Question about Car Audio & Video
New Kenwood Cd Player won't work
I own a 98 Chevy Cavalier 2 Door Coupe. I baught Pioneer speakers which i installed about a week ago. They work perfectly fine. I then baught a Kenwood CD player which i installed yesterday. I did every thing fine, connected all the wires to the right colors everything. (My brother has done it before so it was done right) We checked if it worked first before we inserted it into the metal thing that goes around it and clipped it in place. It turned on fine, but maxed out with the volume at 20 and turned off. When we turned the volume back down it turned back on. I covered all the wires with electrical tape. So i tried putting it in and when i was (can't remember if car was on or not) a spark happened, but it wasn't ANY of the wires. This is hard to explain, but just the metal that goes around the cd player and the metal piece that goes around that sparked, absolutely no wires. After that, i got it all into place and tried turning it on, and it wouldn't turn on and still won't. I checked everything and all the wires are still together and all the fuses (in car and in player) still were good. My brother thinks it's just that my battery (325) can't handle it. But, why did it turn on in the beginning if that was the case and whats the odds that after the spark happended it stopped working? I really need help because i love my music and was so depressed. Is it somehow broken from a spark malfunction or what. Please let me know what you think. I'm also gonna go back to best buy and ask what they think but i have to work today and tomorrow and cant get there =[. Thanks
  • 1,868 Answers
Hello! Even though you believe the wiring is not the problem...The wiring, more times than not, is the problem...When you first turned the unit on the volume maxed out at 20...I believe you have a wiring error in the ground portion of circuit...
Here is the wiring for your vehicle...
POWER
Illumination = Gray
Constant +12= Orange/Black....Memory lead
Switched +12= Yellow...Power-on via ignition
Ground= Black...Outside metal case of CD
Must read zero ohms to
chassis and negative batt.
terminal of vehicle when
connected...
Check your connections with a voltmeter...
SPEAKERS
FR+ = Dark Green
FR- = Light Green
FL+ = Tan
FL- = Gray
RR+ = Dark Blue
RR- = Light Blue
RL+ = Brown
RL- = Yellow
The spark means that +12 volts was tied to the case of the unit and when the case touched chassis ground it caused the spark...Lets make sure you have checked all the fuses..I'll give them to you in a minute...
With the unit set on the carpet... Place one lead of an ohm meter on the case of the unit and the other lead on the vehicle' chassis...You should read a dead short which proves that the case of the unit
(via wiring ) is connected to proper ground...I would bet that it is not...Here are the fuses...
Radio fuse= 10A...This powers the Yellow ignition lead...But it also has an in-line fuse that carries +12 volts to the steering wheel controls
(if equipped)...Last fuse is the Int lamp fuse 10A which powers the Orange/Black constant +12 lead...
Wire as given...provided that the unit is unharmed...
your tunes should return...Let me know how you make out.....
Guru...............Saailer
Posted on May 27, 2010
I dont get any sound radio,sirris,or cd
Is there something new that was installed or modified in your car recently, even if it's not related to electronics? (even trailer hitches, running board, etc)
Have you checked if there was a ground leak at each speakers?
Are you using an amplifier other than the one in your kenwood reciever?
May 29, 2013 | Kenwood KDC-MPV622 CD Player
2002 Chevy Cavalier won't start. The service light
this is a common problem with the passlock system im sure like everyone else you will have to get a new ignition cylinder/switch
Nov 19, 2011 | 2002 Chevrolet Cavalier Coupe
New Radio too powerful for 15 Watt speakers?
Hello mike_mccuske,
The OEM speakers will still work OK with your new Pioneer. Just don't turn it up too loud. Of course you'll get improved sound if you replace the speakers. Your Pioneer's RMS power is 14 watts, and the peak (maximum) power is 50 watts. The door speakers in a 2000 Honda Civic are 6.5" and you can get a set of Pioneer speakers, the TS-G1642R's, from Crutchfield for less than $50. Their RMS power range is 2-30 watts and they can handle a peak power of up to 180 watts.
Hope this helps.
May 22, 2009 | Pioneer DEH-2000MP MP3 CD AM/FM Car Stereo...
Pioneer deh-6400 tuner has no audiobut cd plays ok
Did you also use an antena adapter? If not you may need one. Original in the vehicle is small and can pop out from the radio.
May 18, 2009 | Pioneer DEH-P6400 CD Player
I need help wiring a pioneer to a 1992 cavalier cuz the wires dont mach up
the cavalier wiring-top row is orange 12 volts regardless of the key switch position,yellow 12 volts when the key is on/or accessory, pink is for power antenna or factory amp turn on, grey is for lights dimmer control, black ground,green right front speaker +,light green right front speaker -,grey left front speaker +,tan left front speaker-, bottom row is brown left rear speaker +,yellow left rear speaker-,blue right rear speaker+,light blue right rear speaker- be carefull because you have 2 yellow wires and 2 grey wires if you follow the rows like I explaned you will be fine-If you need the wiring for the pioneer radio E-Mail me at merle840@aol.com
Apr 04, 2008 | Pioneer DEH-1900MP CD Player
Installing a DEH-P31000 into a 97 Cavalier
grey (-) Driver front
tan (+)
dark green (-) Pass. Front
light green (+)
brown (-) Driver Rear
yellow (+)
dark blue (-) Pass. Rear
light blue (+)
yellow (+) Battery
Black (-) Ground
hope this helps.
Mar 24, 2008 | Pioneer DEH-P2900MP CD Receiver...
No Sound Through Speakers
Hi Jake,
If you haven't done so already, I'd try double checking the speaker wiring, you may have some exposed or badly kinked wires behind the unit.
Cheers,
Matt Coyote
Feb 20, 2008 | Car Audio & Video
Swapped out players and new one doesnt power up
Ok. recheck your harness. WIth some brands yes the harness will plug into the radio from a different manufacturer but recheck the wire colors. They usually change pins out. For example whats power on a particular pin may be a speaker wire on another brand unit with the same style plug... so get the harness that came with this radio. Check the pin location and wire color on that pin to the other harness. I almost guarantee that there is a difference. Hopefully you didnt damage your new cd player... let me know how it goes...
Sep 03, 2007 | Kenwood Sirius KDC-MP522 CD Player
Installing a Pioneer DEH-P77DH
You can download the manual from the link below: http://files-upload.com/files/461301/DEH-P77DH_install.pdf Please update the question & let us know if the information given was useful to you - Good Luck!
Aug 26, 2007 | Pioneer DEH-P77DH CD Player
Car Audio & Video Logo
82 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
