Question about Vacuums
1800 vacuum cleaner belt replacement
How do you get into the belt to replace it?
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 310 Answers
Generic problem for all Vacuums
Not knowing the brand name of the vacuum other than the 1800 vacuum cleaner belt replacement, normally the belt is located @ the bottom the vacuum attached to the brushroll and is held on by either screws, clips, or some even snap on – but mostly they use some type of screws to open the area to replace the belt, if needed contact the company website, include the brand name and the model number and request a schematic of the vacuum and that will give you an exploded view of how the vacuum assm goes together and also shows the belt replacement and how that is connected.
http://www.dooyoo.co.uk/vacuum-cleaner/typhoon-1800-upright-vacuum-cleaner/1021772/
Posted on Apr 08, 2008
3 Suggested Answers
Buffalo12980
  • 625 Answers
SOURCE: Belt Replacement in Hoover Savvy
go to thehooverstore site. find your machine and they'll have exploded diagrams for your machine - your should be able to tell how to replace the belt.
Posted on Sep 22, 2007
SOURCE: How to replace the belt on my bissell model 3512-9 vacuum
There are two tabs on the bottom that release the plate and allow the plate to be snapped in and out. They are easy to spot. But, there are also screw holes in some models and there may be screws in them. You might have to deal with both. The screws are unecessary and you can leave them out when you put the plate back on.
Posted on Sep 22, 2009
The brushes do not spin. Nothing caught in the brushes.
Hi, it's Jack at Dyson.
DC25 doesn't use a conventional, user-replaceable belt. Instead it it uses a belt engineered to last the lifetime of the vacuum in normal use, protected by a sensor which shuts off the brush bar if something jams it.
Normally, checking the cleaner head for obstructions and removing any threads or hair from the brush bar and endcap will allow you to reset your machine:
However if you've already followed each of the steps shown in our video guide without success, you may need a replacement cleaner head or a repair of your machine. If you can contact us directly we should be able to arrange this for you, and can also confirm if this is covered under your Dyson warranty.
When you have your DC25 easily to hand, please get in touch with the Dyson Customer Helpline so we can help determine if a repair or replacement part is needed. You can reach us by calling 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
We'll look forward to speaking with you.
Mar 09, 2015 | Dyson DC25 Vacuum
How do i change the brush bar and belt on a dyson dc27
Hi there, it's Jack at Dyson.
DC27's brush bar is powered by a belt engineered to last the lifetime of the machine in normal use. Unlike a conventional vacuum cleaner belt we wouldn't usually expect it to need replacing, and therefore it's not designed to be accessible to the User.
If your DC27's brush bar won't rotate this may be caused by something simple, and we should be able to help you resolve this with some simple troubleshooting checks over the phone.
When you have your machines easily to hand, please give the Dyson Customer Helpline a call on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
We'll look forward to providing further assistance.
Feb 28, 2015 | Dyson DC27 Bagless Upright Vacuum
Brush is not rotating
Hi Barbara, it's Jack at Dyson.
DC33's brush bar will only rotate when the vacuum cleaner is turned on and reclined into the normal vacuuming position, and the brush control is set to 'Carpets':
If the vacuum cleaner is standing upright, or set to 'hard floors', the brush bar will not rotate.
If you're confident the brush control is set correctly, but the brush bar won't rotate when the machine is turned on and reclined, please contact our experts directly so we can talk you through some further troubleshooting checks. If a repair is needed, we can also confirm if this is covered under your Dyson warranty.
Dec 08, 2014 | Dyson DC33 Multi-Floor Upright Bagless...
Where is the brush belt on a dyson 07 upright vacuum?
The type of belt mechanism will depend on which model of DC07 you own. If you have a DC07 machine without the brush control feature, the user-replaceable belt is located within the cleaner head:
http://www.dyson.co.uk/support/dc07/dc07-standard/maintaining-your-dyson-machine/change-the-belt1/belt-fitting-preparation
However, if your DC07 includes the brush control feature (you should see the Carpet/Hard floor dial on the cleaner head), your machine will use a clutch mechanism with belts engineered to last for the lifetime of the machine in normal use.
If you have a DC07 with brush control and would like some help with it, please contact us directly by calling 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Sep 25, 2014 | Dyson DC07 Animal Bagless Upright Cyclonic...
Were are the belts on dc25
DC25 doesn't have a traditional, user-replaceable belt - instead it has a belt engineered to last the lifetime of the machine in normal use. The belt is protected by a sensor which shuts off the brush bar if something jams it, so it's very unlikely the belt itself would need replacing.
If your machine's brush bar isn't rotating, you may need to reset your machine after clearing the brush bar of any threads or hair, and checking the cleaner head for any obstructions. Our Support video walks you through each step:
Please note, the brush bar will never rotate when the vacuum is standing in the upright position. Make sure you recline the machine into the normal vacuuming position before testing.
I'm confident this will resolve the issue, but if you would like further advice from our experts after giving this a try, please give us a call on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Aug 30, 2014 | Dyson DC25 All Floors Bagless Upright...
How to replace belt
Unlike many upright vacuums, DC25 does not have a traditional, user-replaceable belt. Instead, it has a belt engineered to last the lifetime of the vacuum in normal use. It's protected by a sensor which shuts off the brush bar for protection if something jams it.
If your DC25's brush bar isn't rotating, it's likely that the belt is fine, and the vacuum may simply need a reset. To reset your vacuum, just follow the steps shown in the video below:
Please note, the brush bar will never rotate when the vacuum is standing upright. Make sure you recline it into the normal vacuuming position before testing it.
I'm confident this will resolve the issue, but if you'd like any further help or advice from our experts after giving this a try, please give us a call on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Jul 27, 2014 | Dyson DC-25 Lifetime Washable & Reusable...
Brush won't spin when carpet cleaner is running
see this causes and fix it. God bless you
If the vacuum cleaner brush is not spinning, the brushroll bearing might be jammed. Try removing the brushroll assembly and cleaning all hair, string, lint, etc. from the brushroll bearing. If that doesn't solve the problem the brushroll may need to be replaced.
If the vacuum cleaner brush is not spinning, the brushroll assembly itself might be jammed. Try removing the brushroll assembly and cleaning all hair, string, lint, etc. from the brushroll bearings. If that doesn't solve the problem the brushroll may need to be replaced.
If the vacuum cleaner brush is not spinning, the brushroll itself might be jammed. Try removing the brushroll and cleaning all hair, string, lint, etc. from the brushroll bearings. If that doesn't solve the problem the brushroll may need to be replaced.
If the vacuum cleaner brush is not spinning the cogged belt might be broken, stretched out too much, or might have fallen off. Check the belt and replace as needed.
If the vacuum cleaner brush is not spinning the drive belt might be broken, stretched out too much, or might have fallen off. Check the belt and replace as needed.
If the vacuum cleaner brush is not spinning the belt might be broken, stretched out too much, or might have fallen off. Check the belt and replace as needed.
Sep 27, 2012 | Vacuums
Electrolux velocity pet lover 1800
we had the same problem and replaced the driver belt. The only problem is that we seem to have to replace the belt everytime we hoover!
Sep 07, 2008 | Electrolux EL1000A2 Pronto Bagless Stick...
Vacuum Cleaner Bags
REQUIRE REPLACEMENT OF DUST BAG BRAND BLACK AND DECKER MODEL VB 1800 XE HEPA 13.PLEASE SOLV THIS PROBLEM OR COMPATIBLE DUST BAG
Aug 27, 2008 | Black & Decker HV6000 Bagged Handheld...
Vacuums Logo
767 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
