Question about Powermatic 66 10" 3 HP 1 Phase 230V Table Saw w/ 30" Accu-Fence & Rout-R-Lift 1660806K
I am trying to find out how old my powermatic 66 table saw is. serial no is 97661400
On the Powermatic 66's the first two numbers are the year in which it was made, so yours was made in 1997. The second set of two numbers is the model. The last numbers I"m unsure of but its my understanding that they represent the manufactured number, so yours was the 1,400th saw made for that year.
Posted on Aug 12, 2011
Powermatic manuals
L Luke, closest I could find is May 1983.
http://vintagemachinery.org/pubs/655/6140.pdf
Aug 22, 2014 | Powermatic Saws
Powermatic 66 wiring problem
Simple solution: switch two of the wires. Doing so will reverse the direction of the motor. You can switch it at the motor or on the electrical plug end.
Mar 28, 2013 | Powermatic 66 10" 3 HP 1 Phase 230V Table...
Truing the fence on a Powermatic 66 table saw
There should be some screws on the bottom side of the fence that allow you to make adjustments. Loosen then slightly then set the fence to 90 degrees & then tighten them.
Dec 27, 2017 | Powermatic 1791227K Model 64 10" Artisan...
I have a powermatic 66 table saw. I removed the motor, to move the saw. when i reinstalled the motor, the blade has moved 5/16'' towards the fence.
Check to make sure the arbor set screw is not loose. The bearings may have shifted when you moved it. I recently rebuilt an old 66. Repositioning the bearings and tightening the set screw could be all it needs.
Sep 27, 2011 | Powermatic 66 10" 3 HP 1 Phase 230V Table...
My Powermatic 66 tablesaw has a 3 phase 230 Vac motor on it but I cannot tell if it is a 3 hp or 5 hp. All the tags are gone from the motor. Is there any way to tell from the serial number? 8666-1008.
There will be a tag on the motor that will give the specs. Sometimes they are hard to see from the underside and its not easy to remove the top see them. Try lowering the motor (with blade removed) all the way and use a digital camera to reach up into the cabinet and photoqraph the top of the motor. I had to take several since your shooting blind to get a picture of mine.
Nov 09, 2010 | Powermatic 1660802K Model 66 Special...
I have recently purchased used powermatic 66 Table
That is the current setting for a motor-starter which is an overcurrent sensor. This is a circuit breaker like device that usually has a heater coil that opens a contact which cuts the power to the relay that powers the motor to prevent overload damage to the motor.
The dial is in AMPS and should be set just slightly higher than the nameplate amp rating for the motor.
Oct 24, 2009 | Powermatic 66 10" 3 HP 1 Phase 230V Table...
Vibration in powermatic model 66
No. Unplug saw remove saw blade grasp shaft that saw blade was on wiggle back and forth. Should not be too much play. After 10 years motor bearings are proably worn. Easy to replace
Aug 07, 2009 | Powermatic 1660802K Model 66 Special...
My Powermatic 66 table saw won't start. Tried to turn on my Powermatic 66 table saw this morning. Blade moved one half inch as if trying to start. Tried reset button on motor, still nothing.  I...
Your saw motor is equipped with a two speed internal start switch. Over time saw dust will get into the contacts and cause the points to burn. You can pull the end off of the motor and take some 400 grit sandpaper to the contacts to clean them( there are two sets of contacts one works in the out position the other in the in position) it will be the set in the in position that is the problem. Gentle clean them, reassemble the motor end cap and it will work fine. I have to do this about once a year to my saws. I use my saws about 25 hours a week. I have been doing this to one of my Powermatic saws for 31 yrs. now.
Jun 08, 2009 | Powermatic 66 10" 3 HP 1 Phase 230V Table...
Powermatic 66 10" 3 HP 1 Phase 230V Table Saw w/ 30" Accu-Fence & Rout-R-Lift 1660806K Logo
1,081 people viewed this question
Top Powermatic Saws Experts
80stech
Dennis Key
Dennis Key
Ivan
Ivan
Level 1 Expert
Are you a Powermatic Saw Expert? Answer questions, earn points and help others
