Question about Toshiba IK-WB21A Network Camera
Camera not working, power to it is good
Toshiba IK-WB21A camera not working, power to it is good at 12 volts. Is there anywhere to order replacements from e.g power board assembly?
  • Toshiba Master
  • 2,404 Answers
Toshiba doesn't make parts available for that camera. If you want you can call them to be sure but I haven't found anything online as of yet: 1-877-696-3822
Posted on May 27, 2010
I have a 2005 jayco feather light with 12 volt issues I exsperiance a power spike fried the convertorreplaced it now I have shore power 12 volt power but my AC furnace and fridge are not working
The furnace and fridge both have control boards that may have problems. First check both circuit boards for built in fuses. Hopefully this is the only thing gone Replace the fuse and you should be good to go.
Aug 29, 2017 | RVs
Where can i get a cctv camera powerboard (it fits inside the camera)
Ebay or any competent electronics retailer or spares facility.
Dec 28, 2016 | Cameras
On my WS-55511 TV, after a power interruption, will not power up. All i get is a continuos blinking green light.I tried unpluging the tv several times, no luck.
Good Day,
LED does not stop blinking after plug in. Check for 12 volts at connect or PF pin 10 and 28 volts at connector PF pin 11, (on the board on the right hand side, but on the left side of board towards the back of TV). If the supplies are correct suspect a problem in the DM Assembly (part # 955C230002). Part is not available for replacement.
Check C9B01, C9B02, C9B03, C9B13, C9B14, C9B17 and C9B18 (1000 UFD, 16V, 105C) on the DM Power PCB located within the DM Assembly. If they are bad or not, replace them all with part # 181P734030 (680 UFD, 16V, 105C).
The DM (Digital Module) Assembly is located on the extreme left of the chassis from the back. It is standing in a vertical position. Remove cover and you see the Cap’s in one corner of the inside PCB.
Good Luck, Big IRISH.
Dec 14, 2009 | Mitsubishi WS-55511 55" Rear Projection...
I have a 2000 towne and country with a bad passenger side window. My husband tried replacing the motor but the window still wont work. what else could the problem be? The driver side window works fine. We...
I'm assuming you checked all the fuses -- they should be good, but in some cases, the right and left side windows may be on separate fuses.
The best procedure to find this problem is to start at the motor and work your way back to the power source (fuse box) testing each component to see if it is getting voltage.
If you fail to get 12 volts at either of these steps then the component leading to the one which failed to show 12 volts is bad.
First step is to test, with a multimeter, the motor leads for 12 volts when the window switch is engaged.
If you get 12 volts, there, then you should test the coil side of the window motor relay for 12 volts under same conditions.
If you get 12 volts there, test the window switch leads for 12 volts on both sides of the switch. You can also use the multimeter to test the window switch for continuity to see if it is passing current. If it fails the continuity test, replace the switch.
If you get 12 volts there, let me know and we'll take the next step.
I know this is complicated, but electrical troubleshooting is not simple.
More info, let me know.
Charlie
Aug 23, 2009 | Chrysler Town and Country Cars & Trucks
How do I use the web camera without skype?
How does a webcam work?
There are two different ways to use a webcam at home — through e-mail and with instant messaging programs.
E-mail your video files
To use a webcam with e-mail, first launch the software that comes with the camera. Depending on the model, the process of e-mailing and recording your video messages may vary. Press Start or Record to begin the video message. Click Stop and then preview the video. You can then click E-mail or Send, which will automatically open your default e-mail program (Outlook 2007).
When sending a video e-mail, the longer the video message recorded, the bigger the attachment will be, so make sure the recipient’s computer can handle the size. The recipient of the e-mail does not need special software to see your video message; he or she simply chooses to open the attachment and the mini-movie will play.
Aug 13, 2009 | Toshiba IK-WB21A Network Camera
How big of an SD card can I install in my 1K WB21A webcam?
You can use up to a 2 gb card. That is the largest that can be formatted in fat 16.
Apr 20, 2009 | Toshiba IK-WB21A Network Camera
Hisense TL2020 LCD TV
You should check the 12 volts capacitors on your power supply for dry or leaky, bulging conditions.
Replacing those capacitors will restore the functionality of your TV.
May 15, 2008 | Televison & Video
IK-WB21A & ISA server 2004
you have to creat role that allow all traffic (inbound) from the camera ip>>>> to the selected users
Dec 24, 2007 | Toshiba IK-WB21A Network Camera
Toshiba MD20FP3 not turning on
Is a good thing the main fuse is not open,your problem is in the power supply ,as I understand you have no indication of power(no lights,No clicks)The 5 volts that power the microprocessor might be missing,this 5 volts usually come from a regulator,this regulator should have 12 volts in one side and the 5 volts in the other,the 12 volts come from the secondary of a transformer and it has its own fusible resistor,if the resistor is open is because the regulator is shorted and it need to be replaced.This is a good place to check.Be careful when checking this parts.If you are not too familiar with tv service seek the assistance of a servicer,it should not be too expensive.
Oct 03, 2006 | Toshiba MD20FP3 Combo
Toshiba IK-WB21A Network Camera Logo
171 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
