How do I start bluetooth on the qosmio g25-av13?
Try the ff:
1. Are you also using a wireless internet? If you are and you cannot also connect on wireless, make sure that the wireless is enabled on your laptop. On the left side of the laptop there is a on/off switch push the switch to on. (beside the usb port).
2. if it is already on, make sure that the bluetooth is enabled also, you can check it on control panel, system, hardware, device manager, bluetooth, right click on bluetooth driver, if you see enable bluetooth click on it, if you see"disable bluetooth" that means it is already enabled.
3. If the above is already configured, lastly, look for the bluetooth icon (bluetooth manager) on the lower part of the screen on the taskbar/tray if you see the bluetooth icon, right-click on it then click "Enable Bluetooth Radio". Now, if there is no bluetooth icon on the tray at the lower right of the screen, go to Start, Toshiba, Bluetooth, Bluetooth Settings, inside the Bluetooth SEttings, click on Bluetooth, Options, CLick on Enable Bluetooth Power, also, inside the Tray Icon (still inside Bluetooth Settings) select an icon so you can always see the status of your bluetooth on the Tray and you don;t need to do and check everything everytime you cannot connect via Bluetooth.
Hope this helps.
Tricia
