Question about Gateway MX6437 Notebook
Computer was disabled when Bios password was incorrectly entered two times in row, I was trying to remove disk passwor in order to add a larger hard drive It will not boot to a bootable disk or any other media. Can the bios be reset?
    Novelist:
  • 60 Answers
This information is intended for experienced users. It is not intended for basic users, hackers, or computer thieves. Please do not try any of following procedures if you are not familiar with computer hardware. I'll not be responsible for the use or misuse of this information, including personal injury, loss of data or hardware damage. So use it at your own risk.
A. By Using the Motherboard Jumper:
In most motherboards CMOS battery is soldered, which makes it difficult to remove the battery. In this case we use another method.
Almost all motherboards contain a jumper that can clear all CMOS settings along with the BIOS password. The location of this jumper varies depending upon the motherboard brand. You should read your motherboard manual to check its location. If you don't have the manual then look for the jumpers near the CMOS battery. Most of the manufacturer label the jumper as CLR, CLEAR, CLEAR CMOS, etc.
When you find the jumper, look carefully. There will be 3 pins and the jumper will be joining the center pin to either left or right pin. What you need to do, is remove the jumper and join the center pin to the opposite pin. e.g. if the jumper joins center pin to left pin, then remove it and join center pin to right pin. Now wait for a few seconds and then again remove the jumper and join the center pin to left pin.
Make sure to turn the PC off before opening the cabinet and resetting the jumper.
B. By Using Software:
I have found that BIOS/CMOS Password Recovery Tool is the most effective.:
BIOS/CMOS Password Recovery Tool is a program that works instantly to remove any lost or forgotten BIOS/CMOS password. Simply boot your PC to DOS and execute the program, and get access to forgotten BIOS/CMOS passwords in just seconds
BIOS/CMOS Password Recovery Tool Service: http://www.biospasswordrecovery.com/
Posted on Jun 09, 2010
Locked myself out of my ACER forgot password
hi,
if its the bios password. remove power supply then the battery from motherboard press start button put battery back in boot to bios...if windows password as you start the pc press the windows flag key and u at the same time this will bring up the disability features.can normally enter windows without the password.good luck.
Mar 09, 2014 | Acer Computers & Internet
RESET HARD DISK DRIVE LOCK FOR ACER ASPIRE
Step 1:
Which model of acer laptop ? there are many
The BIOS (Basic Input Output System) is designed to check the integrity of the computer hardware and launch the operating system. The BIOS also has basic security features that prevent unauthorized access to the computer by locking the hard drive with a password. The password is required in order to launch the operating system. That option can be disable without an changes to the operating system.
Turn your computer on. Press "Esc," "Del," "F2" or "F8" to access the BIOS. Use the arrow keys to go to the "Security" tab. Press "Enter." Highlight "HDD Lock," Boot Password" or "Hard Drive password" using the arrow keys. Press "+" until "Disable" appears. Go to the "Exit" tab, highlight "Save and Exit" and press "Enter." Press "Y" when prompted to reboot your computer without the hard drive password.
Feb 19, 2013 | Acer Aspire Computers & Internet
I have a w3622 and put in a new hard drive and tried to use the OS disk that came with the computer. what I get is PXE-E61: media test failure. check cable. Disk boot failure.insert system disk.
Sorry to hear about the trouble you are having. Try the following tips and lets see if we can get it up and running.
-Set the boot order in BIOS to boot from the disk drive first. In order to get to the BIOS, you will need to select BIOS option or Settings when the machine is booting up.
Most often, the above error is caused due to incorrect BIOS settings or a faulty hardware, such as hard disk. Sometimes, the error may also occur if the computer tries to boot from a device, on which it cannot find the required boot files. An improperly connected hard disk is also known to cause the same type of issue.
You should follow the below steps sequentially in order to isolate the cause and solve the issue:
  • Verify all the cable connections of the hard disk. An improper or loose connection is likely to be the reason, in case the hard disk has been recently installed or moved.
  • Check if no other storage device is connected to the computer. If it is, remove it.
  • Enter the BIOS setup when trying to start the computer and see if hard disk has been correctly setup and detected in BIOS. If the hard disk cannot be detected due to any reason, you should consider the next suggestion as it might be physical failure.
