Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
HOW CAN YOU REPROGRAM BOTH REMOTES TO WORK? I HAD TROUBLE WITH THE ACTUAL DOOR, THAT GOT FIXED , BUT SOMEHOW OPENERS NEEDED REPROGRAMMING. WE CAN ONLY SEEM TO REPROGRAM ONE OR THE OTHER.
    President:
  • 3,197 Answers
It sounds like you have a Security + opener and one of your remotes has reverted to the billion code technology. You will need to purchase a new remote with the same model number and then you will find that 2 of the remotes will program just fine. It will take trial and error to eliminate the bad remote. I suggest you remove the battery and discard the bad one.
Posted on May 27, 2010
Get my garage door opener to lose from the remote?
I had a similar problem, but it ended up being the LED lightbulbs put in the opener to replace the incandescent--the LED bulbs were interfering with the remote signal somehow.
But while troubleshooting, I did learn to reset / reprogram the remote: press the Learn button on the opener, then press and hold the button on your remote. The opener lights should blink. That should reprogram your remote.
If that doesn't work, you might have to erase the codes from the opener memory, I think you need to press and hold the Learn button until the lights blink. But you might want to search how to do it for your specific unit.
Jan 09, 2015 | Televison & Video
My garage door opens when the neighbor opens his garage door
somehow his controller has "grabbed" your frequency which you already know, you cant change the frequency of you garage door receiver. what you do is unplug you opener and have him reprogram his remote to his door while your receiver is incapable of being programmed. somehow your receiver was in program mode when he set his door opener up. at the back of your opener there should be a red button that allows you to program new receivers, make sure this isnt damaged or stuck while pushed in. i have tried these ideas with some success.if this doesnt work then try reprogramming both yours and his from scratch, one at a time while the one not being done is unplugged. hope this helps
steve
Nov 07, 2013 | Overhead Door 109130-390 390 MHz...
Need to reprogram sears garage door remote opener
Click below to get to the manual you need. Just scroll through till you get to your model number.
http://www.managemyhome.com/mmh/owner_manuals/search?query=GARAGE+DOOR+OPENERS&find=
Hope This Helps,
RSMITH972278
P.S. PLEASE RATE ME
Nov 15, 2009 | Locks & Locksmithing
Chamberlain remote has stopped working, new
WHEN YOU CHANGE THE BATTERY NO NEED TO REPROGRAM THE REMOTE.
THE FLASHING LIGHT TELLS YOU IT IS SENDING A SIGNAL THAT IS BEING RECIEVED IT IS JUST NOT THE CORRECT CODE TO OPEN THE DOOR.
REPROGRAMING THE REMOTE SHOULD SOLVE THE PROBLEM
HOPE THIS HELPS
Sep 28, 2009 | Chamberlain Powerdrive PD422D 1/2 HP...
Garage door opener will not respond to security plus remotes
Reset the Liftmaster unit. There should be a red reset button on the unit in the garage. If this does not work, reset the breaker. Good Luck!
Jul 03, 2009 | liftmaster Chamberlain Garage Door Opener...
Garage door will not reprogram its remotes
Did you actually go to the power head and push the program button, then the remote button?
Is there a small wire hanging down from the power head? It's the antenna wire.
Jan 28, 2009 | Chamberlain 950CB Remote Control
Grage door blinking yellow, click and won't open with anything.
TRY RESETTING THE UNIT BY UNPLUGGING IT FOR ABOUT 5 MIN.
IF WHEN YOU PLUG IT IN THE REMOTES STILL DON'T WORK TRY TO REPROGRAM THEM.
IF STILL HAVING TROUBLE--
COUNT THE FLASHES - GOTO LIFTMASTER.COM DOWNLOAD A FREE PDF FOR A SIMILAR UNIT (THE MODEL NUMBERS ARE DIFFERENT BUT THE CODES ARE THE SAME).
HOPE THIS HELPS
Jan 24, 2009 | Sears Craftsman LiftMaster Chamberlain...
Remote does not open garage door
It sounds like the wall button has the lock feature engauged.
Is there a small green LED flashing inside the wall button?
Push and hold the lock button for about two seconds and the LED should stop flashing. This will unlock the garage door opener and your remotes should start working. You may have to reprogram your remotes and homelink again since you triedprograming in the lock mode.
Good luck.
Jan 20, 2009 | Chamberlain 950CB Remote Control
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
169 people viewed this question
Top Sears Building Materials Experts
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
