Question about Bosch SHU3306UC Built-in Dishwasher
Replace drainhose replace drain
    Sergeant:
  • 228 Answers
Remove l/h/side panel as you look at front of machine 2 screws top and bottom behind door and rmove lid lift away side panel this will show opposte end of drain hose its a push fit with o,ring pull down and out slide out back of machine reverse to refit
Posted on May 27, 2010
My washing machine won't drain what can i do
I f you have tried resetting the breaker and then choosing the drain/ spin option and this didn't work.....you will need to get a large bucket and disconnect the drainhose from the back of the unit and allow the water to flow into the bucket. You may have something stuck in the pump...
Sep 01, 2011 | Kenmore Washing Machines
Water is not draining from the dishwasher.
Unplugthe power cord to your dishwasher. You can do this by manually removing thedishwasher from the wall and unplugging it, or you can flip the power switch toyour kitchen at the circuit breaker (although you will need light to drain thedishwasher hose). 2 Put on your gloves,and, using your screwdriver, unscrew the screws from the kick plate of yourdishwasher. The kick plate is the panel just below the door of your dishwasher.3 Place your bucket on the floor in front of the dishwasher. 4 Unhook the drainhose by pinching the ends of the clamp and sliding it down the hose. Remove theother end from the pump. There will be two hoses in your dishwasher. The drainhose is the one that leads from the pump to the underneath of your kitchensink. 5 Point the hose into your bucket to drain any debris. Twist and scrunchthe hose to help remove the waste. 6 Test the hose by running water through it,and then reattach your hose in the same manner in which you detached it fromyour dishwasher.
May 13, 2011 | Siemens 24 in. SE25A266 ExtraKlasse...
Will not pump out water at end of cycle
May 13, 2011 | Kenmore Dishwashers
GE WDSR080D washer fills and drains at same time. You have to force it to the next cycle to fix it.
how high is your stand pipe that your drainhose goes into should be ev en with cabinet top... other wise replace timer
Jan 27, 2011 | GE WDSR2080D Top Load Washer
My tromm frontload washer is not draining. I
in order to check the main drai hose the whole front panel needs to come come off.This is done by removing the lid.
then remove the screws that hold the main control board, then you need to remove the rubber boot from the front panel.then remove the screws that hold the front panel on the machine.
Feb 22, 2010 | LG WM1814CW Front Load Washer
Dishwasher not draining have already replaced the pump
if you have recently replaced the garbage disposal be sure the plug was removed from the drain port the drainhose connects to.also check the drainhose itself,i"ve seen them plugged with grease etc.
Jan 17, 2010 | Frigidaire Gallery Series GLHS269ZDB 36"...
NOT DRAINING
means your pump is blocked. Apperently there is no main filter according to the book .
It means you will have to open the machine and disconnect the hose from the pump and clean the pump. ( i presume the pump works?)
make sure you try to drain as much of the water by putting the drainhose low into a bucket or basin.
let me know what happened
Jun 24, 2008 | GE WSXH208A Front Load Washer
My teka dishwasher does not drain properly and there is water left in the bottom after the cycle has finished
Means that your pump is obstructed. Clean the filters out and if tha does not work clean your pump and drainhose.
That will solve your problem
May 01, 2008 | Dishwashers
Bosch SHU33A won't drain
I believe you, but did you check the nipple on the drain where the hose connects?
My sink drained OK, and when I took the dishwasher hose loose from the sinkdrain it drained great into a bucket.
When I stuck a screwdriver down where the drainhose connects to the sinkdrain, I felt all kinds of resistance. Its now cleaned out and the dishwasher drains again.
Hope this is your problem otherwise you may need a new pump.
Apr 07, 2008 | Dishwashers
Bosch SHU3306UC Built-in Dishwasher Logo
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
