Question about Whirlpool Calypso GVW9959K Top Load Washer
CE flashes on the display - Whirlpool Calypso GVW9959K Top Load Washer
  • 15,935 Answers
CE Communications ErrorIf there is any breakdown in communication between the machine controller and the motor controller, CE flashes and the unit beeps once.
Some common causes of CE errors include:
· Conformal coating on serial communications pins between the machine controller and motor controller. After disconnecting power to the unit, try scraping this coating off the pins.
· Check the resistance values between the serial communications pins with the connectors in place. Make sure the harness does not have a bad connection.
· Check the quick disconnect at the motor terminal. The drive motor must be hooked up properly or a CE error will occur.
· Drive motor thermal protector has opened.
·Motor controller is not powered or fuse has opened. Replace motor controller.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 21, 2010
CE error displays
hello there and thank you for choosing fixya
CE Communications Error If there is any breakdown in communication between the machine controller and the motor controller, CE flashes and the unit beeps once.
Press STOP/CANCEL to clear the display.
Jul 31, 2011 | Washing Machines
Code ce and lf
controller, “CE” flashes and the unit beeps once.
Some common causes of “CE” errors include:
• Conformal coating on serial communications pins between the machine controller
off the pins.
• Check the resistance values between the serial communications pins with the
• Check the quick disconnect at the motor terminal. The drive motor must be hooked
up properly or a “CE” error will occur.
• Drive motor thermal protector has opened.
• Motor controller is not powered or fuse has opened. Replace motor controller.
If the water fill time exceeds ten (10) minutes, the water valves are turned off and “LF” is
flashed.
Aug 09, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Error code CE When I turn the washer on it start then turn back off, then error code CE flashes on the display.
Jan 10, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Code ce shows we have tried to reset and the code CE come up each time
"CE" Communications Error If there is any breakdown in communication between the machine controller and the motor controller, "CE" flashes and the unit beeps once.
Some common causes of "CE" errors include:
·Conformal coating on serial communications pins between the machine controller and motor controller. After disconnecting power to the unit, try scraping this coating off the pins.
· Check the quick disconnect at the motor terminal. The drive motor must be hooked up properly or a "CE" error will occur.
Nov 29, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
The washing machine displays error code CE for communication error
Hi, Well if there is any breakdown in communication between the machine controller and the motor controller, "CE" flashes and the unit beeps once.
1.Conformal coating on serial communications pins between the machine controller and motor controller. After disconnecting power to the unit, try scraping this coating off the pins.
2.Check the resistance values between the serial communications pins with the connectors in place. Make sure the harness does not have a bad connection.
3.Check the quick disconnect at the motor terminal. The drive motor must be hooked up properly or a "CE" error will occur.
4· Drive motor thermal protector has opened.
5·Motor controller is not powered or fuse has opened. Replace motor controller.
I hope it helps. Thanks! mannu_rakesh
Sep 02, 2009 | Kenmore Washing Machines
My whirpol calypso washer don't running, appear fl and ce
"FL" flashes if any overfill condition occurs. This condition occurs when excessive water in the tub causes the overfill switch to trip. The control must realize that the trip was due to an overfill condition instead of a suds lock condition in order for "FL" to be displayed.
With an overfill condition, the beeper repeats a warning every 10 seconds with no time out. The pump is cycled in drain mode for 30 seconds on, 30 seconds off until the overfill switch resets or power is discontinued to the unit.
• Conformal coating on serial communications pins between the machine controller and motor controller. After disconnecting power to the unit, try scraping this coating off the pins.
• Check the resistance values between the serial communications pins with the connectors in place. Make sure the harness does not have a bad connection.
• Check the quick disconnect at the motor terminal. The drive motor must be hooked up properly or a "CE" error will occur.
Mar 08, 2009 | Whirlpool Washing Machines
CE code flashing and have hit the stop-cancel and everytime i go to start it goes right to CE flashing,,, which i hear is a communication problem do you know how to stop it or fix it
Feb 05, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Kenmore Elite Top Loader "CE" error code.
CE means communications error
Dec 27, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Frigidaire Upright freezer with Beeping Display
the thermistor is most likely bad. you would have to take an ohm reading of the thermistor and check the tech sheet to see if it is in range. The thermistor is $50 to $75 part.
Jun 09, 2008 | Frigidaire Gallery Series GLHS269ZDB 36"...
Whirlpool Calypso GVW9959K Top Load Washer Logo
90 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
