Question about HP Wired Handheld Barcode Scanner
HP BARCODE SCANNER CONVERTS THE DASH (-) INTO QUOTES (")
I AM USING AN EAN 128 CODE AND SOME ITEMS HAVE A DASH IN THE CODE, FOR EXAMPLE:
MK04-00866144
WHEN I TRY THE BARCODE SCANNER IN WINDOWS NOTE BLOCK, THE SCANNER READS THE CODE AS FOLLOW:
MK04"00866144
I ALREADY PRINTED THE LABELS AND THE PRODUCTS ARE LABELED. WHAT CAN I DO TO FIX THIS?
Cannot read bar code
If it will not read any bar codes, then it must be repaired. If it only reads selective bar codes, then perhaps the one you are trying to scan may not be of the type it recognizes.
This scanner will read the following codes: LS 1004/LS 1006: UPC/EAN, Code 39 full ASC11, Code 128, Code 93,
Codabar, Interleaved 2 of 5, Discrete 2 of 5; LS 1000: undecoded
Mar 09, 2015 | Symbol LS-1006 (ls1006i0001900z) Handheld
It scans 'k' at start with upc code
It sounds like the scanner has the Symbol Code ID character enabled and you are scanning a GS1-128 (formerly known as UCC/EAN 128) code. You can disable this by scanning the Symbol Code ID None barcode from Adobe page 211 of 460 (Chapter 12 page 3) of the LS9208 Product Reference Guide. https://atgsupportcentral.motorolasolutions.com/content/emb/docs/manuals/6083309a.pdf
Apr 18, 2014 | Zebra LS 9208 Omnidirectional Projection...
Config
Quick reference is just for simplified configuration. For detailed configuration go to the reference manual.
Download:
Hopefully you know about Code families and specifications? If not - you can learn it here.
Apr 25, 2013 | Datalogic Heron D130 Handheld Barcode...
Honeywell
Scan "do not expand ean-8 to ean-13" in your programming guide.
Jan 18, 2013 | Honeywell Voyager 1200g Barcode Scanner...
Gryphon gm4100 ean 128 ]c1 identifier
1. Download Product Reference Guide (PRG), Gryphon I GD4100/GBT4100/GM4100 and Gryphon L GD4300 (English) Manuals .
2. Go to Page 80, Section titled GS1-128 AIM ID.
a. Scan the Enter/Exit Programming Mode code.
b. Scan the GS1-128 AIM ID=Disable code.
c. Scan the Enter/Exit Programming Mode code.
Feb 22, 2012 | Datalogic Gryphon I GM4100 Barcode Scanner...
Scanner doesn't scan all barcodes
these scanners are user configurable, to prevent scanning of an inappropriate barcode, only the required barcode schema are enabled, if you look in your code book you will find that there is a page with listings and examples of the various different barcode schemes, in the section before that there should be a list of barcodes that allow you to program the device to use whichever barcode scheme you wish (as long as it is compatible with the scanner)
so you can enable the scanner to read 128, code 39 or EAN and also you can configure prefixes / suffixes depending on your software's requirements
Oct 10, 2008 | Falcon 4420
Ean 13 problem
you are probably reading to a inteligent software package like Excell, which sees the inputted data as a number (so ignores leading zeros) you need to specify to the sytem that the incoming numbers are TEXT not numbers.
Sep 30, 2008 | Symbol LS2208 Handheld
Incorrect Reading
Try experimenting with the different inter-scan code delays. You can find the programming barcodes in your manual.
Aug 20, 2008 | Metrologic Instruments Voyager MS9520...
GP5385 incompatible with EAN 13
Dear Akiong, Please try to reset your scanner configuration, using some utilities from it's manual book (usually available at it's case/box), restore it by scanning it to factory configuration,or scan a label that would enable all symbologies.
Aug 24, 2007 | PSC Quickscan GP5385 Handheld
HP  Wired Handheld Barcode Scanner Logo
462 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
