Question about RIM BlackBerry? Curve 8330 Cellular Phone
My roller ball pushes pound or star when I push down on it. Help! I cant do anything on this phone now!
    Problem Solver:
  • 17 Answers
Probably needs to be cleaned
Posted on May 27, 2010
The Dyson roller ball vacuum I have is making me crazy because the roller bar wont turn. What gives?
Check that you dont have anything blocked in the roller, if all is clear there is a little red button on the side off the roller. Push this in and this will reset the roller... If that doesnt work, check that it is switched on with the switch next to the power button.. That should solve your problems
Oct 04, 2010 | Dyson Ball DC24 Bagless Upright Vacuum
I have a sidekick and when i changed it to spanish, now doesnt do anything at all it powers on and the rolling ball doesnt work and doesnt responds to anything, anyone knows something ?!
You may need to perform a Master Reset. This will fully restore your phone to it's factory settings.
To do this, remove your SIM card and follow these directions:
1) Flip the screen as if your about to close it.
2) On the upper right hand side look closely. You will see a little arrow pointing to a small circle.
3) Push in the circle with a paperclip and at the same time hold down the power button.
4) Remember to push both at the same time and keep them pushed in until the phone turns off.
5) Once the phone turns off you have done the hard reset successfully.
6) Then, turn your phone back on normally.
Apr 01, 2010 | Sharp Sidekick LX Smartphone
What is the unlocking code for a blackberry 7290? the carrier is rogers, in canada
each unlock code is unqiue to each phone. There are several different unlocking sites out their that can calculate the code for you based on your phones imei number, which can be found by pushing *#06# (star, pound, zero, six pound) I site that i have used is called www.bestcellunlock.com , it worked for me!
Feb 24, 2010 | RIM BlackBerry 7290
Dell 948 false paper jams
After you lift open the top, look below the shiny bar that the Print Head slides left/right on. You'll see a row of 8 tiny rollers. In between the middle two rollers (rollers #4 and #5 from the left), look for a small plastic tab sticking up between them. Touch this tab with the tip of a ball-point pen to see if it pushes down. If it does, then push the "checkmark" button on the control panel.
Dec 18, 2009 | Dell 948 All-In-One InkJet Printer
Hi i need a unlock code for my samsung phone do u know where i can get one for free as i have just spent 10 pounds and been conned
try these,
First do a CUSTOM reset: *2767*2878#
Make a FULL reset by typing: *2767*3855#
1. First do a CUSTOM reset: *2767*2878# (star 2767 star 2878 hash)
turn off the phone
2. take out the battery and sim and put wrong network SIM and insert a half of it,
so it won't ask for network password and shows "Insert SIM" message.
Now put the battery ,and switch the phone on .(phone shows "Insert SIM" message.)
3.With out turn off the phone push the sim fully in. At this stage the phone is still asking to "Insert SIM"
4. Make a FULL reset by typing: *2767*3855#(star 2767 star 3855 hash)
5. The phone should reboot working with "wrong" sim inside.
6. Make a Change the NCK password to 8 zeros by typing: *7465625*638*00000000*00000000#
(star 7465625 star 638 star 8zeros star 8zeros hash)
7. Now Disable network lock By typing: #7465625*638*00000000#
(hash 7465625 star 638 star 8zeros hash)
Phone is unlocked (check with *#7465625#)
Sep 27, 2009 | Cell Phones
Roller ball
All you have to do is take a sheet of paper with print on it. Take the battery out of you phone. Next do a figure eight motion with the ball side down on the phone about 10 times. There is something on the ink on the paper that will make this work again. good luck
Feb 12, 2009 | Verizon Communications BlackBerry Pearl...
Where can i get an online Manual for a Voice Star VS700 Bluetooth
Hold the power button down, once it beeps, keep holding down the power button but push in the volume up button, once it beeps let go of the volume up button and while still holding the power button push in the volume down button. the pass code is "0000".
Dec 11, 2008 | Radio Communications
Pound Key
Open a notepad and then press all the key on keypad and check which one is giving a pound key. This is required because if the key cover is changed in that case the pound will work when pressed a different key.
Also clean the keypad or else get a new one.
Thanks
Oct 31, 2008 | Toshiba EKT6520SD Phone
Pearl roller ball
It might be a case where the track ball has some dirt or debris underneath it. First, turn the device off. Next, press down firmly on the track ball while at the same time rolling it in every direction. Hopefully that will knock loose any debris. Another tip to try is to wet your thumb with a little water and do the same thing.
If those two options don't work, you may try taking out the track ball and blowing out the slot with some compressed air. Below is a link that shows how to remove and clean the track ball:
http://www.blackberryforums.com/general-8100-series-discussion-pearl/113889-how-clean-trackball-your-pearl-8100-a.html
Oct 03, 2008 | RIM BlackBerry Pearl 8100
RIM BlackBerry? Curve 8330 Cellular Phone Logo
119 people viewed this question
Top RIM Cell Phones Experts
Computer Repairing
Computer Repairing
Longtime User
Jason
Are you a RIM Cell Phone Expert? Answer questions, earn points and help others
