Question about Alvarion BreezeACCESS LB 5830
Point to point wireless problem
There are 4 LB5830 in two links back to back the first link is 7.2 miles and the second is 2.2 miles. The first link stats are as follows two LB5830 radios 7.2 mile link has a SN:12.06 on the near end and a SN:15.20 on the far end. The link is set at 5.780 GHZ and the throughput is set at 70MEG and is running about 18MEG.
Why won't it operate at 70 MBPS?
My link is wireless point to point on 5.8 ghz and is 13 kms apart it has RSSI level of -88 still disconnects
Posted on Apr 21, 2008
6ya staff
SOURCE:
I have a belkin g+ mimo router and am currently trying to set it up as an access point to interact with my d-link dir-615 router. when i add my d-link routers ip address string, the belkin disappears. i...
Hello...
Steps To Convert your Belkin Router as an Access Point.
- Connect your D - Link Router to your PC & Check the Default Gateway It Might Be 192.168.1.1 or 192.168.0.1
( Finding Default Gateway: Right Click on Local Area Connection & click on Status - Click on Details For Win 7 & Win Vista & For Win Xp - Right Click on Local Area Connection & Click on Status, Select Support Tab & Click on Details )
- Now Connect the Belkin router to your Com .. Open Internet Browser & Go to 192.168.2.1
- Towards your Left Corner Under Wireless Clink on Use as Access Point
- It will Prompt you For a Password Leave it Blank & Click on Submit
- Select the Radio Button Next to Enable
- In Specify IP Address Type in IP Address in Range of your D - Link Router Eg: 192.168.0.254
- Select Subnet Mask - 255.255.255.0
- Click on Apply Changes
- Now Open the Router Setup Page Using the Ip Address which you gave EG: 192.168.0.254
- Connect an Ethernet cable From your D - Link Router to Any 1 of the Wired Slots on the Router ( Note: We are using Wired Slot as we have Disabled the NAT on the Belkin Router It Gives you IP Address From your D - Link Router & the DHCP on the Belkin Router is Turned Off)
- Power cycle the D- Link Router & Belkin Router For 15 Seconds Each ( Unplug the Power cable & Plug it Back After 15 Seconds)
- Now go to the Router Setup Page & Check the Internet Status in the Top Right Corner It Would Be Connected.
- Try Going Online... :)
Feb 19, 2011 | Belkin Wireless G Plus MIMO (F5D9230-4)...
How to password protect a d-link airplus wireless access point.
1) Switch On the connected router enter the IP address 192.168.0.1 in the address bar at the top of your browser.
2) Give admin as username, leave the password blank, click ok.
3) In the left panel, select Wireless to open the Wireless Settings.
4) Change SSID. Replace the SSID which you will remeber.
5) For Security, select WEP. Select Shared Key for Authentication and type in your key. eg, manage1234
6) Click Apply
Dec 03, 2010 | D-Link AirPlus Xtreme G DWL-2100AP...
~hello, i using this D-Link ADSL2/2+ for about 2 month and suddenly the wireless connection fail to connect...there is no light on wireless symbol..so, how do reset the setting? thank you
Access to the router using web interface and make sure that access point is enabled. You can reset it to factory settings by using a ballpoint or paperclip to gently push down the reset button in the following
sequence:
1. Press and hold the reset button while the device is powered off.
2. Turn on the power.
3. Wait for 5~7 seconds and then release the reset button.
You can use Router Commander for troubleshooting router problem also
Sep 04, 2010 | D-Link ADSL2/2+ Modem/Wireless Router...
Wireless access point Pda 1360
To perform a reset, please follow the steps below:
Step 1 With the unit on, place a paper clip into the hole on the back on the unit labeled Reset
Step 2 Hold paper clip down for 10 seconds and release.
Note: Do not repower unit during this procedure.
Step 3 The unit will reboot on its own. Once the WLAN light stops blinking, the unit is reset.
Note: Resetting the router does not reset the firmware to an earlier version. It will change all settings back to factory defaults including IP address, username and password.
May 29, 2010 | D-Link AirPlus Xtreme G DWL-2100AP...
Nothing works whit the d-link
seems like it gets stuck while its booting the config and stays that way. How are you resetting your device? Try to hold the reset switch for about 5 seconds and then all the lights should flash. At this point disconnect the power cord and let it sit for about 10 seconds. Power up the device again.
Apr 12, 2010 | D-Link AirPlus Xtreme G DI-624 Wireless...
My D-link 3200AP don't show signal
check the drivers and the capabilities of the second laptop
Dec 25, 2009 | D-Link AirPremier DWL-3200AP 802.11g/b...
Can I use a D-Link DI 634M as an access point?
Sure you can! As you can with any wireless router pretty much.
1. Assign the new router (AP) to an IP on your subnet that's not your existing router's IP... i.e. 192.168.0.2
2. Disable the DHCP server on the "AP"
3. Create a new wireless network on the "AP"
4. Plug your existing network/router into a LAN port
DO NOT USE THE WAN PORT
Voila! You have an access point!
