Question about LG 24 in. LDS 5811ST Stainless Steel Built-in Dishwasher
LE flashes after indetirmed operational period.
LE flashes after undetermined operational period. Checked for broken wires after removing front panel. No broken wires detected. The unit runs fine but stops in the middle or sometime in the quick wash cycle will finish the complete cycle.
    Sergeant:
    Champion:
  • 311 Answers
Motor is going out. Replace the sump assembly.
Posted on May 28, 2010
I get an LE error message on my LG Dishwasher. I replaced the pump. Still get the LE error. Replaced the main control. Still get the LE. No blockage in the pump. What now?
When you receive the LE error code, unplug the machine for approximately 15 - 20 minutes. This will reset the microprocessor.
Oversudsing is the main cause of LE error codes. Using non-HE detergents or too much detergent will cause stress on the motor. Oversudsing can also cause leaking and odor.
A breakdown in the signal between the microprocessor and the motor may cause the error code. This can occur if there is a loose wire.
A couple of notes about this - there are at least three motors on this unit - the main pump, the drain pump, and the 'vario motor' which appears to control the direction of water flow through the sprayers. The main pump is the one likely to go bad. Another cause of the LE code is broken wires in the door. The wires in the door get stuck in the black sound insulation and eventually break. Sometimes, this causes the LE error code. Check the wires in the door first. They are located behind the large front panel. It's easily removed by undoing 6 screws.
Sep 06, 2010 | Dishwashers
What does it meam when my LG WM2677HSM is flashing "LE"?
LE code stands for locked motor error. When this error code appears in your front load washer it indicates a fault in the motor unit.
1 . Check the connections to the Coil/Stator at the rear of the unit possibly it should be something like a broken wire.
2 . Coil/Stator Assembly will be defective preventing the drive to operate.You should go for a replacement of that assembly.
Thank you !!
Aug 09, 2010 | LG Washing Machines
Machine won't spin...everything else working
Thank you !!
Jul 21, 2010 | LG WM-0532HW Front Load Washer
Flashing LE and not finishing the cycle
Thank you !!
Jul 13, 2010 | LG WM-2277HW Front Load Washer
Why is my dishwasher flashing LE
This is very common problem with LG dishwashers. The LE error code (locked engine) is not allways indicative of a motor problem.
Simply unscrew the front door panel from the retaining screws on the inside of the perimiter of the door. Once the screws are removed pull down and out to remove the door panel. Remove the sound insulating material and you will see several wires routed from the contol panel the length of the door to underneath the unit. Inspect the wires thouroghly. Near the bottom is where the pinching can take place. There are two gray wires and if you have been getting the "LE" error code, one of those wires is most likely broken or pinched. Splice, reconnect, solder or tape and you're back in buisiness!
Jul 08, 2010 | LG Dishwashers
Le comes up and stops cycle
Thank you !!
Jun 28, 2010 | LG WM3677HW 3.7 cu.ft. Front Load Washer...
My dishwasher is showing LE on the display and will run but doesn't seem to be cleaning the dishes. Any solutions?
Well LE means locked motor, this seems to be a very common problem withe these dishwashers.
Possible Cause For Error Occurrence:
Wiring connection is OK?
The Impeller of Washing Pump is locked.
The rotor of Washing Motor is locked.
The Blade is locked.
Anyway the LE error code is not all-ways indicative of a motor problem. There are also strong chances of any lose connection (wire), so first you can simply unscrew the front door panel from the retaining screws on the inside of the perimeter of the door. Once the screws are removed pull down and out to remove the door panel. Remove the sound insulating material and you will see several wires routed from the contol panel the length of the door to underneath the unit. Inspect the wires thoroughly. Near the bottom is where the pinching can take place. There are two gray wires and if you have been getting the "LE" error code, one of those wires is most likely broken or pinched. Splice, reconnect, solder or tape.......
Please follow the below link for more information (the link contain service manual, you can check the page number 25) -
http://136.166.4.200/contents/Dishwasher/LDS5811/LDS5811_Service_Manual.pdf
(Just copy and past the above link in your web browser)
Good Luck!!
Thanks
Mar 27, 2010 | LG 24" Built-In Dishwasher - Black
LG LDF6810 stops with LE error code
This seems to be a very common problem withe these dishwashers. The LE error code (locked engine) is not allways indicative of a motor problem. I had the same issue with my diswasher (3 months out of warranty). I found out that one of the gray wires which runs the length of the door panel was pinched and broken simply from the repetative motoin of opening and closing the door over time (very poor design). Good news is that it was an easy fix. Simply unscrew the front door panel from the retaining screws on the inside of the perimiter of the door. Once the screws are removed pull down and out to remove the door panel. Remove the sound insulating material and you will see several wires routed from the contol panel the length of the door to underneath the unit. Inspect the wires thouroghly. Near the bottom is where the pinching can take place. There are two gray wires and if you have been getting the "LE" error code, one of those wires is most likely broken or pinched. Splice, reconnect, solder or tape and you're back in buisiness!
Feb 18, 2008 | LG LDF6810 Built-in Dishwasher
Random electrical problems, sometimes it works beautifully, sometimes not!
F11 = Communication between the Central Control Unit (CCU) and the
Motor Control Unit (MCU) cannot be sent correctly.
1. Unplug washer or disconnect power.
2. Check wire harness connections to the MCU, the motor, and
Central Control Unit (CCU).
3. Check the drive system for any worn or failed components.
4. Plug in washer or reconnect power.
5. Verify CCU operation by running a Diagnostic test or any
cycle.
6. Check the MCU by looking for operations of the drive motor.
7. Check the drive motor for powered rotations.
8. Check that the serial harness at the MCU is not mounted
upside down. The wires should be to the left when facing the
MCU connectors.
FDL=
A Door Lock Error occurs if the door cannot be locked. It will try to lock
it six times before displaying the error code.
Le code d’erreur “Verrouillage porte” apparaît s’il n’est pas possible de verrouiller la
porte. Le système effectue six tentatives de verrouillage avant d’afficher le code d’erreur.
■ Door lock mechanism is broken or removed from door.
■ Door switch/lock unit failure.
2. Check door switch/lock unit.
3. Check the wire harness connections to the door
switch/lock unit and Central Control Unit (CCU).
Feb 12, 2008 | Whirlpool Duet GHW9150P Front Load Washer
LE Code on control panel
Press "end of cycle". Plug off the wall. Code can be an indication of several issues. The most common cause is over-sudsing in the machine. Overloading the wash with too much laundry may also cause the LE error code. Lastly, a breakdown in the signal between the microprocessor and the motor may cause that error code. This can occur if there is a loose wire, see that all wires are tightened..........
Dec 31, 2007 | Washing Machines
Open Questions:
See all LG 24 in. LDS 5811ST Stainless Steel Built-in Questions
LG 24 in. LDS 5811ST Stainless Steel Built-in Dishwasher Logo
180 people viewed this question
Top LG Dishwashers Experts
Mike
Mike
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
