Question about Hitachi 12" Compound Miter Saw with Laser Marker - C12FCH
Does Hitachi C12FCH cut Aluminium? - Hitachi 12" Compound Miter Saw with Laser Marker - C12FCH
    Novelist:
  • 157 Answers
Hello. A muli-answer for this I'm afraid. The quick answer is yes depending.
Depending On:
  • Thickness of material
  • type of blade
If you are simply wanting to cut aluminum siding/soffit, then install a paneling blade backwards and chop down slowly
If you are referring to bar stock, you will - but not well. You will need a special quick-cut abrasive blade, and you may find you need to change the blades often.
If you wish to cut screen door trim, curtain rod, draft stop, Jolie Edging for ceramic tile, or other thin hollow/extruded materials - then the abrasive blade will do nicely for short/small jobs.
The main problem with cutting aluminum in a high speed rotary device is that the friction of the blade heats the metal fast enough that you get a coating on/in the blade. (In layman's terms - bunged up) The devices in machine shops are set considerably slower, and are usually cooled mainly with liquid.
Hope this answers your question satisfactorily. Good Luck and don't forget to rate this answer.
Thank You,
Richard
Posted on Mar 20, 2011
Which site is the best site for ACP aluminium composite panels?
There are many websites for ACP aluminium composite panels. Among them, Deltyn is the best site for ACP aluminium composite panels. Because this site is the good provider for ACP aluminium composite panels. Deltyn Aluminium Composite Panel Manufactures Suppliers ACP Cladding ACP...
Apr 06, 2016 | Building Materials
Tip
Stop crushing aluminium pipes.
Prevent crushing or distorting aluminium or thin wall pipe when clamping or using a vice, guide some pipe offcut, sockets or even large flat washers inside pipe to be cut etc. Place cut as close to inner support as possible.27e45d8.jpgc31a74c.jpg
on Apr 23, 2010 | Motorcycles
How to replace carbon brushes for Hitachi C7U2
brushes can get jammed in the holders if not used for a while. If you can not pull them out then you will have to cut the wire in the middle of the spring, remove the main body from the aluminium casing and push them through. Then replace them with a new set after cleaning the holders so the new ones slide in and out smoothly.
Feb 12, 2014 | Hitachi C7u2 190Mm 110V Circular Saw
New hitachi miter saw can't loosen the clamp lever
Any answer to this question? We are having the same issue.im sure it's something I'm not realizing but need to get this thing unstuck
Apr 14, 2013 | Hitachi 12" Compound Miter Saw with Laser...
The laser marker quit working - which parts to buy?
Hello. The C12FCH laser unit is housed in the base of the saw housing and has a part No. 323-647. Just a quick check though, are you sure it's the laser module itself and not the laser switch? And have you checked that the lens is free of obstruction? Here's a link to the parts list (blown up, not in fine print like in the manual): http://www.hitachipowertools.ca/upload/fmproduct_filec/C12FCH_BD_6745.pdf
Hope this helps, don't forget to rate us for assistance.
Thank You.
Richard
Mar 20, 2011 | Hitachi 12" Compound Miter Saw with Laser...
12" Compound Miter Saw with Laser Marker - C12FCH: Electronics including the laser marker do not func...
Some lasers work off batteries. If yours does, you might want to change the battery/batteries.
May 17, 2010 | Hitachi 12" Compound Miter Saw with Laser...
Saw quick working suddenly, maybe blown fuse
Your saw will have a reset button that may be black in color but should not have a fuse
With the power off push down in the reset button you may or may not hear a small "click" plug it back in a give it a try
Pushing them to hard will cause an overload and they will quit
give it 5 minutes to cool of and resetting should do it
Mar 08, 2010 | Hitachi 12" Compound Miter Saw with Laser...
When i cut my tv on it cuts off i have an hitachi 42 inch
TVs don't like being cut. It breaks them.
If you meant to say "when I turn on my TV, it turns on for a second then turns off", call Hitachi.
Oct 12, 2009 | Dell W1900 19 in. HD-Ready LCD Television
Hitachi 12" Compound Miter Saw with Laser Marker - C12FCH Logo
102 people viewed this question
Top Hitachi Saws Experts
John Trevino
JOHN LAPIER
Are you a Hitachi Saw Expert? Answer questions, earn points and help others
