Question about Car Audio & Video
I NEED MANUAL FOR A CLARION DECK MODEL# DX2525
  • Bobinger79 May 27, 2010
    Please check the model number again.
I dont hAVE THE wire hardness for my deck and wondering if am able to get just that part
http://www.shopping.com/Clarion-VRX485VD-wire-harness/products?CLT=SCH
The ones i see listed are not an exact model number match, however, in my experience have found that most harnesses will fit models from the same make... for example, when you swap a Sony deck you can replace it with another Sony deck with a different model number just by unplugging the harness from the deck itself and plugging it into the new deck.
Jan 06, 2011 | Clarion VRX485VD Car DVD Player
I had a Clarion 6 Disc CAA-355 in my car which got wet and is no longer working. Can I buy the same model again. If so where from and for how much or is there another model that will be compatible with my...
Great Clarion Disk Changer, 6 CDs CDC-655Z:
CDC655z Multi-Disc Changer - 6 -disc direct load mechanism. - 1-Bit D/A converter. - 10 sec. read ahead memory to prevent interruptions caused by shock and vibrations. - Non-stop play. - Optical Digital Output. - 0º to +90º mounting angle.
Great Multi-disk player. Works only with Clarion audio source units.
Selling b/c my deck player broke- I can give you the deck- maybe you can fix it. The model is DXZ-535, comes with owner's manual and remote.
Feb 25, 2010 | Clarion Car Audio & Video
I didnt get a manual or remote with my vz409 clarion deck
go to clarion web site punch in the numbers should have a downloadable manual for it there and you will also be able to order a remote
Feb 24, 2010 | Clarion XMD3
Clarion vrx485vd wont play videos from iphone when connected
You need a composite video cable to the Clarion Video input. The usual ipod adapter is for audio only. If you have an AV ipod adapter and you still don't have video, the signal is not strong enough for the clarion to see it and you need a 12volt pre amp. you can find them online starting around 25. Hope this helps
Jun 19, 2009 | Clarion VRX485VD Car DVD Player
I need the wiring diagram for this deck (vrx745vd)
Go to www.clarion.com click united states...then type vrx745vd and look to your right...you can download..
May 10, 2009 | Clarion VRX745VD Car DVD Player
What cords do i need to hook up a clarion vrz935vd tv deck
YOUR GONNA NEED A WIRE HARNESS THAT MATCHES YOUR VEHICHLE FIRST OF ALL
Jan 06, 2009 | Clarion VRX745VD Car DVD Player
Robert
The best solution is to google Clarion and serial # to deck, also include manual. EXAMPLE: Clarion VRX935VD Manual....And in that manual there will be a wire connection page. It will show you the best possible way to install the deck into your car.
Jun 12, 2008 | Clarion VRX935VD Car DVD Player
Can't Reset clock on deck
The manual has your solutions, and is available here: http://www.clarion.com/us/en/MungoBlobs/662/481/DB225(Manual).pdf You may have to go in from the main site (www.clarion.com) to reach this pdf file.
May 25, 2007 | Clarion DB-225 CD Player
Reseting the time
To reset the clock.... the simple way to do it is to just disconnect the ground on the battery...it will reset the deck.
Mar 17, 2007 | Clarion DRX6475
Car Audio & Video Logo
95 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
