Question about Cooper Lighting Lighted Switch
My upstair room light is stop working. Changed bulb, switch and bulb holder. But still no luck. What else I should do before call the an electrician. - Mahen
  • Mahen2 May 30, 2010
    Jim, Sorry about the late reply. I had problem with my internet.Its been sorted now. Your information was really helpful. Like you said, I checked both hanging wire from celing. No voltage to my tester. But voltage is on switch wire. Also checked all other wires on celing in that room. No voltage. Now where do I go from here? - Mahen
    I am bit confused. do you have an email I want to send the circuit. Basically power is coming to swith. and power is coming to celing rose red wires when switch is on. There are three black wires and three red wires coming to celing rose from celing.I am bit confused with the wires connection from celing rose to bulb holder. Let me send the diagram first please
    Novelist:
  • 101 Answers
Hi there,  Have you checked to see if you have power getting to your switch? You could've tripped a circuit breaker, so I would check your electrical first to rule that out. Once you've checked for power, put your switch in the OFF position. Next, take off the light from the ceiling...leaving just the two wire's hanging down and apart from each other. If you have a voltage tester/meter, then you'd want to turn the switch ON again - then check to see if you're getting power (voltage), as well as, a complete circuit. If so, great! If not, contact me again and I'll help you further. But I believe you'll have found the problem already after following the above steps. Make sure to secure each connection when putting your light back up onto the ceiling. And, DON'T turn the switch back on until your light is securely mounted. Good Luck with this, and feel free to contact me again if this doesn't work. - Jim
Posted on May 27, 2010
  • Jim May 30, 2010
    Hi Mahen2,
    That's okay, I'm glad I'm able to help. Now, the good news here is that there's voltage to the wire when the switch is on. Meaning, you most likely don't have a power problem. That wire is called the switch leg. The other wire's the neutral wire. This wire (neutral) goes directly to the white (neutral) wire , or silver screw terminal on the fixture. But, before you begin working on this, please turn OFF your switch - and if possible, the circuit breaker too. I just feel better knowing your safe. Next, take the switch leg wire from the ceiling and connect (splice) this to the other wire, or brass/colored screw terminal on the fixture. Secure all your connections, put your new light bulb in, and then you can turn your switch back ON to see if everything's working. Now, if it isn't...you probably lost a neutral wire somewhere. Meaning? There's a loose or broken neutral wire somewhere, but we'll deal with that after you do this first. Also, you mentioned some other wire's in that ceiling that don't work? Did you turn on that switch and checked them too? Are there any other switches in your room? I'll tell you what, check out everything I've written here with you. If nothing works, then you can contact me on my cell phone at (408) 892-1030. Whatever will be easier for you, but this way I can ask and get the information needed, while you have everything apart. This can get more involved, so that's why I'm giving you my direct contact number. You might have to contact an electrician, and I can help you with that too. Well, let's stop here, cross our fingers - and hope what we have now, will work. Good Luck, and thank you very much for the 4-thumb rating. I greatly appreciate it!
Clio wiring diagram
one of the common probs is the hazard switch faulty it can stop one side or other working intermittant. when problem happens operate hazard switch a few times and check all 4 work ok. the bulb holders are also poor if its just the front change the relevant bulb holder the only other is the poss is one of the inline harness connectors under bonnet or fascia. good luck.
Sep 29, 2016 | 2005 Renault Clio 1.4
1998 renault laguna offside rear indicator suddenly stopped working have changed bulb and fuse? All other lights working! Any ideas would be greatly appreciated
bulb holder could be faulty.check for any rust in the bulb holder.
put another bulb make sure it fits nice n tight for good earth otherwise replace the holder.
Feb 05, 2014 | Cars & Trucks
I replaces my light switch in my room and the light still won't work?
check the fuse in the fuse box. failing that call in an electrician as there is a way to wire up a switch and you may have picked the wrong 2 terminals.
Dec 31, 2013 | Cars & Trucks
My upstairs lights are not all working
You have an intermittant connection. This can be anywhere in the circuit - including white neutrals. It can be hard to find because it is intermittant. You may have luck tapping on or around switches, fixtures and outlets to narrow down the location of the intermittant.
