe
Step 2. Unzip and install the Mira Scan driver that you just downloaded. After installation , system will suggest you to add a scanner
Step 3. Then, add an imaging device
Step 4. Then the Scanner and Camera Installation Wizard comes up. Click Next at the bottom.
Step 5. Then on Scanner and Camera Installation Wizard screen it will ask you which scanner or camera do you want to install? You want to go where it says Manufacturer and then click on EPPSCANNER and where it says Model it should say color flatbedscanner. Make sure it is highlighted, also. Click on Next at the bottom.
Best regards ,
fanaudi .
May 25, 2011 | Acer ScanPrisa 640P Flatbed Scanner
""I can't get my scanner
If reinstalling the drivers doesn't work. Try manually adding the device.
1. Start>Control Panel
2. Under Hardware and Sound click, Add a device
3. From there you should see your Printer/scanner. Go thru the prompts and it should be able to find and install the drivers from manufacturer site
Mar 29, 2017 | Office Equipment & Supplies
Cant scan
Try to scan with Preview or Image Capture apps (in your Applications folder).
If that does not work, try deleting and re-adding the printer in the print queue:
- Sys Prefs, Print & Fax
- Select the printer in question and click the minus sign at the bottom of the list
- Select the plus sign to re-add it. Look for the printer, select it and wait until the "Add" button becomes available. Click it.
If this does not work, do the same thing, only instead of the second step, right (control) click the print queue area and select Reset Printing System
Jul 12, 2010 | HP Computers & Internet
Need to find a free download to install
Instructions for installing Acer brand parallel port scanners in Windows XP:
Step 1. Download MiraScan v3.424 from the web : Mirascan_v3424p.exe
Note: For additional screen shots of this procedure and installation procedures, please read the pdf file posted here: scpinwxp-eng.pdf
The Screenshots show to be for Mirascan v3.423 but procedure is same for v3.424
Note: Adobe Acrobat Reader is required to view or print this file.
SOURCE : http://forums.driverguide.com/showthread.php?t=35623
Originally written by Jerry K 12-03-2007
Oct 13, 2009 | AcerScan Prisa 340P Flatbed Scanner
Trouble uploading photos from my camera.
You may not have the software installed on your computer or it's not installed properly.
First tru plugging in your camera using the USB and turning the camera on (press the arrow buttun for about a second). The FinePixViiewer should open.
Apr 30, 2009 | Fuji Finepix Z20fd Digital Camera
By mistake this morning, I was going to download some pics off a digital camera and plugged it into the USB port. I don't know what I was thinking, but I went to the control panel and selected scanners &...
you need to uninstall that device. go to the start button, click on run and type: compmgmt.msc, press enter. goto device manager on the left side. Scroll down the list on the right side. Find the device you installed and double click it. Choose uninstall option. I hope this helps..
Mar 26, 2009 | Computers & Internet
Trying to erase a light with a scanner
There is no real place where scanners come up except when they are plugged in. Once plugged in they should come up in device manager which you can access by right clicking My Computer select Manage Computer and you will see the Device Manager. Once selected you will see all the hardware devices connected to your computer. Under Scanners should be the scanner wich you can then right click and choose uninstall.
To connect a scanner simply plug it in and use the CD it came with to install the driver and software which should pick up the device and add it. The scanner software itself is what picks up the scanners and alows you to use there functionality.
What is it your trying to do re-install, add, remove a scanner. Is it the software thats playing up or the scanner itself?
Mar 23, 2009 | Syscan DocketPORT 465 Scanner
I need a driver soft ware to work with windows xpsp2 for acerscan prisa 310p email: elfondkya_ihabmoh@yahoo.com
Instructions for installing Acer brand parallel port scanners in Windowsmag-glass_10x10.gif XP:
Mirascan_v3424p.exe
Step 5. Then on Scanner and Camera Installation Wizard screen it will ask you which scanner or camera do you want to install? You want to go where it says "Manufacturer" and then click on EPPSCANNER and where it says "Model" it should say color flatbedscanner. Make sure it is highlighted, also. Click on Next at the bottom.
scpinwxp-eng.pdf
Note: not all XP systems will work with parallel port scanners. If the procedure doesn't work for you, then you must obtain a newer USB type scanner.
Mar 22, 2009 | AcerScan Prisa 620U Flatbed Scanner
Driver for Acer Vuego 610P
Mirascan_v3424p.exe
Note: For additional of this procedure and installation procedures, please read the pdf file posted here:
scpinwxp-eng.pdf
from Vuego Scan
Nov 26, 2008 | AcerScan 610P Flatbed Scanner
Downloading to computer
Go out to hp.com and click on support then updates and find your camera and download the latest updated software. I have several hp devices including one camera, and have had to download updates for all of them, The discs which come with equipment are made up before the release of the equipment, needless to say by the time you get it, the disc has long been updated.
Aug 11, 2008 | HP Photosmart M415 Digital Camera
Cameras Logo
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
