Question about Garden
I have been given a rear tine tiller. the owner said that in ran last year. I have not tried to start it, am going to get a new plug, clean gas, and try it. the throt. cable is froze up and am tring to free it up.have not checked the oil yet but will do that , is there anything else that i should do ?
Be sure that you check all grease fittings. and spray your frozen cable good with wd 40 and let set over nite
Posted on May 29, 2010
Testimonial: "I have started the motor, now to clean it up and paint in thanks"
Started electric tiller for 1st time this year. It ran a few inches then stopped. Tried reset button, still won't start. Tested cord and it's good. Any suggestions?
Double check to make sure nothing is binding or blocking tines.
Unplug see if you can turn tines by hand ever so slightly. How old is the tiller? warranty? troubleshooting in owner's manual? Customer service may be helpful.
Mar 04, 2015 | Mantis Electric Tiller
DRAINED GAS FOR WINTER IN CRAFTASMAN REAR TINE TILLER. PUT GAS IN WOULDN'T START. SO PUT GAS IN CARBURETOR, WOULD START BUT DIED AS SOON AS USED UP GAS. TRIED SEVERAL TIMES. SAME THING. IT'S LIKE IT ISN'T...
You drained the fuel but sounds like you did not run fuel out of carb. the carb is probably just clogged either take off carb and clean thoroughly or just try to take off the screw on the float bowl and clean it there are little holes on it that are most likely plugged up. Good Luck...
Apr 02, 2011 | Craftsman 208 cc 12" Dual Rotating Rear...
We have a rototiller, craftsman, bought new at sears several years ago. Model No. 944627591, Craftsman 9 HP, 21 inch tine width, rear tine tiller with counter rotting tines. Pinion input gear is sheared...
The model ID starting in 944 indicates your tiller was manufactured by Husqvarna. This division has since been purchased by AYP. A quick online search finds that www.needlawnmowerparts.com lists having one for $55 plus shipping. I have not dealt with this company, so I can't recommend or not recommend them.
It is very common for tiller makers to not offer internal transmission parts. Transmissions are difficult at best to repair and reassemble. Used tillers are available from time to time, check your local classified ads or www.craigslist.com to find one. If you decide to go with a new tiller, i would recommend trying www.northerntools.com or www.mytsc.com to start your search.
As far as longevity on the new transmission, Sears won't guarantee any of their parts longer than 1 year. However, you should expect a replacement part to last as long as the first one did.
Sears doesn't give year models for their equipment, but usually supports replacement parts for at least 10 years. Most equipment manufacturers don't build their units to last longer than 10 years....they want you to buy another one.
I hopethis has helped.
Jan 04, 2011 | Garden
Troy Bilt Rear tine tiller model 643 Bronco, won't start,it ran out of gas, put in new gas and it started but wouldn't stay running. Put in new spark plugs, cleaned filters, changed out gas,still won't...
did it run out of gas when you added gas it could be that the fuel line has plugged up with something from the bottom of the tank take the fuel line off and try blowing threw it and take a air hose and blow out the carb and carb cleaner
Jun 05, 2010 | Troy-Bilt Pony Garden Tiller
Can't start my Troy Built Tuffy tiller. I haven't used it for a year, but it started fine last season. I replaced the spark plug, changed the oil and air filter and filled it with fresh gas. When I pull...
First pull your spark plug out reconnect to the plug wire and ground tot he engine body
Pull the starter cord and see if you have a good clean spark that goes to the electrode and not to the side of the spark plug.
If no spark check your off/on switch
Mar 31, 2010 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
Ran fine now it seems like the engine is seized , only two years old the gas and oil mixture was fine it is a ryobi 60511b
take out plug and try to turn tines by hand and check the tines for free movement if free try to pull start it if still seized spray cylinder with penetrating oil and let sit if still wont turn over possible internal breakage-crank/piston rod
Mar 14, 2010 | Ryobi Cultivator
Craftsman model 917293310 rear tine tiller won't come out of '' F
you need to soak the shaft running through the case with a good penetrating oil probably. they rust up and seize
Apr 27, 2009 | Garden
I have a bolens rear tine tiller that will not run. The carborator has been completely cleaned, new gas, new spark plug, new oil, and new gaskets. It seems like it is not getting gas from the tank. Will...
is the fuel filter clogged? you may need to check the engine compression for bad valves or rings.if the compresion is off it wont get gas . check the fuel filter first though and keep me posted.
Apr 23, 2009 | Mtd Products Yard Machines 158CC Tiller
Tiller won't start.
I recently had the same issue with a tiller that hadn't been started in over 8 years. Turns out that old gas had left a varnish coating in the carburator keeping the gas from feeding. Rebuilt the carburator with new float, needle valves and bowl, new Welsh plug. Fresh gas and two pulls later it went to churning. Took a short time to adjust the two needle valves for idle and full throttle and we went a-tilling.
Apr 04, 2009 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
Older model earthquake rear tine tiller won't start
try replacing the spark plug and spraying a shot of starting fluid into the cylinder via the spark plug hole
Sep 30, 2008 | Ardisam Garden
Garden Logo
189 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