Regards,
G33k
May 09, 2011 | E-Machines eMachines Desktop PC
Can't unlock My Essentials 1TB Hard Drive Asking for password and I don't have it.
to remove the hdd password do the follwing
1) Restart your computer. Note that during computer restart, the screen goes blank for 3 to 5 seconds. Text then appears and the operating system boots up.
2) As soon as the first text lines appear on the screen, press the "Del" key on your keyboard to enter the BIOS setup
3) Navigate to "Security" in the BIOS menu using the arrow keys on your keyboard
4) Navigate to the option "Hard Disk User Password" and press "Enter
5) Navigate to a hard drive, press "Enter" and select "Disable" to remove the hard drive password.
6) Press "F10" to save and exit the BIOS settings. Computer booting resumes.
this will remove the hdd password
Jan 26, 2011 | Western Digital My Book Essential Edition...
I forgot my password to unlocking my WD external hard drive 2 TB? How can I unlock it without loosing all my data saved?
Jan 26, 2011 | Western Digital Elements 2 TB USB 2.0...
I forget my password in u3 what can i do??????
Jan 25, 2011 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
I forget the hdd password
Jan 15, 2011 | Computers & Internet
Clear password hdd
If you know your hard disk password, then go to the BIOS configuration and then to the password/security section and then to the hard disk password setting. You need to enter the hard disk password and then you can select disable hard disk password.
Nov 13, 2010 | Acer Extensa 5620 Notebook PC
When ever i power up my toshiba satellite laptop,there are two blank screens with a blue box in the centre saying enter password
the bios passowere has been engaged go to bios by pressinfg del or F1 button on startup go to bios setting password you will see enter password press button with passord blank again it will ask for confirm password enter blank password press enter it will delete all the password if you are un able to enter bios and asking for password remove the cover you will see three jumber pins near ur cmos battery pin one and towo are for normal pin 2 and 3 for clear comos in some there are only 2 pin short the pin to clear the cmos some times shorting doest start the computer dont worry put the jumbers back to the normal position and restart the computer while stating you will see cmos reset press F1 to continue or press DEL to enter bios press DEL and enter the correct time as clearing the cmos the time will be set defult if you cant see cmos jumper pin remove the cmos battery and restrt the computer then shut down the computer and place back the cmos battery in its compartment doing this please remove the power to your hard disk or your haRD DISK MAY GET CORROUPTED
Oct 24, 2010 | Computers & Internet
1. My ideapad Y430 easy cam doesnot working after i reinstall windows vista ultimate. Not i cant use it for my password. 2. I also try to partition it into four but it doesnot support i can have only two...
this is all I can offer in your situation.....one option is to..use the...
Novo button
This button functions as a reset button; use with caution. Press the
1. Novo button to enter the main interface of OneKey Recovery while the
power is off. You can use OneKey Recovery to restore the primary
hard disk partition (usually drive C) back to the factory default
configuration, including the operating system and the software on it.
Attention: Once done, the system can no longer return to its previous
state. All data on the primary hard disk partition (usually
drive C) will subsequently be lost. So make sure all
important files on the primary hard disk partition have
been backed up onto another hard disk or USB hard disk
drive before this operation.
For details, see “OneKey Recovery4.65 User Guide
2. For the camera check out these key functions....
The following describes the features of each function key.
Fn + Esc: Turn on/off the integrated camera.
Fn + F1: Put your computer in sleep mode.
Fn + F2: Turn off the LCD screen (any subsequent operation will turn the LCD screen back on).
Fn + F3: Shift to other connected display devices.
Fn + F4: Switch between wide screen and normal mode.
Fn + F5: Enable/disable the built-in wireless networking feature.
Fn + F6: Enable/disable the bluetooth features.
Fn + F8: Enable/disable the touch pad.
Fn + F9: Enable/pause Media Player playback.
Fn + F10: Stop Media Player playback.
Fn + F11: Skip to the previous track.
Fn + F12: Skip to the next track.
Fn + Insert/NmLk: Enable/disable the Numeric keypad.
Fn + Delete/ScrLk: Enable/disable Scroll Lock.
Fn + Pause/Break: Pause to view the system information during start-up.
Fn + up/down arrow key: Increase/decrease display brightness.
Fn + right/left arrow key: Increase/decrease computer volume.