Jun 21, 2009 | D-Link DI-634M Wireless Router (DI634M)
D-link dwl-2100ap in WDS mode Received Deauth: WLAN 1 11G STA
I have had similar problems with DWL-2100 and (much less often) with DWL-3200. I have no solution, but a workaround: changing the authentication mode. For example, if the units are using WPA-Personal, I change it (on both) to WPA2-Personal or WPA-Auto-Personal. It doesn't seem to matter which mode is used, it's just the fact of changing it that helps (eventually). You may have to go through the process more than once. Also, realize that although the web interface comes up 30 seconds or so after a reboot, it may take another 30-60 seconds before a link is established, so don't give up too soon while trying these changes.
Dec 03, 2008 | Computers & Internet
How to use second access point as repeater
pls i also need solution to this problem, kindly send to my email [email protected]
thanks
Feb 12, 2008 | D-Link AirPlus G DWL-G710 Wireless Range...
Power on and off
it is not the power, but it is searching for a signal to connect to via cable. make sure the cable is connected correctly
Jan 06, 2008 | D-Link AirPlus Xtreme G DWL-2100AP...
Open Questions:
Brother printer tEcH SupPoRt pHoNe nUmBeR{-l855*22l~4867}Washington USA Brother printer tech Support Number +1{85522l4867}}USALogin Repair service center to resolve all Brother printer customer service phone Number products. Brother printer ROUTER is an American multinational company which was founded by Michael Brother printer ROUTER using its company headquarters in Round Rock, United States of America. It deals with the repair, growth, Brother printer ROUTER support number, and selling of computer-related services and products. Brother printer ROUTER Tech Support Phone Number Recently, Brother printer ROUTER has been named the number Brother printer ROUTER technical support advice you not to perform any troubleshooting method if you are not confident of your skills. In such cases, Brother printer ROUTER customer care number can be dialed to contact the certified technicians Contact Technical Support Use one of the below methods to identify your product and see the available contact options, including Service Requests, Chat, and Phone . Enter a Brother printer ROUTER Service Tag or a Brother printer ROUTER Get Brother printer ROUTER Technical Support Phone Number and Customer Services. Brother printer ROUTER is a US-based multinational tech organization having its headquarters located in Round Rock, Texas. This tech organization supports, repairs, sells, and develops technology products. Basically, the company offers computer related products and services.
Oct 23, 2019 | Brother Computers & Internet
DELL PRINTER tech support phone {&$&{[email protected]*5666} NuMbEr USA VKJ [email protected]#& This DELL PRINTER USA phone number +1:855:,:536:5666 is ranked #2 out of 2 because 7,728 DELL PRINTER USA techs tried our tools and information and gave us feedback after they called. The reason techs call # I:855:,:53656.66 is to reach the DELL PRINTER USA tech support department for problems like Where to buy, Complaint, tech support, Repairs, Returns. As far as we can tell, DELL PRINTER USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. DELL PRINTER USA has 2 phone numbers and 4 different ways to get tech help. We've compiled information about I8OO8O31O69 and ways to call or contact DELL PRINTER USA with help from techs like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling DELL PRINTER USA Calling DELL PRINTER USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our support call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from DELL PRINTER USA tech support can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with DELL PRINTER USA's tech support department, you may need to provide them with information that identifies you as a tech, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare DELL PRINTER USA's phone numbers against each other. Contacting DELL PRINTER USA in General While I8OO8O31O69 is DELL PRINTER USA's #2 most popular phone number, it's not the only way to get a hold of their tech care team. You already know from reading above that I8OO8O31O69 is their best tech phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach DELL PRINTER USA help by calling them, is that other techs give their tech support at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact DELL PRINTER USA. VIKKI
Oct 23, 2019 | Dell Computers & Internet
WEBROOT TEch sUppoRt pHoNe [+1]8OO[8O3]1O69 nUmber vviss Usa WEBROOT USA phone number is ranked #2 out of 2 because 7,728 WEBROOT USA customers tried our tools and information and gave us feedback after they called. The reason customers call # I:8OO:,:8O31069 is to reach t he WEBROOT USA Tech Support department for problems like Where to buy, Complaint, Tech support, Repairs, Returns. As far as we can tell, WEBROOT USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. WEBROOT USA has 2 phone numbers and 4 different ways to get customer help. We've compiled information about I8OO8O31O69 and ways to call or contact WEBROOT USA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling WEBROOT USA Calling WEBROOT USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our free call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from WEBROOT USA Tech Support can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with WEBROOT USA's Tech Support department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare WEBROOT USA's phone numbers against each other. Contacting WEBROOT USA in General While I8OO8O31O69 is WEBROOT USA's #2 most popular phone number, it's not the only way to get a hold of their customer care team. You already know from reading above that I8OO8O31O69 is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach WEBROOT USA help by calling them, is that other customers give their customer support at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact WEBROOT USA.
Oct 23, 2019 | Webroot Computers & Internet
See all Alvarion BreezeACCESS LB 5830 Questions
Alvarion BreezeACCESS LB 5830 Logo
115 people viewed this question
Top Alvarion Computers & Internet Experts
Ekse
Marvin
Marvin
Are you an Alvarion Computer and Internet Expert? Answer questions, earn points and help others
