Question about Universal Remote Control Remote Control
I need the instructions to operate the pink heart remote control that was purchased from things remembered in 2008 manufactured by ewig industries
Ewig ind. Projection clock manual needed
Try Googling (ewig)(model)(manual) without parens.
Jun 12, 2017 | Home
I need instructions to operate this remote. Thanks
as you gave us no information of make,model and what you want to control there is not much help we can give
Dec 09, 2015 | Televison & Video
Why won't television turn on with remote control?
Check the remote control for its infrared emission. Check it with fresh batteries. If it is found OK, check and replace the infrared sensor inside the TV. If you wish to get some details; check the site linked here. It has details about how to check a remote control; by one among the post. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/
http://electrohelponline.blogspot.com/
Sep 12, 2014 | Sanyo DP26640 LCD TV
How to uninstall OtShot
1. Find OtShot icon, seen as a pink heart, right click it and hit Exit.
If you can not find the heart icon, then open the task manager and end OtShot.exe process.
2. Follow the instruction that corresponds to your operating system to uninstall the Otshot.
Windows XP: Go to Start> Control Panel> Add Remove programs> Look for Otshot in the list> Click on Remove.
Windows 7/Vista: Go to Start> Control panel> Uninstall a program/Programs and Features> Look for Otshot in the list > click on Uninstall.
Important notice: Sometime you may fail to find the Otshot in Control panel if you get otshot via different way and in such case, please just ignore the first step and move on to next step.
Oct 18, 2013 | Computers & Internet
I've purchased a One For All remote and can't seem to remember where I set the operation instructions as well as the codes. Will you please help me.
One for All remote manuals and code lists are available from their site: http://www.oneforall.com/support/manual . Use the drop down menus to select Universal Remote Control and the model. The direct link for the manual for the URC-3021 is http://www.oneforall.com/uploads/support/00a1e876ce84e35c2c0351a407218d66.pdf .
Please note that the codes in the universal remote are usually limited to those for devices released 6+ months before the remote was programmed. If your device(s) are newer than your remote, you may need a newer remote.
I hope this helps.
Jul 11, 2011 | One For All URC-3021 Remote Control
I just purchased an LG TV but no codes instruction book.
LG is prioritized they don't create codes all codes are created by there manufacturers ,to be used with lge products
Apr 02, 2011 | Peerless Industries PL LG42LCD TV
I need code for my Tv
try one of these codes 003, 013, 012, 030, 046, 050, 051, 049 here are some instructions
Follow these steps to program the remote control.
  1. Turn on the component to be programmed.
  2. On the remote control, press and hold the SET button.
  3. While holding the SET button, press and release the POWER button
  4. Release the SET button.
  5. Press the appropriate component button for the component being set up.
  6. Using the number pad, enter the component's manufacturer code. NOTE: If more than one code number is listed for the manufacturer, repeat the procedure, entering one code at a time until you find one that works.
  7. Press the ENT button.
  8. Point the remote control at the component.
  9. Press the POWER button to verify operation.
NOTES:
  • If a new code number is entered, the code number previously entered will be erased.
  • When the batteries are replaced, the programmed codes may be erased. It may be necessary to reprogram the remote after replacing the batteries.
  • The operation of a combination deck of any kind is not guaranteed.
  • Some product functions may not be able to be controlled by the remote control. Use the remote control provided with the component.
  • If none of the codes listed for the manufacturer work, it may be necessary to try codes listed for other manufacturers or perform a search for the correct code. Consult the Operating Instructions provided with the remote control for steps on searching for the correct code.
  • In some rare cases, you may not be able to operate your non-Sony equipment with the supplied remote control. This is because your equipment may use a code that is not provided with this remote control. In this case, please use the equipment's own remote control.
here is a link for your remote controller http://esupport.sony.com/perl/model-remote.pl?mdl=RMV302#instr
Feb 18, 2009 | Sony RM-V302 Remote Control
JVC code to set my remote
Brand codes for universal remotes are determined by the remote control manufacturer, so there's not really "a code for JVC" that anyone could tell you. You could try looking on the remote manufacturer's website to see if they have the information available. Or you could simply purchase another remote, and you'd have a fresh set of instructions.
Dec 14, 2008 | JVC AV27F476 27" TV
Need tv codes and operating instructions for sony cmdr rm vl500
Here is the PDF file for your remote full instruction manual.
http://www.docs.sony.com/release/RMV302.pdf
The codes For your T.V
023
039
040
034
hope this help..
Nov 11, 2008 | Sony RM-V302 Remote Control
Philips universal remote codes
For the universal remotes, most of the models have their own code proprietary set. There is no industry standard. You must look in the romote's instructions to have the proper code settings.
Not all universal remotes will work with all models of TV sets. The combinations of the protocols for the codes are in the many thousands!
You will find that with the universal remotes they are very limited to accessing the features in the set. The universal remotes are only good for the basic functions. You will need the original remote to do any serious operations and to access the internal menus of your set.
Call the manufacture support for your set to find out how you can order the original. You would be better off.
Jerry G.
Aug 07, 2008 | Panasonic VIERA TH-65PV500 65 in. Plasma...
Universal Remote Control Remote Control Logo
551 people viewed this question
Top Universal Remote Control Televison & Video Experts
Computer Repairing
Computer Repairing
Are you an Universal Remote Control Televison and Video Expert? Answer questions, earn points and help others
