Question about George Foreman GV12 Indoor Grill
Model 12205 opp err appears and then it bleeps.
When i turn it on it says opp what is that
Sir/mam
Please provide the model or the brand name of your problem
that shows opp when you turn it on.
So that we (FixYa) member(s) can help you to satisfy your problem!
Thanks for using FixYa!
Oct 08, 2012 | Cell Phones
I have a reebok Z7 treadmill and it's showing err 2 when I switch it on
this happen can be E1 OR E2 whatever because this change from some manufacture to another. This mean:
1) LUBE the deck belt,very well
2) lube the rollers bearing
3) measure the input voltage motor, if there are the motor need repair
4) measure the output voltage board, for input voltage motor, if there ARE not, the board is faulty.
see the block. Try to run the sofware calibration after you fix,
God bless you
Jun 28, 2012 | Reebok Exercise & Fitness
Err 2 keeps bleeping
adjust the speed sensor, see the diagram attached , clean, and tight the connector very well.
2)Test the input voltage motor, if there are the motor need repair.
3) Test the output voltage board, for input voltage motor, if there are NOT the board is faulty.
4) Run the software calibration for diagnose, troubleshooting.
sincerely. God bless you
Apr 18, 2012 | Bladez Fitness BH T8 PRO Treadmill...
I WANT TO GET COMPLETE SERVICED MY E6.SINCE LONG TIME I AM FACING MANY PROBLEM WITH IT. PLS TELL ME WHERE PLACE I SHOULD GO IN DELHI,INDIA
here's the motorola service center in delhi,india
1. Active Telecom
Address: G-7, Vardhman Plaza, Plot No. H-3,
Netaji Subhash Place,Pitam Pura Delhi 110034, Delhi,
Pitampura, Near Netaji Subhash Metro Station, India,
Tel: 011-65667080
Email: active_tele@airtelbroadband.in.
2. Motostore (Smart Mart)
Address: O-2, Lajpat Nagar- II,
Central Market, New Delhi, Delhi, Lajpat Nagar,
Near Tiwari Sweet, India,
Tel: 011-41724384
Email: motoservice@smartmartonline.com.
3. Redington India P Ltd
Address: S-3, green park extension,
near uphar cinema, newdelhi-110016, Delhi,Green Park,
Near Uphar Cinema, India,
Tel: 011-46034444/46034400,
Email: servdelmobile@redington.co.in.
4. UCOM Technologies pvt. Ltd.
Address: DA/3, Ground Floor, Opp. Nathu Sweets,
Vikasmarg Shakarpur, New Delhi-92,, Delhi,
Vikas Marg, Opp. Nathu Sweet, India,
Tel: 011-43016487,43016488
Email: vikasmarg@accordccs.com.
5. UCOM Technologies pvt. Ltd.
Address: Shop No. 9, 1st Floor Kirpal Bhavan,
Near Raghuna Restaurant, G-8, Model Town 3rd,
New Delhi-110009, Delhi, Model Town, Near Raghuna Restaurant, India,
Tel: 011-42372210
Email: modeltown@accordccs.com
6. UCOM Technologies pvt. Ltd.
Address: 1st Floor, Unik Entreprises,
D Park, Opp. State Bank Of Patiala, Delhi Road,
Rohtak - 124001,, Rohtak, Opp. State Bank Of Patiala,, India,
Tel: 01262-321888
Email: rohtak@accordccs.com.
7. UCOM Technologies pvt. Ltd.
Address: 15-A, Block BA (DDA Flats), Opp. DDA Market,
Shahid Capt. Nayyar Marg, Jail Road, Janakpuri,
New Delhi - 110058, Delhi, Janakpuri, Opp. DDA Market, India,
Tel: 011- 25526358,
Email: janakpuri@accordccs.com.
8. UCOM Technologies pvt. Ltd.
Address: 20, Rajendra Bhawan, Rajendra Place,
New Delhi-110008,, Delhi, Rajendra Place, 20,
Rajendra Bhawan, Ground Floor, India,
Tel: 011-41538487
Email: rajendraplace@accordccs.com
just pick the one that is near to you... :)
Dec 01, 2011 | Computers & Internet
I need the written instructions to set up an avid screen gazebo 13x9 model 2086
To get the instructions you need to call or email Avid at.
AvidOutdoors.com
P.O. Box 5932
Albany, NY 12205
Phone: 1-518-453-2436
Fax: 1-518-453-0053
E-mail: mail@avidoutdoors.com
Business Hours: 9:00 AM - 5:00 PM Eastern Time M-F
Sep 17, 2011 | Miscellaneous
I have been given a George Forman Grill model no. 12205 but did not get a user manual or guide with it wher can I get a copy
You can download and print the instruction manual in PDF format by clicking this link.
http://www.georgeforeman.co.uk/pdf/product_10_12205.pdf
Adobe PDF Reader is required to view this manual. Download Adobe Reader
Hope this helps. Kindly let me know if you have any difficulty in downloading the manual.
Thanks for using FixYa.
Apr 12, 2011 | George Foreman Kitchen Appliances - Others
Detector shows 888 when first switched on then 0 then err with bleep
Showing 888 for a second is normal, it is a display test.
But Err means the unit is faulty or end of life (around 7 years), it can't be repaired so it should be disposed of and a new one bought.
Dec 20, 2010 | Kidde Nighthawk Combo Gas/co Detector
''err 99'' code appearing fairly often recently on Canon Rebel XT
To isolate the cause of the issue, do the following: -
1. Turn off the camera.
2. Remove the lens, battery, and CF card.
3. Allow the camera to sit without power for approximately 20 minutes.
4. Insert only a fully charged battery, and turn on the camera.
5. Depress the shutter button as you would to take a picture.
Does the “ERR 99′ message appear? If so, the camera may be faulty and requires a service. If it does not, then: -
2. Insert the CF card.
3. Turn on the camera.
4. Format the CF card in the camera.
Does the “ERR 99′ message appear? If so, then the CF card is faulty. Try a different card. If the message does not appear: -
2. Clean the gold contacts on the lens by GENTLY rubbing them with a pencil eraser or soft cloth. Keeping the camera face pointing down, also clean the gold contacts on the camera, being careful that you do not let any debris fall into the camera body.
3. Reattach your lens.
4. Turn on the camera.
If the “ERR 99′ message only appears when one particular lens is attached, then that lens should be examined by a service technician.
If you see the “ERR 99′ with a different Canon lens attached, then the camera is faulty and should be serviced.
Mar 19, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Err 7
Err7 is a motor error.Check out the following Haier washer manual link (page number 17).
for washer manual click here
The only solution suggested is to replace the motor.
Jan 08, 2009 | Haier Washing Machines
Service centre in delhi?/
Motorola Service Centers in Delhi
1. Active Telecom
Tel: 011-65667080
Tel: 011-41724384
Tel: 011-42372210
Email: modeltown@accordccs.com.
Tel: 01262-321888
Tel: 011- 25526358,
Tel: 011-41538487
Email: rajendraplace@accordccs.com.
Jun 04, 2008 | Motorola Mobility ROKR E6 Smartphone
George Foreman GV12 Indoor Grill Logo
32 people viewed this question
Top George Foreman Kitchen Appliances - Others Experts
Mike
Gerry Harvey
Gerry Harvey
Angel Joseph Jr.
Angel Joseph Jr.
Are you a George Foreman Kitchen Appliances - Other Expert? Answer questions, earn points and help others
