The clothes are dry except for a few wet drip spots on the clothes when I remove them from the dryer. Where is this water coming from? I have a Thor washer/dryer unit.
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Please check that the filter or exit spigot are not clogged, the path between the tub and the pressure sensor which senses the water level in the tub is not clogged. As it can result in water level being incorrectly detected (may read as too high or too low) for the stage of programme that is executing, which can result in a halt of the programme. Please also check if some small clothing got stuck between the tanks, bad transmission, bad thrust bearing or brake hanging. If still the issue persists, then there should be air for passage in the standpipe on the back of the washer. Please check that the hose should be fitted airtight into the standpipe. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on May 27, 2010
Nosound from earphones onGalaxzy 4 tablot
what did you clean them with ? water?, bad move. you should only clean your electronics with acceptable electronic cleaning solutions,
or Rubbing Alcohol on a lint free wipe very lightly saturated then swing the cloth around in the air for a few second to make sure its not dripping wet, but very lightly damp. then make sure all units are off with no current flowing through. also make sure that you DO NOT turn them on straight after let them dry completely. ( when applied to items should see a streaking not an overall wetness.(if overall wet, you've used to much) drying time is based on wetness.) Use hair dryer if necessary.
Good Luck, try the dryer on the headphones. including the tablet plug in area. you might have gotten water in it.too!
Dec 07, 2014 | Samsung Galaxy Tab 2 Nd Generation 7 8gb...
My hot point Aquarius 1200 washer dryer WD62 won't dry my clothes. What program do I use to dry my clothes. Fed up with having dripping wet clothes come out.
It sounds like you have a failed moisture sensor. But first be sure all the vents are clear and open. If you have the white flex have it removed, it plugs up quickly. Use a flexible metal vent tubing.
Dec 04, 2014 | Washing Machines
What's the best way to clean a tv screen
Mild soap and water with a microfiber cloth with TV off. Then I wipe only water on the cloth to remove any residue then quickly dry with a dry microfiber cloth.
Sep 06, 2014 | Televison & Video
I have a Semi Automatic Whirlpool Sparkle washing machine my question is can i put water in the dryer just to remove soap from the clothes
Whether your dryer is electric or gas, DON'T PUT WATER IN THE DRYER!!! If you need to get more soap out of the laundry, run it through another cycle without soap.
Jul 27, 2014 | Whirlpool Washing Machines
Water under and around dryer. Clothes dry but water on floor. The wash not leaking. I the vent and line are not clogged. What is causing the water under dry?
Unless the clothes are dripping, soaking, wet when they're put in the dryer (and it would take them a loooong time to dry if that were the case) there's bound to be a leak of some kind coming from somewhere other than the dryer. Do you have a lavatory or toilet on the other side of the wall behind the dryer? They dryer has no water of its own to leak.
Dec 27, 2011 | GE DBXR463EDWW Electric Dryer
There is water coming out from under the dryer. I have checked and there is nothing wrong with the washer.
Check and insure the vent is clear. A clogged vent will prevent mositure from leaving dryer, as this moisture builds it will pool at the low spot or appear to be leaking from the dryer. A second possibility which I am sure you have already checked is that the clothes are not being thoroughly rung out in the wash cycle. If they are dripping wet when placed in the dryer, access mosture could leak out as well.
Mar 02, 2011 | Kenmore Dryers
My dryer is warm inside and there ia good airflow out the vent and the dryer has been taken apart and "de-linted' how come it is still dripping water from the door and it takes a long time to dry?
I hate to say this but I would look at your washer to see if the "spin cycle" is working, the clothes are way to wet to be in a dryer (electric or gas.) If your washer is working correctly the clothes should be barely damp when the spin cycle is complete. Please check that first! Good Luck!
Douglas
Jan 28, 2011 | Dryers
I have a GE dryer that won't dry our clothes. It heats up, but water is all over the inside door and the lint that comes out of the hose in the back is wet! The outside of the dryer (the top in...
It really sounds like your washing machine is not spinning the clothes out enough. Have they been wetter than usual lately? The dryer could just be struggling to keep up with the heavier / wetter load as there is no reason for it to create moisture on it's own.
Oct 06, 2010 | GE Dryers
Dryer model # RES7648JQO Serial # MK2707517 I put up a load of clothes to dry and when the cycle is done the clothes are still wet and there is water on the door inside the dryer. I've tried adding a...
it sounds like an airflow problem. check everywhere the air flows. inside the lint catch. the vent behind the dryer may be clogged or kinked. the exhaust line in the floor or wall of the house might be clogged. 689b12c.jpg
Aug 01, 2008 | Roper Dryers
Washer/Dryer not drying
is your dryer a conderser type
does it have a tank that you have to empty at the end of cycles
if it does the filter that condensers the water from drying cycle
if that is blocked it will not work
Jan 25, 2008 | Equator EZ 3710 Front Load Washer / Dryer
Washing Machines Logo
29 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
