Question about Logitech MX1000 Laser Cordless (097855023933) Mouse
Docking station for MX1000 Laser mouse not working
I have a MX1000 Laser mouse. My charger/docking station quit charging my mouse. I know the batteries are good. A co-worker has the same mouse and my mouse will charger on his docking station. Any ideas?
  • 2,404 Answers
That docking station has a lithium-ion battery in it that supposedly never needs replacing. I'm wondering if the battery did go out on it and needs to be replaced. If there is now way to get inside of the docking station then you will need to get another mouse, cause you can't just get the docking station.
Posted on May 27, 2010
Dell duo station
I had the same issue. I tried opening the dock and could not find anything wrong. It seems the charger was delivering sufficient voltage. So I disconnected power to the charger and reconnected couple of times and it started working again. My charger has a LED light and based on the brightness of the light you can findout if the output voltage is close to 20 volts.
Sep 20, 2012 | Dell Jbl Inspiron Duo 1090 Audio Station...
Using mx1000 on win 7. everty hour or two the mouse disconnects and i have to add it to the bluetooth connections
Using 32bit drivers on 64bit Win7 will do this. It'll work for hours, and then quit responding with a "code 10" in the device manager. When you download setpoint/drivers, look closely, they have 32 and 64bit versions.
Feb 11, 2011 | Logitech MX1000 Laser Cordless...
Recharger doesn't recharge
mcdevito75 here, The batteries in the mouse could be going bad, old.
Jun 29, 2010 | Logitech MX1000 Laser Cordless...
Logitech MX1000 Laser Cordless Mouse, I replaced the li-ion battery with a NiMh AAA battery pack, soldered in the board that was on the old battery and used it for a week before the battery pack needed...
Li-Ion battery and NiMh battery have completely different charging requirements! Li-Ion battery has much stricter charging requirement and the regulator is normally design to trickle charge at 0.1 Current rating @ 4.2V and then completely shut down.
WARNING: if you use a Ni-Mh charger on a Li-Ion battery, then it will erupt and even explode and catch fire!
Bottom line is that the rescued Li-ion regulator is not designed for your Ni-Mh pack and you will never get a full charge with it and you will need a completely different regulator board: you are better off putting in a suitably sized Li-Ion battery with inbuilt regulator but with higher current rating if possible.
Hope it helps! Let me know how you go.
Nov 14, 2009 | Logitech MX1000 Laser Cordless...
Looking for a charger for this mouse
go to radio shach anget sku #273-0029 3-12 vdc seletable power adaptor/charger with tip "g" use the positive tip configuration ,(this will make sense later).
Plug into cradle ,there ya go.
cost 19.99 +tax
mine works nice and if you have another charger go oit that is 3,4.5,6,7.5,9,or 12 then all you need in a bind is another adaptor plug to match.
Mar 22, 2009 | Logitech MX1000 Laser Cordless...
Charger no longer charges
Clean the Contacts with an eraser, fine steel wool or light sand paper.
Feb 18, 2008 | Logitech MX1000 Laser Cordless...
No software disk.
Go to logitech website and download current drivers.
Nov 04, 2007 | Logitech MX1000 Laser Cordless...
Laser Mouse MX 1000 By logitech
Pretty much I cannibalized a pack of battery charging adapter plates, soldered the three wires to them, trimmed & bent them a little.. and then epoxied them down to the battery hold-down in their appropriate places. A little trimming was done on the plastic so the contacts could reach in far enough without obstruction.
After having the mouse sit around useless without a working battery in it.. for months, which definitely irritated me... I looked up 3.7V li-ion batteries and came across the "klic-5001 battery" (google it) and ordered two. The first one I destroyed trying to solder the wires directly to the battery contacts.. which just ruined all the internal li-ion battery components(i.e. DO NOT TRY DOING THAT)... the second battery, which I never tampered with whatsoever, is connected to the mouse via the contacts I described above. The klic-5001 batteries by the way do fit very well in the hold-down meant for the original battery.
End result: one, exceptionally well working MX1000 mouse which I can replace the rechargeable battery inside anytime it begins to get to aged and not working so well... ^_^ It charges as normal and the battery monitoring works like nothing ever changed.
Logitech mx1000 Not charging.
I had the same problem with the mouse MX1000 not charging when it is on its charger.
Then, I realized that I forgot to plug the adapter for the charger - this charger is not taking its power from the USB port but from an external charger!
Once I plugged the charger, the mouse recharged without any problem.
I hope this helps.
This mouse is really great, once this question of recharge is solved.
Stephan
Oct 27, 2007 | Logitech MX1000 Laser Cordless...
Logitech MX1000 Laser Cordless (097855023933) Mouse Logo
326 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
