Question about FireLite (USBFLB80) Hard Drive
Blinking light my FireLight USBFLB80 is blinking constantly and my computer won't recognize it.
The drive is brocken and should be replaced if still under warent.
Posted on May 27, 2010
Compac computer won't turn on and the power light blinks constantly what can i do to fix this problem
Does it beep? if it does, whats the beep pattern...ie long long short, or short short short
if nothing else, something is causing a short...check the usb ports (real common) the contacts break from wear and short out, have your power supply tested.
Aug 20, 2012 | HP Compaq Presario SR1303wm PC Desktop
I bought a SmartDisk solution for disk backup that is basded on a Firelight Drive and the BounceBack archiving software. I have the BounceBack software configured to take a snapshot of my key C Drive files...
If you're on a network with your workstation, the network administrator does the backup of the server. Yes, you can use as many copies of the firelight as you want.
Apr 16, 2017 | SmartDisk (USBFLB100) 100 GB Hard Drive
Adding to ubuntu desktop
it could be that power isn't sufficient on the USB connection. you might need to plug in your AC adapter.
Also this drive has both FireWire and USB ports on it.
To get it working, make sure that the AC adapter is supplying power, and that USB is connected correctly, then re-boot.
Ubuntu should recognize the drive.
Command line tools that may help are
lsusb
this shows which devices are connected via USB to your computer.
dmesg | less
will help you look for the drive's identification and recognition by the computer, providing information such as vendor strings, capacity, and device assignments.
Good luck.
Mar 23, 2010 | FireLite (USBFLB80) Hard Drive
When I plug in the usb connection for my smartdisk firelite 30 gb, it is not being recognized by my pc
I am sure tha that you have verified that the FireLite has power and the USB connectors are secure both at the Firelite end and the computer end.
If all that is in good order, then you can follow these instructions.
When you plug in your drive you need to do the following to see if the drive is connecting to the computer.
Right Click on "My Computer"
You will get a menu, chose "Manage"
You will then get a Computer Management window.
On the left side of the window will be a menu.
Under the Storage section, chose "Disk Management"
This will open in the right side of the window and will show you your main hard disk, CD-Rom disks and any other disks connected to your computer.
If you see your Firelite hard drive, then it is connected. The drive may need to be formatted. This window should tell you if that is the case. If you see the firelight and it shows that the disk is unformatted, you can right click over the large section on the lower left window which is located to the right of the smaller area that describes the disk. You will get another menu that will allow you to formate the disk. You can also assign or change the drive letter assigned to the Firelight using that same right click menu.
I hope that you have found these directions helpful. Please contact me if you need clarification on any of the instructions I have written here. If the Firelite is not visible on this Manage Computer Window, then you may have a defect with your Firelite Drive.
Please let me know if I can assist you further.
Thank You,
Brian
Jan 28, 2010 | FireLite (USBFLB80) Hard Drive
My USB Port stopped recognizing my Smart Disk
on my computer right click and select properties, then go to the device manager. Under the USB device locate this device and delete and unplug the cable from the computer. Let the computer reboot, and plug the cable into another port if ava. and see what happens.
Oct 10, 2009 | Targus PA050U 4-Port USB Hub
This external hard drive is no longer recognized in Windows Explorer. The blue light is on but all I hear is a ticking sound. Any clues please? It's a Smartdisk Firelight Model # USBFLB60 Many thanks. Ken
It could be that the power supply or USB port is not supplying sufficient power to the drive. That would give the behaviour that you are describing.
Jun 10, 2009 | Computers & Internet
Tv won' turn on. Green light constantly blinking.
this tv is mitsubichi?
is mit what is the model?
look like bad DM, you need chage The capacitors.
Jan 31, 2009 | Mitsubishi WS-65315 65" Rear Projection...
External hard drive
Check your device manager for any errors or conflicts.
Dec 16, 2007 | SmartDisk FireLite 40 GB Hard Drive
External hard drive
Problem is just external...First try in another pc,if it still wont work so just buy new external and put that hdd in new external...
Nov 30, 2007 | FireLite (USBFLB80) Hard Drive
FireLite (USBFLB80) Hard Drive Logo
308 people viewed this question
Top FireLite Computers & Internet Experts
Paul Bade
tdk1988
John Anderson
John Anderson
Are you a FireLite Computer and Internet Expert? Answer questions, earn points and help others
