I have a siebe climate control UP1 which seems to have stopped working, hot water and heating is just constantly on and doesn't seem to stop boiling, I have now shut down the whole system as I am worried I'm going to fry! Any help?
  • 518 Answers
SOURCE: central heating thermostat
Looks like it was replaced by the CM67 series, try this link for the manual:
http://www51.honeywell.com/pacific/common/documents/CM67_User.pdf
Geno
Posted on Feb 29, 2008
  • 744 Answers
SOURCE: Central Heating - Ignitor starts but no gas
Check the flame sensor near the ignitor....it could just be dirty. Check that first. Check the electrical connections to it. Also, check the flame sensor's position. It must be within the correct proximity of the ignitor to tell the gas valve to open. Make sure the gas is on to the unit.
Posted on Mar 15, 2009
  • 59 Answers
SOURCE: stopped heating, where is the heating element
turn off the electricity. unhook the two wires going to the heater. Hook up a meter to the two connectors. set the meter to ohms and ohm the heater out. If it has an open in it replace the heater.
David
Posted on May 25, 2009
heatman101
  • 43501 Answers
SOURCE: st6400c thermostat wont run the central heating independantly
This does not sound like a thermostat problem. I would be looking for a zone valve or circulator pump problem.
Posted on Nov 12, 2009
SOURCE: Hi There, I have an Ideal Response 120 Combi .
I have the same boiler with a similar issue. The water is more than likley leaving the system from the pressure relief valve, which will be routed outside. It sounds like you have lost the pressure in your expansion tank, which is inside the boiler. With the boiler pressure at zero and the power isolated, the expansion tank can be accessed from a panel at the top of the boiler on the right hand side. You will see a valve on the red expansion vessel like the one on a car tyre and can be pressurised with a car tyre air pump. I think from the manual the pressure should be about 1 bar, but it depends on the length of pipework on your system. A competent boiler engineer should be able to sort this out, but it may be that your valve is leaking, or the expansion vessel has failed and the problem will occur again.
Posted on Jan 03, 2010
1999 Ford Taurus keeps running hot
Does it get hot mainly when parked or stopped at a red light or does it get hot even when the car is in motion?If its only when your stopped,the cooling fans are probably not working due to a blown fuse,relay or bad fan motor.If the coolant inside the reservoir seems to boil once the engine gets hot,that can be caused by a defective radiator cap.A blown head gasket will also cause overheating.If you let the engine idle for a few minutes,shut it off,pull all of the spark plugs,see if any plug or two adjacent plugs are wet with coolant, that's a sign of a blown head gasket.If you constantly need to refill the radiator with coolant, that's another sign.
Oct 12, 2015 | 1997 Ford Taurus
I have a 2000 pontiac grand prix with a digital climate control system. The heat quit working, it doesn't blow out any heat. Now that it is warm outside the air stopped blowing out any air. The digital...
I have a 2000 pontiac grand prix with a digital climate control system. The heat quit working, it doesn't blow out any heat. Now that it is warm outside the air stopped blowing out any air. The digital temperature on the climate control is not correct. When it states that it is below 30 degrees on the ext and it is warm outside the air wont be cold. Once it starts going above 30 degrees the air gets colder. Today the blower stop working all together. Was told it maybe the climate control unit was bad. You can hear the door opening/shutting when you switch the temp from cold to hot. But there was no heat blowing out whatsoever in the winter time. Could you please give me your opinion on whether or not it is the climate control unit or something else?
Jul 11, 2011 | 2000 Pontiac Grand Prix
My heating is not working properly it starts and then after a while radiater light goes on and off n then heating stop working but i get hot water ok
In most cases problems with the circulator pump boil down to two problems.
The most common is air in the lines causing an air lock.
The next problem is that the pump gets stuck and is not running even though it may be hot and seem to be running. In this cause the pump can sometimes be taken apart, cleaned and it will work, but usually it needs to be replaced.
Here is a tip that I wrote that will explain circulator pump problems in more detail.
Heating Circulating Water Pump Problems
heatman101
Feb 23, 2011 | Heating & Cooling
I have a 95 Buick LeSabre Limited that will not stop blowing heat. Only when I turn the car off does it stop but when I turn it back on within 1 minute it is blowing Heat at full force. It has climate...
make sure you dont have a vacuum line off under the hood, going into the firewall, or to a control valve that shuts off the hot water to the heater
Oct 28, 2010 | 1995 Buick LeSabre
2003 Ford F250, the heater does not blow hot air
check the heater temp. control pot under the hood, inline on one of your heater hoses, it may be sticking causing hot water to only get to your heater core when the engine is at high r.p.m.s
Oct 31, 2009 | 2003 Ford F250 Super Duty Crew Cab
Parkray Cumbria efficiency problem
Some circulation pumps have a 3 phase mixing valve (cold,warm,hot) to regulate the water pressure in the building; no way to know unless you trace the plumbing. Basically, the hot water temperature could be lost because the circ-pump is cooling it with the cold water supplied to it. This is used to balance the pressure (aka Pressure Balancing Circ-Pump), so heater is really working overtime to heat the water. If the pump has two in and one out that's more than likely your problem; but you should consult a "old-school" plumber in your area.
Nov 25, 2008 | Water Heaters
Climate control/heat not blowing
put a plastic tie around the flap on the heater motor when it blowing hot then it cant be closed by the automatic climatic control .
Nov 19, 2008 | 1992 Lincoln Town Car
Electric Oven not getting hot enough
Sir, I think the top oelement is for broiling ONLY. It should not turn on when baking. The clicking may be the oven heating up.
How far apart were the oven temp instrument and the digital?
Don't expect them to match...they are inaccurate.
1. Heat water until it boils. Place digital therm in boiling water until it comes up to 212deg. If it is not at 212 in boiling water, record the error.(this gives a rough calibration to the digital)
2 Turn on oven, set to 350 deg, place digital therm on rack. Wait until oven reaches 350 (on stove) and read the digital. Note the difference between the two
Mar 30, 2008 | GE Profile Spectra JBP95 Electric Kitchen...
Heating & Cooling Logo
231 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
