Question about Dell Dimension 9200 PC Desktop
My Dell Dimension begins to boot then sits there as if asleep
My Dell Dimension begins to boot then sits there with the power button light flashing on and off slowly and nothing displayed on the screen. If I press the button once it starts to flash faster and then reverts to a slower flash.
If I try to kill it by holding the power button in for about 5 seconds, it tries to power up automatically a second later and for a while it was turning itself on and off for a few seconds repeatedly - weird! If I leave it flashing for a while before I kill it, sometimes I can start it. Once booted up into Windows it is fine. Sometimes it gets as far as starting to load windows before going blank with a flashing power button again.
Any clues?
  • 903 Answers
It sounds like it's probably the power supply. Computers require more power to boot up than they do to keep running, so if it's fine once it gets going, the power supply may just be dying. If you have a multimeter and know what you're doing, you can test the power supply connectors to see if any of them (especially the ones leading to the motherboard) are not giving the proper voltages.
How old is the computer?
Posted on May 28, 2010
How can I jump the power switch?
Solid Amber Light on Dimension 4500 - Power supply is suspect ...
en.community.dell.com/support-forums/desktop/f/.../t/18332108?...
Dell
Feb 12, 2007 - 14 posts - ‎4 authors
I have a Dimension 4500 that is obviously a few years old. ... So when I push thepower button "on" now, the light is a constant ... I pulled of the 20-prong conection (to the motherboard) and jumped ... The fan itself can be replaced, if you're good at mechanical projects. .... And the computer started right up. Boot Up Problem With Dell Dimension 4500 - General ...
Sep 5, 2012
Dell Dimension 4500 won't power up - General ...
Oct 24, 2006
Dimension 4600 - Bad Power Supply or Power switch ...
Mar 27, 2006
On/Off butotn failure.. Please Help - Community
Mar 8, 2006
More results from en.community.dell.com
Dell desktop won't start with power button - Forums - CNET
www.cnet.com > Forums > Desktops
CNETAug 5, 2009 - My dell dimension 4500 was accidentally turned off at the power strip and ... There is a light behind the button but no lights on back of computer. ... I have a Dimension 2400 that I'm not using--could I try that power supply in it?
Dell Dimension 4600 won't power up {Resolved} - Virtual Dr
Feb 03, 2016 | Dell Dimension 4500 PC Desktop
My Dell XPS 730 needed a new CMOS battery I changed this but now it wont post get no beep errors and it doesn't get to the DELL screen. There is power everything lights up and fans start going but no...
I believe you have used the wrong type of CMOS battery. Try putting the old one back in and see if it will boot. If not the CMOS NAND chip may be broken. If this is the case contact Dell and order a new one.
May 07, 2011 | Dell XPS 730X Desktop Computer
My Dell Dimension 5150 PC is not starting up straight away, instead the green light on the power button flashes about every second for several minutes then stops, pressing the power button then boots the...
It sounds like your system is hibernating or asleep instead of powering up. Consult the power management section of your manual here. You can also use the troubleshooting section of the Dell online support site to help find a solution to this problem. It could be the button is sticking in the bezel, or there could be some other fault with the switch or the power supply.
See a link to the support page for your system here. and follow the prompts for more details about this error.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Jul 10, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Can't boot up Dell 5100 Dimension, amber light flashes
When you mean the amber light, is that the blinking hard drive access light or the power light? Different cases have different colors on it. Mine has blue and green lights.
If you see the boot screen (bios) and then after it goes to boot, does it blink and hang?
This could be a simple operating system issue, hard drive or hardware/motherboard issue. If you could provide more information, that would help.
Jun 28, 2009 | Dell Dimension 5100 (D51L1) PC Desktop
Dell Dimension 3000 flashing yellow light
Replace the power supply with a known working one. If it goes away then you know that the original power supply is bad.
If it doesn't go away with the new power supply then you know the motherboard is bad and would need to be replaced.
Jun 26, 2009 | Dell Dimension 3000 PC Desktop
Computer won't turn on
A flashing yellow power LED is an indication of a failure in the power supply. If under warranty, Dell should be replacing it. If out of warranty, then a 400/450 Watt ATX power supply should resolve the issue.
http://www.newegg.com/Product/Product.aspx?Item=N82E16817182021
Apr 06, 2009 | Dell Dimension™ E510 PC Desktop
Dell Dimension 5150 will not boot. Flashes amber light
I had the same issue with my Dell Dimension 5150 and I replaced the front I/O USB Audio Panel and it booted right up.
Feb 10, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Dell Dimension 4400 Won't Turn On
inside the pc there should be a green light. called flea light. if its not on.. then id say motherboard or power supply are bad.
take power cord off. and hold power button down for 10 ecs. then reconnect and retry. i think its abad psu.
Oct 09, 2008 | Dell Dimension 4400 Power Supply ** FREE...
Dell Dimension 9200 PC Desktop Logo
193 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
