Question about Hitachi 60SX13B 60" Rear Projection Television
COLOR SHADOWS How do I use my "genus remote" to realign my color red,green & blue. I know how to put the plus sign on the screen but what to do from there.
  • 78 Answers
Select each color. all you have to do is align it with white by using the directional arrow keys - Simple! For fun, Grab a pair of red and blue 3d glasses and offset the red and the blue channels. Yes, I have too much time on my hands. Good luck :)
Posted on Apr 07, 2008
6ya staff
SOURCE:
Have a projection tv...RCA model 61830BL. Had
Hi the green cross it cant move that the reference for red and blue adjustement ;just try to put the red and blue cross over the green pattern then quit/
if that doesnt work you probly have the stk-xxx ic
who control the color alignment ,are blow/
you will have to replaced and make the convergence
check if you have an auto adjustement for that most projection tv have one...
hope that help..
Mar 28, 2010 | RCA P61830BL 61" Rear Projection...
53 inch projection tv...seems like the color red and color blue have shifted giving me a picture with red and blue shadows
For CRT projection TV's, this indicates that the Green picture tube is burned (warn out). The less green that strikes the screen, the more redish the image will look. You will need to find an old school TV repair shop that knows how to replace picture tubes.
In the case of a DLP style TV, the color wheel needs replacing.
Dec 29, 2009 | Hitachi Televison & Video
Shadow images and scrolling banner curves upward and back down.
Your TV most likely has one or more possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Mar 15, 2009 | Panasonic PT-53TW53 53" Rear Projection...
Red, green and blue color resolution
Hello my name is willie and i see this problem alot here at the shop. The symptons you describe is known as "convergence". OK your problem might have a simple soultion. if you can answer this question. When you acess the customer menu go into setup option.. then do you have convergence option. If you do not it will be known as the fl231 fuse. a fuse that common to blow due to bad connections. Now if you do have this option then you will have more problems with other boards. and it will have to be troubleshoot further. Does the picture also bown in at the top and bottom. when you go into convergence option(if you have it) does the cross hair move? let me know and i will see if i can help further
Sep 01, 2008 | RCA R52WH73 Projection Television
Tv problem
yes u need to go in to the menu where it says source and go to the convergence use the right arrow on your remote control it is a round ball u will come to a xross on the screen if the xross is nice and white in the center of the screen then u do nothing at that piont but if it is not hit your ratio button on the remote and your screen will change colors if it is green looking u can set the red lind if it is blue then u can set the blue line just read what it tells u on the screen to do.when u are done in the mode hit the round ball in the center and u can do all the x on the screen just find but please look at what it is telling u what to do on the screen i hope this will help it is very easy to set the convergance on the model set
Jul 09, 2008 | Zenith IQD61W35 61 in. Rear Projection...
Mitsubish hd 1080I wt 46809
Check settings first to make sure no one changed anything out of the ordinary. Are the shadows that of a color or darkened shadow? It could be out of convergence, which can be corrected in the menu - or it could be low quality video cables to. Also, if there is no green, does a white color show up when you're in a menu mode (Red+Blue+Green = White Image)? If so, then the green picture tube is working and it's just a color adjustment, otherwise you may have to invest in a new green picture tube.
Apr 22, 2008 | Televison & Video
Alighnment off
The alignment you need to do to realign your TV is called "setting the convergence". All projection TV's have 3 color guns (one red, one blue and one green). When you move a TV or josstle it, these guns can get misaligned and need realignment. This is definitely something an average user can do (you don't need a TV repair man to do it for you). It is a very simple procedure (most TV's have an option in the menu to do this, just look for convergence adjustment). What you want to do is use the remote to get all 3 colors to overlap completely (you can only move one color at a time). Some TV's have squares on the screen that you must align, others have plus signs. If you can't find it in the menu on your TV or if you can't figure it out on your own, you can look for a manual at Hitachi's website that will walk you throught the process for your TV.
Jan 25, 2008 | Hitachi 53SDX89B 53" Rear Projection...
Blue shadows
Sony Too green,red or blue
http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
Nov 25, 2007 | Sony KP-53HS10 TV
Blue and red shadows on screen
This sounds like one of the convergence IC's has cracked loose or burned out, and should be replaced and realigned by someone with experience.
Jun 26, 2007 | Hitachi 50UX57B 50" Rear Projection...
Blue Color spots on all pictures
Call a technician, sounds like an Integrated Circuit problem and would cost you about $250.
May 07, 2007 | Philips 60PP9202 60" Rear Projection...
Televison & Video Logo
155 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
