Question about Sony Grand WEGA KDF-42WE655 42" Rear Projection HDTV
Sony Wega television has a red light flashing that says lamp
  • 10,594 Answers
When Sony tv shows lamp light that means lamp inside tv is dead/ broken and need to be replaced.
Lamp replacement procedure is easy and written in user manual.
Please buy Sony original lamp for good picture in tv.
Thanks.
Posted on May 27, 2010
  • 87 Answers
SOURCE: sony wega kdf-50e2000 standdby light blinks 8 times
8 BLINKS B -10.5 IS OVER VOLTAGE (B-BOARD) If your a novice call Sony or a Sony authorized service center.
Posted on Apr 14, 2009
rylee_smith
  • 8619 Answers
SOURCE: Sony 50 Wega LCD flashing red light
Hi
How many times is the red light flashing? The number of times the red led blinks means---
  • Continuous blink once a second, no pausing - No reply from the jungle IC301 (data bus is busy, shorted to ground, or held high), IK video path is defective.
  • One blink - not used for the self-diagnosis
  • Two blinks - B+ over current protection (OCP), unit goes to the standby mode then displays the 2 blink fault. Could be a short in the power supply of any of the circuits.
  • Three blinks - B+ over voltage protection (OVP), unit goes to the standby mode then displays the 3 blink fault. This is also a problem in the power supply circuit, check T603 and R672.
  • Four blinks - No vertical Deflection (V STOP), Screen goes to a single horizontal line then the video signal muted. Check IC1509, Q1505
  • Five blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.
  • Six blinks - No Horizontal (H STOP), no raster, goes to the blinking self-diagnosis function immediately. Check C515 & 516 and the jungle IC, IC206.
  • Seven blinks - High voltage shutdown. The high voltage has exceeded 33k and the unit goes immediately into safety shutdown. Check power supply regulation and horizontal circuits.
  • Eight blinks - Problem with the audio (AUDIO), unit goes to standby and blinks the self-diagnosis code. Check IC406 audio amp, PS401, and 402. On some projection models of Sony TV sets, this code means that T8005 (flyback transformer), or the associative components in the high voltage circuits are defective on the D board.
  • Nine blinks - Replace D 6116 and D 6301 on the "G" board, do not resolder as this will fix the problem temporary. Or Panel Module Error or Thermal Error. If it is intermittent 9 blinks, meaning sometimes the TV comes on and other times you get flashing, then change the switching regulator on the "G" board or check connections. Make sure the regulator is -12 or -13 (negitive).
  • Ten blinks - Check Q8014 and Q8013 for shorts, leakage, or bad solder connections on the " D" board. If the transistors are bad, check R8051 and IC8005, also on the "D" board.
  • No blinks(Unit is dead) - Problem in the standby power section. Might check fuse, R607, Q601, IC601, R612 and VDR601 (should show open).
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
Posted on May 01, 2009
Slinteriors
  • 8617 Answers
SOURCE: Sony Grand wega lcd projection tv Hd/Tv Help troubleshooting
Did you clean the air filter? Sounds like a thermal problem due to a plugged air filter.
Posted on Jan 17, 2008
  • 8457 Answers
SOURCE: RED LAMP LIGHT COMES ON A SONY 3LCD TV WHAT DOES
Lamp need it replaced.The lamp is dead.
Posted on Feb 12, 2010
  • 26 Answers
SOURCE: Sony WEGA Red Light Flashing Non Stop after shutt-down & repower
CHANGE THE LAMP
Posted on Mar 05, 2010
Sony 60" wega tv it just turned it self off when i
it's telling you to replace the projection lamp, it has burned out,
Feb 28, 2013 | Televison & Video
TV WONT COME ON AND THE LIGHT KEEPS FLASHIN RED AN GREEN ON THE STANDBY BUTTON
  1. If your Sony Wega will not turn on, the front green light blinks, you hear a faint whirring sound and the green light turns red and flashes, it probably means the lamp inside the set is no longer working. If you noticed the screen beginning to dim in the preceding days or weeks, this most likely is the cause.
  2. If the green light flashes and the picture comes on momentarily but then goes off, and the green button flashes until the set restarts, then the seal around the lamp mount is loose and needs to be refitted.
  3. If the picture on your Grand Wega cuts in and out and the green standby light flashes, both of the set's STKs need to be replaced. STKs are small chips on your television's circuit boards and are identifiable by their labels. The specific STKs used in your Grand Wega TV will be identifiable by the numbered labels on top of the STKs.
  4. When you plug in your Sony Wega and hear a loud popping sound, it's probably caused by a defect in the high-voltage circuit. Let the professionals take care of this one.
  5. If, after turning on your Sony Wega, you can hear your set but the screen is black, you most likely need to replace your projection lamp.
Read more: How to Troubleshoot a Sony Grand Wega ' eHow.com http://www.ehow.com/how_5243554_troubleshoot-sony-grand-wega.html#ixzz1EoY37gpC
Feb 23, 2011 | Sony Grand WEGA KF-42SX300 42" LCD TV
Green standby lamp flashes but power light does not come on and there is no picture
Here you go:
http://www.highdefforum.com/rear-projection-tvs/109533-flashing-green-standby-lite-then-flashing-red-lamp-light-sony-wega-50-xbr.html
Dec 05, 2010 | Sony KDF-E42A10 42 in. LCD Television
Changed lamp and TV won't turn on, power light flashes 3 times
Red light blinking 3 times shows problem with lamp cover.
Lamp cover is not fixed securely in your tv after lamp replacement. Lamp cover is first thing that was removed to replace lamp, check lamp cover and make sure its back in place properly.
Thanks.
Jul 17, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
Flashing red light saying lamp and no picture.
REPLACE LAMP !!!
Buy an Orginal Replacement Lamp.
May 19, 2010 | Sony Grand WEGA KDF-50WE655 50" Rear...
My sony wega 60 inch tv will not turn on. The
I bought a new blub for it and the light still goes green then red.Anybody know?? mg
Sep 02, 2009 | Sony Grand WEGA KDF-60XS955 60" Rear...
Power Light Flashing Red
Change the lamp. If red led is flashing 4 times. replace lamp fan.
Apr 22, 2009 | Televison & Video
Sony Grand WEGA KDF-42WE655 42" Rear Projection HDTV Logo
923 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
