Question about Nakajima AE-830 Typewriter
When turn on typewriter there is an continuous beeping/screeching noise and will not operate.
    Genius:
  • 1,218 Answers
Remove print wheel to ensure its not jamming, switch machine back on and see if carriage returns to the LHS home position. If it does not and the carriage is just shaking and the noise is still there, you may have a defective carriage motor or defective power supply.
Posted on May 28, 2010
Why my royal Satellite II Typewriter has a beep?
Does it work or does it just beep. Could have the margins set together.
Jul 30, 2014 | Office Equipment & Supplies
Turn on and it has a continuous beep
Most typewriters have a "power on system test" or POST routine. Beeping means that it fails the test. With the power off, try moving the carriage all the way to the left and turn it on. Some typewriters, if the carriage is not right over the left sensor, will fail the POST. Most typewriters will check things like, "Is there a ribbon installed?" "Does the Daisy Wheel home?" and will move the carriage left to right to make sure that the sensors recognize the left and right limits. There are other checks of course, but those are the ones that are easily fixable.
Apr 14, 2014 | Swintec 2640 Electronic Typewriter
Beeping sound
Usually beeps indicate an error either in operation or that the typewriter cannot complete a request or operation due to a malfunction. If the beep is continuous, you probably have a malfunction and should have it serviced.
Oct 05, 2013 | Brother GX-6750 Typewriter
Humming noise after turning typewriter on
If that is all that happens, no lights, no beeping you probably need a power supply or a board. If there are lights and beeping we need to know what it's doing.
DickyO
May 05, 2011 | IBM Wheelwriter 6 Typewriter
Typewriter beeps continually and first and third lights from the bottom right blink when I turn machine on. Beeping stops after 30 seconds or so, but lights continue to blink and no keys work. I changed...
Be sure the printwheel id properly installed, remove P/W & check for dirt and debris in that area. If you have air in a can try blowin out that area.
DickyO
Jan 05, 2011 | IBM Wheelwriter 6 Typewriter
Swintec 8016 Typewriter making grinding noise all functions froze
Try some WD40 on the silver shafts that the carrier slides on they do get very gummy.
DickyO
Apr 26, 2010 | Swintec Office Equipment & Supplies
Making noise when turned on, carrier won't move
you might try unplugging machine for a couple minutes. if this doesn't work, it needs professional help
Oct 31, 2008 | Swintec 7040 Typewriter
Pitch Beeping
make sure the printwheel is locked in place, and the cover is closed. otherwise it is probably the main board or power supply. take to a repair shop for evaluation
Aug 14, 2008 | Brother EM-530 Typewriter
Beeping noise
Sounds like the rt. margin is set at that point. Tab to the far right then press the rt. mar. key it is on the L. side of the keyboard.
DickyO
Jun 27, 2008 | Lexmark Wheelwriter 1500 Typewriter
KB? Pitch?
maybe your printer stuck,try to move him manually and then start typewritter
May 07, 2008 | Brother EM-530 Typewriter
Nakajima AE-830 Typewriter Logo
161 people viewed this question
Top Nakajima Office Equipment & Supplies Experts
James Cagle
James Cagle
Jim Keysor
Are you a Nakajima Office Equipment and Supply Expert? Answer questions, earn points and help others
