Question about Copystar CS-2030 Copier
When copying, I get lightly shaded bands of varying with across the copy. There are maybe 6 or 8 bands.
  • 113 Answers
Clean the main charger and grid then try again. can also clean the magnet roller
Posted on Sep 09, 2010
I have a Minolta cs pro 2080 copier, shading on copies
3 possible causes:
1) The optics are dirty thus making your copy darker. The test for this is to manually lighten the copy using the exposure control on the panel of your copier. Lighten the copy several positions and see if the copy gets better. If it does then the optics need to be cleaned.
2) The copier is overtoned. This means that the toner to developer concentration is to high. This will require a trained technician to lower the toner ratio and then recalibrate the toner/developer ration using the F8 mode.
3) If the shading gets much worse as you run say 10 copies in a row then the drum cleaning blade would be the cause. So run 10 copies of something and compare the first copy out with the tenth copy out. Do you see a dramatic difference in the amount of background or "shading"?
Good Luck and thank you for using Fixya.
Mar 16, 2010 | Minolta EP4000/5000 CS/PRO Copier
Photocopy has black band at end of the page
well ithink tou are using the ADF to copy something...you will have to clean the scanner glass(not the scan bed but when you lift the ADF cover you will see a scanner glass about inch wide)...it should resove your concern...
Mar 27, 2009 | HP Photosmart C7280 Printer
Error 3200 and no light from scanner Lamp on Kyocera FS-1118MFP
this error belogs to Exposure lamp problem ? cause of this error 1. Defective scanner PWB. 2.Defective exposure lamp or inverter PWB. 3.Incorrect shading position poor . 4.poor contact of the connector terminals Solutions:- 1. Replace the scanner PWB and check for correct operation. 2. Replace the exposure lamp or inverter PWB. 3.Adjust the position of the contact glass (shading plate). If the problem still occurs, replace the scanner home position sensor. 4.Check the connection of connector YC7 on the scanner PWB, and the continuity across the connector terminals. Repair or replace if necessary.
Mar 24, 2009 | Kyocera FS-1118MFP Laser Printer
Lighter bands across copy using Canon F 132500 copier
Open the flap to expose copy platen and press print you should get a flat even black
if you get the white bands do the following:
Clean the corona wires open the cover pull out the sliding charge wires and clean with q tio and acoho or a pencil erasure
If that does not work remove top glass and clean mirror and bottom of glass
Dec 24, 2008 | Office Equipment & Supplies
Light copies
You enter the buttons in this order. " menu" " pound" 1934, the machine will come up with a T or tech on the screen, you have to then press the machine settings button then scroll to maintenance, press enter, go to adjust shading, place 5 white pirces of paper on the glass and run the procedure.
I doubt though that without removing and thoroughly cleaning the scanner that it will work properly. Those mirrors and the glass haze up badly and need to be cleaned to clear up copy quality.
to remove from tech mode once you do shading. Just POPO the machine. ( Power Off Power On )
Jul 18, 2008 | Xerox WorkCentre M15i Laser Printer
Copying spreadsheets
If the lines look like little steps, maybe broken is segments off by about the thickness of a pencil line, try this. Most likely it's the scanner. You can try calabrating it by doing the following. press in order. Menu #1934. You will see a T pop up to the right side of "Ready to Copy". Then press machine status, then scroll until you find maintenance. May be under system settings. When you find maintenance, press enter, then scroll to Shading Adjustment. Or depending on software version, Adjust shading. Place 5 sheets of paper on the glass,, press enter, then when is says "Adjust Shading?" press enter again. Let it print out the sheet. Then try a copy. If that doesn't help, the scanner itself will probably need replacing.
The scanner is the issue. The segments of what is called the CCD are not working properly.
Once you adjust shading, if that doesn't work, the scanner will need to be replaced.
Feb 28, 2008 | Xerox CopyCentre C20 Black and White...
Copystar CS-2030 Copier Logo
Top Copystar Office Equipment & Supplies Experts
Kyocera HP Expert
Tammie Duggan
Tammie Duggan
Timothy Van Der...
Are you a Copystar Office Equipment and Supply Expert? Answer questions, earn points and help others
