Question about GE Profile JTP56 Electric Double Oven
Touch pad for the oven does not work
Touch pad for the oven (GE Profile - JTP56) does not work except for Clear button. Intermittently F7 shows up and goes away when Clear button is pressed. Any ideas?
  • 523 Answers
Eith touch pad or control board un plug the touch pad if it returns the board is bad if it dont the touch pad is
Posted on May 27, 2010
Our monogram double wall oven has a f7 code on the control panel. None of the buttons appear to be working, except clear, which clears the code. Then still no buttons work, and the f7 code comes back. What...
It's most likely that the error code you are seeing is F1, not F7. F1 is a code for 'stuck touch pad'. You will need to replace the clock/ERC or the touch pad (or both).
Feb 28, 2011 | GE Monogram ZET3058SHSS Stainless Steel...
Built in double oven GE profile
F7 code is 'shorted matrix or start key' could be due to a problem with the key panel or control.
Aug 05, 2008 | GE Profile JTP56 Electric Double Oven
On a GE Profile Performance oven the code F7 show up on the key pad and the oven Beeps. Hitting the end or stop button stops the beepimg for about 5 minutes. Turning the power off achieves the same...
Hello there
The code can be caused by a faulty keypad or a Stuck keypad which may mean relay is turned on. Determine if problem is with the Key Panel or Control by:
1. Pushing CLEAR/OFF pad.
2. Disconnecting Ribbon Cable from control and waiting at least 32 seconds to see if Code recurs
If code recurs, problem is in the control. Replace control.
If code does not recur, problem is with the Key Panel. :
furtrhermore
Jul 21, 2010 | GE Profile JTP56 Electric Double Oven
Getting F7 code on a ge profile performance oven , oven light will not turn off and control panel will not respone.....beeps when I push CLEAR OFF button.
F7 A = Function pad button stuck or
B = Bad clock Unstick button or
Replace Electronic Range Control (ERC)
Try gliding your finger flat across the keypad rapidly and see if you can unstick the key / touch pad. Usually once this code appears it will repeat.
On self cleaning ovens this is the service check:
Thanks for using FixYa!
Kelly
Mar 09, 2010 | GE Profile JTP56 Electric Double Oven
Double oven. Top is digital. It has started
You have a stuck keypad or a bad electronic oven control. Try pressing all buttons at random several times each to unstick a faulty pad. If that does not work the EOC must be replaced.
Oct 06, 2009 | GE Profile JTP56 Electric Double Oven
F7 error code
Hi
On a GE range oven F7 indicates either a function pad button is stuck or the clock on the oven is malfunctioning
On the 99 Range oven F7 indicates a shorted Clear/Off Key due to membrane switch or a shorted control or connector
On the GE XL44 Self Clean Oven F7 is Stuck keypad or control relay malfunction
check out more detail here
http://www.fixya.com/howto/h155060-dreaded_f7_error
hope this helps
Aug 14, 2009 | GE Profile JTP56 Electric Double Oven
F7 was on, now no buttons are working
HI, you will need to replace the touch pad or key pad asap. it has failed.
Jun 14, 2009 | GE Profile JTP18 Electric Single Oven
My GE profile oven is giving me a code f7 and I can't clear it.  What does this mean?
Well, F7 error code occures due to
Replace the ERC there are ten screws 3 on each side and 4 on the control leave the hex screws alone all you need is a phillip screwdriver.
REMEMBER TO SHUT OFF THE POWER FIRST lift and fold out the control panel remove the ribbon cable and remove the four screws that hold the control board . replace control panel in reverse order.
Best of luck!!
Thanks
Dec 02, 2008 | GE Profile JTP56 Electric Double Oven
Can't clear Code F7
For a temporary solution, put a magnet over the "clear off" button. I used just an ordinary refrigerator magnet and it stayed off
Oct 03, 2008 | GE Profile JTP56 Electric Double Oven
GE Profile JTP56 Electric Double Oven Logo
727 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
Are you a GE Oven Expert? Answer questions, earn points and help others