You checked the connections - or did you tighten the connections? There's a difference! Every building is subject to vibration. Over time, this vibration can cause connections and wirenuts to loosen. If the wires in the wirenuts were not pretwisted before the wirenut was placed - there may be some intemittant connections going on inside the wirenuts.
Check and TIGHTEN all connections - wirenuts, terminal screws, etc. This includes the neutral wires! Test lamps are really not very good test tools to use - that's why electricians don't use them. Your test lamp cant tell you if it is registering 50V, 120V or 240V. There is a huge difference as you can imagine. Do not overlook the outlets. it is not uncommon for an outlet to supply power not only to the next outlet - but to a nearby switch above it, too.
Get an inexpensive multimeter. It can provide you with more information that you'll ever need as a homeowner. That is much better than the questions a neon test lamp raises.
Jan 16, 2013 | Home
1994 mercury grand marquis. My emergency brake light will not stay on when the brake is on. The bulb has be checked and it is still go. I need this for it to pass inspection
Hello, These controls are very simple. You need to have the switch adjusted in the holder under the dash or more slack in the adjustment cable.
The way this works is the contact switch needs to extended far enough to activate the bulb. If the Emergency brake is too tight, the contact switch does not get enough room to extend. There is adjustment in the holder for this. What usually happens is the contact switch has extended for a worn system.
When new Emergency brakes are installed or the brake cable is adjusted, someone should have reset the Emergency brake holder. Now the Emergency brake switch does not have room to work. The cable does not move far enough to allow the plunger to move under the dash. You need to either adjust the holder or loosen the cable.
Jun 18, 2011 | 1994 Mercury Grand Marquis
How to replace bulb in front bumper turn signal housing 1995 jag xj6
hello,
  • Identify the blown bulb. Note that if a headlight bulb has blown, the dip beam is on the outside and the high beam is on the inside. Turn off the ignition switch and light switches.
  • Open the hood and replace any blown headlight bulbs. Press the plastic spring clips and remove the bulb holder from the assembly. Pull the bulb out of the bulb holder and replace it with a new bulb. It only fits one way. Be sure not to touch the bulb's glass. Replace any parking lights at the same time, they are in the headlamp unit too.
  • Remove the front turn signal light unit in the bumper to change the turn signal bulb. Push gently on the inside edge and insert a blade between the bumper and the lens at the outside edge. Compress the spring and remove the lens. Fit a new lamp by inserting it into the plug. The side marker light is changed using a similar process.
  • Open the trunk to replace the rear fog light, stop light, tail light, reversing light and turn signal light. Remove the rear light cover and turn the bulb holder fastener 90 degrees counter clockwise. Remove the expired bulb, fit a new one and replace the parts, turning the bulb holder clockwise.
  • Thanks..
    May 21, 2011 | 1995 Jaguar XJ6
    I have a 2000 dodge intrepid es 3.2 my brake lights stopped working, i changed the bulbs, and the brake pedal switch i checked the fuses? am i missing something?
    I had 1990 Dodge Shadow that had the brake lights go out too. The problem was the cheap way that the bulb holder was made. I had to solder a wire to the outside metal case for the lights to work. If you know a bit about batteries and voltages, check that the bulb contacts are getting voltage, and that the wires are in tact all the way to the bulb.
    Dec 18, 2009 | 2000 Dodge Intrepid
    My break light doesnt work and i have changed the
    check and see if you are getting power to the brake light from the bulb holder.If your not getting power there then change the brake light swich above the pedal.Good luck
    Nov 29, 2009 | 2000 Toyota Avalon
    I have a T5 and an orange coil light is flash on my dash and my brakelights have stopped working
    i have one of these and i dont remember seeing an orange coil light ,stops lights will be the switch no doubt so should be easy to replace,just join the wires on the switch together and see if stop lights work ,if not check for a feed if you have a feed then look at bulbs and bulb holders and earth to bulb holders.But this coil symbol?? has me intrigued tell me more
    Apr 11, 2009 | 1986 Volkswagen Wagon Camper
    Cooper Lighting Lighted Switch Logo
    208 people viewed this question
    Top Cooper Lighting Electrical Supplies Experts
    Craig Butler
    Craig Butler
    john h
    Gene Haynes
    Are you a Cooper Lighting Electrical Supply Expert? Answer questions, earn points and help others
