Question about Whirlpool Duet GHW9150P Front Load Washer
WHILPOOL9150 FRONT LOADER, f05 CODE KEEPS COMING UP
  • prneumann Jun 13, 2010
    bad connection on sensor unit, thank you
    President:
  • 1,554 Answers
The error code is related to the water temperature sensor being out of range, that is, the resistance of the negative temperature coefficient (NTC) thermistor is not normal. Check the resistance of the NTC thermistor and the wiring connections.
Remove the 3 screws securing the top panel to the rear of the washer then slide the panel rearward and off the cabinet. Look for the central control unit (CCU) on the top rear of the cabinet and locate the temperature sensor wiring harness shown in the figure.
Disconnect the wiring harness from the CCU. Check the terminal connection and make sure it is snug fit and corrosion-free then measure the resistance between its terminals. The normal resistance is between 9k ohms to 35k ohms at room temperature.
Posted on Jun 13, 2010
  • 2 more comments
  • Jahn27
    Jahn27 Jun 13, 2010
    Recheck the resistance of the temperature sensor directly from its terminals if the resistance reading at the wiring harness is either open or shorted. Remove
    the three screws attaching the lower front access panel (service panel)
    to the cabinet
    then pull the panel down and off the cabinet. You can prop up the bottom
    front edge of the washer or cushion and lean it against the wall to
    access the screws more easily.
    On the bottom right side of the tub is the temperature sensor. Disconnect the wiring harness and measure the resistance of the sensor. Replace the sensor (part number 8181705) if the resistance reading confirms the abnormal reading at the wiring harness. Otherwise, replace the sensor wiring harness.
    Consider the replacement of the CCU if the sensor and the wiring harness are okay and the terminal connections are snug fit and corrosion-free.
    what should the resistance of the sensor be?
  • Jahn27
    Jahn27 Jun 13, 2010
    The resistance of the sensor is between 9000 and 35000 ohms for temperatures between 30 and zero degrees centigrade.
  • Jahn27
    Jahn27 Jun 14, 2010
    Congratulations and we are glad we are able to help you find and address the problem. Thanks for using Fixya.
My Kenmore Elite front loader keeps on showing the same problems
Cut down on your soap i only use very little soap and it works great.No more SUD code
Jul 02, 2014 | Kenmore Elite 45986 Front Load Washer
HOTPOINT WASHING MACHINE aq9f49u f05 fault code is coming on
Hello , I have the F05 fault also ... I have changed preasure switch and have checked the pump and no blockage. It goes through half a cycle then the F05 fault comes up and flashing lights .. Question ... should the pump turn freely if you turn it with your finger ?? Mine sort of judders ... Also when you tru it on a wash it does not draw any water in ??? Can you help please ??
thanks in advance
Malcolm .
Mar 06, 2013 | Hotpoint Washing Machines
ERROR CODE F05 KEEPS COMING UP after machine runs about 3 minutes then it drains
It is a computer board problem and they will fix it for free if you call the main company and complain. There was a recall on the board and they fixed my daughters machine for free.
Jul 16, 2011 | Whirlpool Duet GHW9150P Front Load Washer
F05 keeps coming up on my ultima 860 hotpoint 1600 spin w/m,we cant find manual,what is problem?
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Fo5 is a pressure switch fault; areas to check are pressure chamber for blockage, pressure pipe sump and pump. Click on a link for more Hotpoint, Creda and Indesit error code definitions or Hotpoint WMA / WM workshop manuals
Mar 05, 2010 | Hotpoint Ultima WF860 Front Load Washer
Coming up on screen F05
Error code F05 means pressure switch jammed on full.
Remove lower rear cover of washer.
Locate and remove large black hose fastened to bottom of drum.
Remove and clean filter inside hose.
Remove hose onto pump, and check for blockage or obstruction here as well.
This should solve the problem.
Please leave feed back.
Thankyou.
Jan 10, 2010 | Hotpoint Ultima WF865 Front Load Washer
I have a kenmore front loader 41744072300 that has error code f04. After replacing the keypad because of an F05 error code. Washer stops after 6 minutes on any cycle. Sears states f04 may be the panel is...
After 2 more sears repairmen. They replaced, motor control unit. Wrong.. Then the computer control board.. Correct.. Did not wait for the Repairman because they may break something else. Only took 1 month to figure this out.. Sears = Bad
Dec 28, 2009 | Kenmore Washing Machines
I have a Kenmore Elite front loading machine machine HE3 that keeps giving me an error code of F05. What does this mean? Obviously I've lost the manual
"F05" is a heat sensor error code. The following link explains:
http://www.fixya.com/support/r629462-f05_error_code_whirlpool_duet_kenmore
Actually, none of the error codes are included with your owner's manual. They are, however, included in the technical data sheet which should be located behind the lower kick panel directly below the door.
If you have any questions, please let me know. I hope this helps you.
Jul 11, 2009 | Kenmore Elite 45986 Front Load Washer
F05 Fault code
this will be the motor brushes
Jul 07, 2009 | Bosch Axxis WFL 2060 Front Load Washer
Hotpoint WT965 ultima fault code F05
I have a ultima WMD940 won't drain and comes up code F05. Please can you help my washing is piling up
Aug 27, 2008 | Washing Machines
Whirlpool Duet GHW9150P Front Load Washer Logo
108 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
