Question about Mitsubishi WD-62525 62" Rear Projection HDTV
Tv will not turn on, green timer light just blinks
Screen flashed green a couple days ago and now won't turn on but the timer button flashes green.
Posted on Aug 21, 2011
  • 94 Answers
Defective DM assembly
Posted on May 28, 2010
  • 179 Answers
SOURCE: Timer light blinking green/tv won't turn on
the wd 62327 doesn't have a DM module as it doesn't have the atsc tuner. are you sure you have a wd62327?
in a normal set
power:
Green Blink = μPC Initializing (after AC off/on) (1~2 sec)
get the error code by doing this: (and let me know)
Error Code Operational Check
Pressing the front panel “INPUT” and “MENU” buttons at the same time, and holding for 5 seconds,
activates the Error Code Mode. The ” Power LED” flashes denoting a two digit Error Code, or indicating no problem
has occured since the last Initalization.
Note: The front panel buttons must used, NOT those on the Remote Control.
• The number of flashes indicates the value of the MSD (tens digit) of the Error Code.
• The flashing then pauses for approximately 1/2 second.
• The LED then flashes indicating the value of the LSD (ones digit) of the Error Code.
• The Error Code is repeated a total of 5 times.
Example: If the Error Code is “34”, the LED will flash 3 times, pause, and then flash 4 times.
Posted on Nov 17, 2008
  • 668 Answers
SOURCE: Mitsubishi DLP, green blinking timer light, tv won't come on,
This Chassis has been known for a slew of Capacitors failing throughout many of the Circuit Boards. The best way in my opinion to fix the set is to send the Chassis Assy to Mitsubishi for them to rebuild it. Some folks have has some success in replacing the bad Capacitors in the Power Supply, the DM Board, and the Format Board to get the set to turn on. These Capacitors are identifiable because the tops of them are bulging up.
It is a difficult set to work on and disassemble, this is Mitsubishi's Customer Service Number in case you need assistance. 1800-332-2119
I hope this helps,
Sky Assoc
Posted on Feb 08, 2010
SOURCE: Green LIght Blinking
replace the DM or have someone repair the DM. The capacitors are bad and someone who knows how to repair circuit boards can replace them
Posted on Nov 06, 2007
SOURCE: Mitsubishi dlp tv green timer light blinking
timer light keeps blinking tv does not turn on
Posted on Nov 29, 2008
SD Tech
  • 14553 Answers
SOURCE: what repair is needed for blinking green light and
These sets had a lot of problems like yours---for a while lots of them had 3 different boards with caps going bad etc---a real nightmare---fix one board and a few months later another goes out.
I was at a local Mitsubishi authorized repair center recently---Because of all the problems there is now available an ENTIRE CHASSIS exchange for most of these sets---it wholesales for about 200---a third of what it will cost you to have a shop fix all three of the suspect boards.
This is from what I was told a response by Mitsubishi from the THOUSANDS OF ANGRY PEOPLE WHO PAID A LOT OF MONEY--and 3 or 4 years later the sets are dropping like flies.
If this information has helped you, rate this solution as I do this here for FREE.
SD TECH
Posted on Nov 15, 2009
Toshiba 50HP95 timer/Rex light blinking green. Tv wont turn back on.
place to begin if you are able is examine the power board for puffed up caps and or voltages coming into the board and out of it.
Aug 27, 2012 | Toshiba 50HP95 50 in. Plasma Television
Does the led ever stop blinking? No ..well in that case generally this indicates a standby voltage problem...if all those voltages ok then the cuircit known as digital module is at fault. also make sure the lockout has not been activiated. i really dont think it could but to unlock hold menu button down for 10 seconds. After all that i believe it would be a bad digital module
Willie@fordtv.com
Jan 08, 2008 | Mitsubishi WS-55813 55" Rear Projection...
Replaced lamp but lamp light still blinks orange
I have a wd-57731 The lamp light blinked orange. i replaced the lamp turned the tv on and the timer blinks green for one minute and then the lamp light blinks orange again. It won't turn on. Can you suggest anything?
Nov 22, 2011 | Mitsubishi WD-57731 57" Projection HDTV
Green blinking timer light, TV won't turn on
Common to mitsubishi dlp tv's,you have a bad signal ***'y (power supply,formater board) lots of bad electrolytic capacitors,
Mar 22, 2010 | Mitsubishi WD-62525 62" Rear Projection...
Flashing green light
Did you try this yet
SYSTEM RESET
If the TV will not respond to either the remote control
or the front panel controls and/or will not power Off,
press the SYSTEM RESET button with a pointed item
like the end point of a paperclip. The TV will turn Off
and the TIMER light will flash quickly for about one
minute. When the TIMER light stops flashing, you may
turn on the TV again. Changes you made the last time
the TV was On before you used the SYSTEM RESET
button may be lost, however, the changes you made
previously are not lost.
POWER/TIMER Indicator
The green light is a multi-function indicator. This light
will flash rapidly for about one minute each time the TV
is plugged into the wall electrical outlet, when power
is restored after a power failure, or using the SYSTEM
RESET button. Do not attempt to turn on the TV again
during this period. Wait for the flashing to stop and
the light to turn off, before attempting to turn the TV
on. While the TV is powered on, the light illuminates
steadily. If the TV has been programmed to turn on
automatically using the Timer feature,
Sep 21, 2009 | Mitsubishi WS-65515 65" TV
Lamp problem
The DM is failing to complete the boot sequence thats why the power led is continuously blinking green. The V26 DLP DM repair kit will usually repair that issue you can get the kit at the following link which includes the replacement capacitors and step by step instructions with pictures on how to do the repair.Its listed under the repair kits category.
http://servicemanuals.vstore.ca/
Mar 26, 2009 | Mitsubishi WD-62526 Projection TV
Blinking green light under 'Timer' flashes there is no picture
If you have a green blinking LED that runs continuosly, its the widespread problem of failures of capacitors on several circuit boards in the TV. Currently Mits is having authorized service centers remove the chassis and send it them for rebuilding. Its an expensive and time consuming repair.
Feb 17, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Turn on the TV and only Timer light is on , no sound & picture
after holding down the menu and device the led will blink a two digit error code such as 3 blinks pause then 4 blinks then repeat that sequence a couple of times. Need that blink code to help let you know whats going on. The 34 code means lamp abnormality which translates to the power Pwb capacitors have most likely failed.
Jan 23, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Green Blinking Timer Light Mitsubishi WD-62527
hold the menu bottun for 10 seconds
after press power
see if that works
Sep 22, 2007 | Mitsubishi WD62527 62 in. LCD HDTV
Mitsubishi WD-62525 62" Rear Projection HDTV Logo
738 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