3. And for the password...here you go....
Using Passwords
Using passwords helps prevent your computer from being used by others.
Once you set a password and enable it, a prompt appears on the screen each time you power on the computer. Enter your password at the prompt. You cannot use the computer unless you type the correct password.
Make sure that only authorized individuals access your computer.
Establishing different kinds of passwords requires that other possible users know the proper passwords in order to access your computer or your data.
As many as three passwords might be needed for your computer: the Supervisor password, the User Password, and the hard-disk drive (HDD) password. When the Supervisor password is set, only the Supervisor password entitles you full control of the computer.
• User password
If a user password is set and Password on boot is enabled, a password prompt appears when you turn on the computer. Unauthorized users cannot get access to configuration data.
You can also use the user password to enter the BIOS Setup Utility, but once the Supervisor password is set only a part of the options can be set.
• Supervisor password
With a Supervisor password, you can get full control of the computer. It also can be used as a power-on password, the same as the User password. Also, when you enter the BIOS Setup Utility with a Supervisor password, you are entitled to set all of the options.
• Hard disk (HDD) passwords
Once an HDD password is set, you need to enter it to get access to the hard disk. You can set the HDD password through either the User Only selection or the User + Master selection in the BIOS Setup Utility.
Note: If you set passwords through the BIOS Setup Utility and you put your computer into sleep mode by pressing Fn + F1, the following describes the behavior of the computer when you bring it out of sleep mode:
• You are prompted to type the Windows log-on password rather
than the User password to resume operation.
• If an HDD password is assigned to any hard disk drive, the hard
disk drive is unlocked automatically when you resume operation.
To set a User Password:
1. Turn on your computer. Press F2, while the initial screen is displayed.
The BIOS Setup Utility screen opens.
2. Select Security, using the cursor directional keys.
3. Select Set User Password, and press the Enter key. The Set User Password window opens.
4. Choose your user password, which can be from one to eight
alphanumeric characters in any combination. Type it in the Enter New Password field.
5. Press the Enter key once to move to the Confirm New Password field. Retype the password you just entered to verify it.
6. Commit your password to memory, and press the Enter key.
7. Press F10 to exit.
8. Select Yes in the Setup Confirmation window.
Changing or Removing the User Password
To change the password, do the following:
1. In the Enter Current Password field, type your current password.
2. In the Enter New Password field, type a new password; then retype it to verify.
To remove the password, do the following:
2. Leave the Enter New Password field blank, and then press the Enter key twice.
Note: Make sure the Password on boot is set to Enabled if you need the password protection at power on.
To set a Supervisor Password:
Only a system administrator will be able to perform this procedure.
2. Select Security using the cursor directional keys.
3. Select Set Supervisor Password, and press the Enter key. The Set Supervisor Password window opens.
4. Choose your supervisor password; it can be from one to eight
5. Press the Enter key to move to the Confirm New Password field.
Attention: You might want to note your password and keep it in a
safe place. If you forget your supervisor password,
Lenovo can not reset your password. You must take your
computer to a Lenovo reseller or a Lenovo marketing
representative to solve this problem. Proof of purchase is
required, and a fee will be charged for parts and service.
The next time you open the BIOS Setup Utility program, you will be prompted to type your password to proceed.
Changing or Removing the Supervisor Password
1. In the Enter Current Password field, type the current supervisor
password.
2. In the Enter New Password field, type the new supervisor password; then retype it to verify.
password.
Hard Disk Passwords
Two types of the hard disk passwords help protect the information stored on the hard disk:
• Hard disk user password
• Hard disk master password, which requires a hard disk user password If User only is selected and a hard disk user password has been set, but no hard disk master password has been set, the user must enter the hard disk user password in order to gain access to files and applications on the hard disk.
If User + Master is selected you need to set a master password and a user password both as the Hard Disk Password. Either of the two passwords can be used to get access to the Hard disk. Any change or removal to the master password deletes the user password.
To set a hard disk password:
Print these instructions.
3. Select Built-in HDD1 Password Select, and press the Enter key. A window for selecting User Only or User + Master opens.
I will send the rest in the comment section..hope this helps in some way...the Fang.
Mar 07, 2009 | Lenovo 3000 Y410 Notebook
Gateway MX6437 Notebook Logo
164 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
