Question about Toshiba Satellite 1805-S204 Notebook
Hi, we have a toshiba S1800-254 computer and need to make it wireless, so we were wondering what card to use what to do with it and where we can we buy one ?
  • Toshiba Master
  • 2,404 Answers
Seeing as how its an older laptop, your best option would be to get a wireless USB G network adapter, it plugs into a USB port on your laptop, then get a wireless G router to match up with your wireless G Network USB adapter. Stick with Belkin if you can since they have been reliable from my own experience. Get a Belkin Wireless G Router and a Belkin wireless G USB Network Adapter. At that point you'll have wireless access and it will run you under $100 dollars.
Posted on May 27, 2010
Testimonial: "many thanks I will try and get it sorted xxxxx"
Hi, I have a Motion Computing LE1600 and I was wondering which internal wireless n card will fit in the computer.
im not sure i know that machine,if its a tour then a wi-fi card would be possible ,if its a laptop or netbook youll need an external dongle type modem/or push-in card
Sep 25, 2010 | Motion Computing MOTION LE1600 Notebook
How do I get this prehistoric Toshiba Satellite 1400-S151 to work with wireless? Do I need a wireless card or something completely different? When it click on the wireless icon on the lower right hand...
1st.: check to see if there is a wireless button on the outside of the computer. Some have this option to turn it on/off and it's easily overlooked by many.
2nd.: Right click "my compuer" and go to manage. Go to "device manager" and find your card under the "network adapter" tab. If it is disabled, double click it to enable it. If it has a yellow flag on it, you will need to download and update the driver.
Mar 25, 2010 | Toshiba Satellite 1400-S151 Notebook
Which wireless card for Toshiba Satellite 1905-S301??
Lots of incompatibilities and covering pin 13 does NOT solve the problem with this series laptops. Get the MPC13A-20/R 802.11b card - it works wonderfully well, even though it's only a 'b' card.
Dec 08, 2009 | Toshiba Satellite 1905-S301 Notebook
I have a Toshiba lap top A 105. I have lost my internet
It is possible to disable the wireless connection with the keyboard. Try the combination of Fn and F8 buttons (this is a common Toshiba shortcut) to turn it back on. If that doesn't work, look at your Network Connections (through the Control Panel, assuming a Windows OS, if needed). Check the settings and if it is enabled. In the device manager, check if the wireless adapter has an exclamation point in a yellow triangle. If you have the exclamation point try letting Windows repair the driver. (You may need to access the Toshiba website for the correct driver. Either use a different machine and put the driver on a disc or USB driver or your machine's wired connection.) If that tells you it has no problems, remove the wireless connection (and uninstall the driver) and reboot the computer and it should see new hardware and start reinstalling the driver. Then you can try to establish a new wireless connection.
If the above solutions do not help, it's likely to be a hardware failure. You could get a new wireless adapter (USB or an appropriate card for your laptop add-on card slot), use the wired network (if that has worked), or consider a new machine.
Nov 15, 2009 | Toshiba Satellite A105 Notebook
Is there a wireless card in the toshiba satellite 1415-s173?
Go to Control Panel > System > Device Manager
Under Network Adapters you would be able to locate wireless card if its there in your system.
Sep 19, 2009 | Toshiba Satellite 15" Flat Panel LCD...
Toshiba Satellite M35X-S109 wireless problem... will not see wireless.. says turn on ... how do i turn on wireless it worked yesterday
You can press the Fn key + F2 to enable the wireless card.
The other way to do the same , would be through wireless switch located either on the left of right of the laptop.
You can also try restarting the computer, sometimes the driver for the wireless card can casue the conflict.
Thanks for using fixya
proton
Aug 15, 2009 | Toshiba Satellite M35X-S109 Notebook
Wireless lan networking for toshiba satellite 1900
Not enough info per problem description. Not all 1900 series laptops have wireless cards installed, and not all 1900 series laptops are ready to handle wireless cards, either. Need to know what model your computer is, what wireless card you're using, ... C'mon. Let's have it...
Mar 19, 2009 | Intel Toshiba Satellite Mini-PCI Laptop...
Does my laptop have wireless internet??
Basically they don't. They can be purchased and easily installed by opening the cover that contains it and inserting it just like inserting memory and then connecting the white and grey wires to the wireless card.
Jan 26, 2009 | Toshiba Satellite Pro A10 Notebook
Connect to house internet
you cannot get wireless with a (home phone) with dial-up
Jul 10, 2008 | Toshiba Satellite A135-S2276 Notebook
Toshiba Satellite M40 Internal Wireless Card replacement
On the bottom of the laptop there will most likely be 2 panels to remove. One will be the hard drive, the other will be your RAM modules and most likely your wireless card. It'll probably be in the middle. Open this up, your wireless card will have two wires plugged into it that you'll have to unplug. Then on each side there is a tab that you have to click outward, then the card will flip up. Then you can just pull it outward. Do the reverse for installing the new card.
Aug 28, 2007 | Toshiba Satellite M40-S417TD Notebook
Toshiba Satellite 1805-S204 Notebook Logo
271 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
