Question about HP (D7580-60003) Motherboard
I need memory for hp-compaq dc7100 but i need to know whether high or low density chip is needed
  • HP Master
  • 2,404 Answers
This is the specs for your motherboard:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00783614&tmp_task=prodinfoCategory&lc=en&dlc=en&cc=us&product=3262274&lang=en
Posted on May 27, 2010
Not supporting ram of 2gb DDR3 in acer motherboard N15235
You first need to ensure you have memory that is compatible with the motherboard. If you have high density memory instead of low density that could be the problem because a limited number of motherboards recognise high density memory.
I suggest you check with the motherboard manual.
If you are certain you have compatible memory I suggest you clean the terminals of the chips and blow any dust from the receptacles and work the chips in and out of the receptacles several times, taking suitable precautions against static discharge at all times.
With the chips removed switch on the computer, wait for the beeps and then switch off and refit the chips.
If all is well the computer should recognise the memory and boot as normal.
Feb 26, 2015 | Acer Computers & Internet
LOOKING FOR HP COMPAQ DC7100 SPF Ethernet Controller
Go to this website:
HP Compaq dc7100 Minitower Drivers
Select your operating system.
You will then get a list of driver options. You will need to know what network interface you have to select the correct one.
Thanks for using Fixya.
Nov 12, 2010 | Compaq dc7100 Minitower PC Desktop
Hi. I need to purchase a DVD burner for my Compaq dc7100 and need to know what brands will fit my computer. Thanks, **** P
I've checked on the specs of dc7100, and it shows that it has multibay optional for 12.7mm removable drives .
I've difficulties finding the exact DVD compatible for dc7100 since it seems that it's already been discontinued.
However, these are the closest match that I've found. Kindly click to double check the specification if it matches your computer:
HP Multibay DVD+RW Drive
HP Slim 8x SATA supermulti LightScribe Drive
Oct 29, 2009 | HP Compaq dc7100 Ultra-slim PC Desktop
How do I determine what kind of memory that I need?
Go to Crucial.com and install their configuration utility through your browser. They will tell you what you have and all the combinations you can do to max out your system. Look at the specs of the RAM and you can get it from Crucial or some other vendor.
Dec 30, 2008 | Computers & Internet
My laptop has 256K memory installed. I purchased 512 RAM (max I can add is 1024) and installed it in my hp Pavilion zt1230 laptop. Per Kahlon.com instructions, I cleaned gold leads with eraser and popped...
Is it a High Density memory? There are two different types of memory, High and Low. Low density is the universal but High density, may be cheaper but the motherboard needs to be compatible with High density memory. Although your memory fits in the slot, I think you have High density memory hence why it won't boot up and does when you remove the memory.
Dec 06, 2008 | Computers & Internet
Few questions about RAM memory?
Solution:
i)  LOW DENSITY modules have 100% compatiility with ALL systems and ALL chipsets.
    HIGH DENSITY modules only have 10% compatibility
    here compatablity means LOW DENSITY RAM are accepted by all system(100%)  or any make           system.. HIGH DENSITY RAM are accepted by 10% by only some system or computers...
ii) in order to check system performance or amount of Computer RAM usage press the ctrl+alt+del
   simultaneously a new window(window task manager) will appear showing:
    CPU usage: showing the amount of CPU or processor utilized at that particular time.
    PF usage: showing the amount of RAM memory utilized at that particular time.
    Physical Memory: showing Total RAM Memory, Available Ram memory....
iii) baiscally they are two types of RAM they are:
    DDR1:which is older one supported by older system  or older mother boards which is costlier
    DDR2: which is latest one supported by all new system or new mother boards which is less                         costlier
    DDR: double data rated ram......which will send data at a double rate compared to SD RAM
iii) here color doesnt matter, these slots either support DDR1 or DDR2 but not both at a time
    DDR1 has 184 pins or gold plated pinssss... on the edge of the RAM
    DDR2 has 240 pins
    so difference doesnot allow DDR2 to placed in DDR1 motherboards or vice versa...
iv) it does have anything to do with no of chips on the RAM but they only differ whether it is DDR1 OR DDR 2(DDR2 are much faster than DDR1)
NOTE: whatever may the the RAM, each RAM has FSB(called Frequency...) which determines the frequency of rate at which data is tranferred from RAM to processor(CPU)  usually in MHZ such as FSB 300, 400, 200 , 333...................
more the FSB the faster data is transferred to the processor(CPU)
dont worry even RAM with less FSB's work well with the processor....having 1 GB RAM or 2 GB RAM is engouh, it only matters with the speed of CPU ... but not RAM......
Sep 24, 2008 | Compaq Presario SR1120NX 2.66GHZ Tower w/...
Memory Stick Installation
So it seems you got the DDR / DDR2 side of the equation correct, but unknown to most, there is 'low' and 'high' density memory.
The density of memory refers to the number of chips used to make the total amount of memory that your memory stick contains. e.g. High density memory has few, large capacity chips to make up the 1024MB of memory on the stick, whereas low density memory uses many, small capacity chips to make up the same 1024MB total on the stick.
Typically, if it is a low / high density conflict, it is the 'low density' sticks only that will boot.
Me, I purchase Kingston memory when I'm unsure what the motherboard will be, and it has never failed to work.
I fix computers.
May 19, 2008 | EliteGroup PM800M2 Motherboard
Emachine w3118 memory
while the reason you want to know density might help to answer, if you are buying memory you only need to know it will work in your machine
when I bought memory for my computer I googled brand and model number with the word "memory" and found a seller that had a little tool I down loaded and ran to tell me what memory was needed
memory is very cheap now days so price compare before you buy
Feb 25, 2008 | E-Machines eMachines Desktop PC
High density memory
need low densisty on ebay 35 buck eash 1 gb ok works on picky mobos way better
Feb 07, 2008 | Dell (E210882) Motherboard
HP (D7580-60003) Motherboard Logo
231 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
