Question about KitchenAid KESC307 Electric Kitchen Range
I have a KESC307HS8 and the display no longer works. I can use all the buttons on the control panel and they all work, oven will turn on, I can set the timer and it will work but nothing will show in the LCD displays for either clock or oven information
  • 1,284 Answers
Hi, thanks for the descriptive analysis of the problem you have with the KESC307 Electric Kitchen Range. All you need to do is to either replace the LCD display or you dismantle it to see if the flex connecting the control panel is still connected to it...
Take care
Posted on May 27, 2010
Jenn air svd46800 oven not working
Good Afternoon,
The control boards in your appliance may have failed. There is a display board, part number 71001799 and relay board part number 12001693. Commonly we see transformers on these relay boards fail with power surges. Luckily, we do test and repair these parts. Remanufacturing these controls will save you the high cost of buying new, and each rebuild will come with a 2 year warranty-- which is three times longer than new. Email me if you have any questions! info@fixyourboard.com
Jun 05, 2017 | Jenn-Air Ovens
My microwave keypad wont work the light is on and the reading says please touch clock and set time of dry
SEE THIS CAUSES AND FIX IT. God bless you
Touchpad and Control Panel If the microwave buttons don't work the touchpad and control panel assembly are probably defective.
Touchpad If the microwave buttons don't work the touchpad might be at fault. Generally speaking, if the display is working and some of the buttons respond correctly but some don't, the problem is with the touchpad.
ser Control and Display Board If the microwave buttons don't work the main control board is most likely defective and will need to be replaced.
Main Control Board If the microwave buttons don't work the main control board is most likely defective and will need to be replaced.
Oct 01, 2012 | Kenmore 80809 Microwave Oven
JJW8230DDB Jenn Air double oven. Black. Digital display. The only buttons working on the display are the Cancel buttons. Display still shows time, but I can not set the time (the clock button does not work...
When buttons are not working most of the time it is due to a short in the touch pad or the electronic control in a unit you would have to call for service if you did not know how to use a multimeter to perform ohms and continuity testing and measureing of both pieces. Usually though due to the button not working most of the time it is the touch pad though. If you have any further questions message me back Thanks again
Rick
Oct 16, 2011 | Jenn-Air JJW8230D Electric Double Oven
Double oven control panel just quit after power surge.
This is unfortunate.
The display is a computer you need to do most of the work.
Go Onlne to www.partselect.com and order that display. You will need a friend or a service guy to open and install you new display
Jul 26, 2010 | GE Profile JTP18 Electric Single Oven
The digital display no longer lights up. How do I
if your oven works correctly and the only thing that is wrong is that the digital display is blank you will have to replace the control board remove the two screws on the side rails lower remove them set them aside remove the two screws in the side of the of the control panel pull up on it and lean it down take the screws out of the control board and disconnect the wires one at a time and put them one at a time on the new control board reassemble the unit that will complete the replacement
Apr 04, 2010 | Whirlpool GBD277PD Electric Double Oven
My oven is giving me an error of E6 F2, what does that mean
Equipment is Whirlpool double oven RBD305PDS14 built-in. After a very stormy summer 2007, I thought a power surge may have zapped the control board. Problem initially presented on display as error & fault "E6 F2"; simply pressing "Timer Off" would usually clear this error & fault code.
However, some months later, the display would often go completely blank followed by the beep sequence "short-long-short-short-short" (Morse code: dit dah dit dit dit). No error & fault code would appear. Pressing any keypad oven control did not work at all in this condition. When power was cycled at the breaker panel, the usual "PF" with clock display did not appear.
[TURN OVEN POWER OFF AT BREAKER!!!]
After following the excellent information on "how to remove the control panel" posted in this forum, I first tested the "control panel thermal fuse" (refer to the tech sheet that should be behind the control panel once it is removed). It showed a closed circuit.
I turned my attention to the "flexible" keypad connector cable (error & fault code "E6 F2" is a keypad or keypad connector problem; again, refer to tech sheet). The control panel has a board mounted female connector with two tabs that may be gently pulled upward to release the flexible cable.
I cleaned the flexible cable contact area (it seats into the board mounted female connector) carefully with a Q tip and some isopropyl alcohol. I reinserted the flexible cable and gently pressed down on the two tabs (noted above) on the board mounted female connector. VERY GENTLY tug on the flexible cable to insure it is gripped by the connector.
After all of this monkey business, I re-mounted the control panel display panel on the oven and restored power. So far, so good. After applying power, the "PF" with clock display always appears. I am able to set the clock and press "Start". Over functions normally. The clock displays as normal and I no longer observe the problem I described above.
BTW, I noted the incoming 240V has transient suppression (no surge protection, however
RATE THIS SOLUTION
RNJ VINOD KUMAR
Sep 19, 2009 | Whirlpool Ovens
F1 code on display pad
That error means the main control board has a internal failure. The board will have to replaced to fix that issue. If you need detailed repair help with that visit the link below:
Appliance Repair Help With Live Chat
Mar 23, 2017 | Amana AOGD2750 Gas Double Oven
Time display
if the-at doesn't work sounds like you inadvertently turned of the display for clock try holding the clock button for 3-5 secs itll beep and remain on then
Mar 09, 2008 | KitchenAid KEBC247 Electric Double Oven
GE Profile JGB97 Self Cleaning Oven Controls won't work
You have a problem that may be solved with my solution to the Dreaded F7 Problem. Even though you don't have a F7 error on the display the symptoms are all the same. You can find my fix at the following links.
http://www.fixya.com/howto/h155060-dreaded_f7_error
I have shared this with more than 1550 folks and most report success. This problem often develops after a self clean cycle.
I hope it works for you too. Please let me know at the following:
hutchipop@yahoo.com
Good Luck,
Charlie Popeck,P.E.
Consulting Engineer
Feb 06, 2008 | Ovens
Display is black
I had a very similar problem (I was observing the error & fault code "E6 F2", but not always.  I did always have the beeps.) on a Whirlpool RBD305PDS14 double oven built-in.  I spent time today (Oct. 21) and traced the problem down to the keypad flexible cable that connects the keypad to the oven control panel.
[ALWAYS WORK WITH POWER OFF!!!]
I cleaned the flexible cable contacts that seat into the board mounted female connector on the control panel board using a Q tip and isoproply alcohol.  This did the trick.
(Elsewhere in this forum, there is information on how to remove the oven control panel and gain access to the control assembly.  I posted this information - keywords in subject: Whirlpool RBD305PDS14.)
Sep 25, 2007 | Whirlpool RBD305PD Electric Double Oven
KitchenAid KESC307 Electric Kitchen Range Logo
105 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
