Hello EMIS,
On the front panel of the DVD-RW, you should see a small hole, either above or below the tray. Take a paper clip and open it out. This should just about fit into the hole. Push the clip tip into the hole as far as it will go and keep poking around. This will actuate the manual release lever for the tray and the tray should pop out.
S-L-O-W-L-Y pull the tray out and take out your DVD. Restart the computer and the tray should go in automatically.
Hope this helps! Should you have any further questions, please feel free to
post them here.
P.S. Before you assign a rating, please
make sure that the issue is resolved or you are satisfied. If not, please post
back as to what you did, and/or any other questions you may have, and I will
try to assist you as best I can. Please do not assign an ‘Inappropriate’ or
‘Thanks for trying’ rating if your issue is not resolved after the first
response itself, as sometimes a bit of to and fro dialogue may be necessary
before we can find a fix or an answer to
your query.
If you find that the solution/answer I provided led you
to, or resulted in a fix, please close the ticket with a FixYa! or Helpful
rating. I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Cheers!
IrishDruid
Hello EMIS,
Have you been able to resolve your problem? If you have,
please close this problem ticket with a Helpful or FixYa! rating. I would be
very grateful for your gesture of appreciation.
post them here.
Cheers!
IrishDruid
"Discover
How to Achieve Your WILDEST DREAMS"...Free Download
FREE SOFTWARE GIVEAWAY
Windows Utilities
Just wanted to inquire if your issue is resolved, or if there is anything
further I can do to assist you…
to, or resulted in a fix, please take a moment to close the ticket with a FixYa!
rating under my solution. I would be very grateful for your show of appreciation.
post them here.
Cheers!
IrishDruid
P.S. -You can rate this solution with one of
four votes, if you feel your issue is resolved."FixYa!"
- The solution provides great advice on how to solve the problem.
(Positive Rating)"Helpful"
- The solution provides useful leads that helps solve the problem.
(Positive Rating)"Thanks
for Trying" - The solution does not solve the problem but the
effort is appreciated. (Negative Rating)"Inappropriate"
- The solution has absolutely nothing to do with the problem. (Negative
Rating)
If your issue is not still not resolved, do not
assign a rating just yet. Please post back as to what steps you took, results,
etc, and I will try to assist you further as best I can.
IrishDruid
writing error
