Question about Kyocera Mita KM-1815 All-In-One Laser Printer
Unable to copy with my Kyocera KM-1815. Error code is C3200.
I have a Kyocera KM-1815 machine. Most of the time I'm not able to use the copier. Sometimes if it is powered off then back on, it works for a short time. - The error code displayed is C3200.
  • 241 Answers
Typicaly the scanner optics would need to be cleaned. Or it could be a scan lamp failure. A Kyocera dealer could help you with this.
Posted on Jun 09, 2010
Not scanning...error code 720f
Software trouble error code
720f Error: Unknown error
Causes:
Unable to determine the
cause.
Check procedures/corrective measures:
Turn the main power switch off and on.
Jan 14, 2011 | Kyocera Km-3060 Mfp Copier Copy Machine...
Could you tell me how can i enter the simulation mode for the kyocera 1815 copier.
I would suggest you check the manual of the kyocera 1815 copier. this should be stated clearly on the user manual. so check the user manual for the information as regards this.
Take care.
Jul 14, 2010 | Kyocera Office Equipment & Supplies
Kyocera c3200 error Problem
A C3200 is as follows:
Exposure Lamp Problem.
• In indicator check before starting copying, the average value in scanning of the shading plate with the CCD is 128 or more.
Solution:
Defective scanner board (KP-5063).
Replace the scanner board (KP-5063) and check for correct operation
Defective exposure lamp or inverter board.
Replace the exposure lamp or inverter board.
Incorrect shading position.
Adjust the position of the contact glass (shading plate). If the problem still occurs, replace the scanner home position sensor.
Poor contact of the connector terminals.
Check the connection of connector YC7 on the scanner board (KP-5063), and the continuity across the connector terminals. Repair or replace if necessary.
These are direct from the Tech man.
More than likely it is the Exposure Lamp.
Hope this helps.
May 02, 2010 | Kyocera Mita KM-1815 All-In-One Laser...
C6000 on Kyocera KM-3050
you can try to reset the error code by going into
simulation mode
at the machine punch in 10871087
once in simulation mode.. go to sim 163
that's a fuser reset
execute that..
if problem persists you need to replace fuser
Mar 10, 2010 | Kyocera Mita KM-1815 All-In-One Laser...
How to fix Error code C6020
I have The Km C2520 with the same C6020 code. Is the solution the same?
Jan 26, 2010 | Kyocera Mita KM-1815 All-In-One Laser...
Kyocera mita error codes of KM 1500
Hello sir; The error code you display A3200 is not available in our menual, we do have C3200 , if that's correct, it means exposure lamp burn out ( not on), replace it, or thermos fuse out.
May 13, 2009 | Kyocera KM-1505 Copier
Kyocera mita km-1820 not printing clear copies
you have to check the duplex unit on the machine itself.
May 01, 2009 | Kyocera Mita KM-1815 All-In-One Laser...
Scan error C3200
remove the flat wire in the scanner, then remove the railings from the scanner, clean the railings with a soft cloth, if you encounter the c3200 error it only means that the railings of the scanner is dirty, the scanner cannot move. i hope this will fix your problem..... if you have anymore questions regarding kyocera copiers dont hesitate to txt me or call me to this number +639081953003 or +639079941995
Feb 27, 2008 | Kyocera Mita KM-1815 All-In-One Laser...
Service Manual for KM-1815 Kyocera Copier
all km manuals are available from New Jersey Copy
contact tony@newjerseycopy for all mita service and op mans
Nov 01, 2007 | Office Equipment & Supplies
ID Code for KM-3035
i want to change the id code for km 3035 kyocera how to chang
Jul 30, 2007 | Kyocera Mita KM-3035 All-In-One Laser...
Kyocera Mita KM-1815 All-In-One Laser Printer Logo
1,444 people viewed this question
Top Kyocera Mita Office Equipment & Supplies Experts
Kyocera HP Expert
Henry Gertcher
Adorjani Laszlo
Are you a Kyocera Mita Office Equipment and Supply Expert? Answer questions, earn points and help others
