Back to:
Tags:
BenQ Projector Lamp for PB6100, PB620
Benq PB6200 projector lamp or other problem (by 2 users)
posted by kpsounis on Apr 07, 2008
I have had this projector for 3 years. Twice this last month it turned off on its own. (no bad lamp warning yet) Two days ago, the projector turned off again on its own and the red light indicating a bad lamp came on once for the first time. I turned off and on the power switch from the back of the unit. Now, when I turn the power switch on, instead of causing the power green light turn on on the console, and the bad-lamp red light turn on too (assuming the lamp is bad), nothing happens. (There is only a green flushing barely visible not on the leds but on the buttons of the console, as if a malfunction problem is happening.) How do I figure out if the lamp is bad (I removed the lamp and no black/smoky areas are visible) or there is something wrong with the unit. I see no point replacing the lamp on a broken unit, but I have read that sometimes units behave abnormally in the presence of a bad lamp, and replacing the lamp fixes the problem. Thanks!
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by Guest, posted on Sep 08, 2008
PB6200 fan running but no light. Three LEDs (power, temp, lamp) all off. Only way to stop fan is to turn off power switch or unplug. Any suggestions??
Best Solution
posted on Apr 10, 2008
Helpful (85)
Marrie
Rank:Wiz Wiz
Rating: 84%, 275 votes
Hi there
I replaced a Mainboard on a BenQ PB6210 just yesterday - had all the same symtoms.
No LED lights coming on but the rest of the buttons has light.
Tried every other component from the lamp to the colourwheel , but the Mainboard replacement fixed it in the end.
You'll be looking at about $95 for the part
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Benq PB6200 projector lamp or other problem:
I don't want to Accept this solution
Can you Help with these Multimedia Projector Replacement Lamps problems?
BenQ (200NSH-LAMP) Projector Lamp for...
could you help me - I bought the kodak 8mm film projector....
cnt figure out how to make the projector bulb to come on
I replaced the lamp and the lamp light still blinks and I...
I have a 60" phillips projection model number...
I have a BENQ model number PE7700 and I need assistance on...
Loading problems.
Repair Service
Find Multimedia Pro. Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
