Question about Mitsubishi WS-65815 65" Rear Projection HDTV
I have a mitsubishi ws 65819 tv, no picture
I have a mitsubishi ws 65819 tv, the sound works but no picture and i am getting an error code of 2-1, what does it mean and can it be fixed?
at first the tv would not come on for a few days and now that it did i have no picture please help.
  • 116 Answers
SOURCE: Mitsubishi WS-65313 - Will not turn on
The most common failure are the two convergence integrated circuits part # 267P173010. The two pico fuses may be open as well, which come from the power supply and provide +24 volts and -24 volts.
Posted on Mar 05, 2008
Slinteriors
  • 8617 Answers
SOURCE: Mitsubishi ws 55809
22 is short protect usually its the convergence Ics in that model that can short out. check fuses F9A04 and F9A05 if they are open its most likely the convergence ICs that need repslacing. If you need further assistance, please reply to this same post.
Posted on Jul 29, 2008
Hi, after lookin in the service manual I have a question. I tested th see if the fuses were shorted, however... I'm not completely sure how these fuses work, since most fuses are shorted to begin with... Are they resistive type fuses of some type? Just looking for insight. Thanks
Posted on Jul 31, 2008
daniel719
  • 240 Answers
SOURCE: MITSUBISHI WS-73909 will not turn on
it is normal for the green light to flash for 70 sesonds at first plugin the set will not turn on while it is taking place try it again after the light stops blinking.
now if your still having problems I need the error code
to get the error code Hold down input (device) and menue at the same time for 5 sec.
the led will start blinking an error code to you.
if it is broken we need the code.
thanks.
daniel
Posted on Jan 13, 2009
  • 14 Answers
SOURCE: my t.v. wont turn on.
hold down the menu + device for five sec what is the error code?
should be like 1 pause then a 2 or something
Posted on Feb 10, 2009
Vertical Lines on my Mitsubishi WS-65819
This sounds like a bad connection or a bad capacitor in the 220 volt source that supplies the voltage for the CRT boards. You will need to get a schematic and trace out this voltage from the PM board to the CRT driver boards when the set acts up. it could even be a connection on one of the plugs from the PM board to the CRT boards. Sorry but not a real easy repair. Might take some time to trace unless a component is failing. Good Luck
Jun 29, 2007 | Mitsubishi WS-65819 TV
Mitsubishi Medallion WS-65819 wont turn on. Code 2-2
The power supply regulator section circuit inside should be troubleshooted.
Mar 28, 2013 | Mitsubishi WS-65819 TV
My WS-65819 won't power on. It would power on for
need to replace the stk's and some other caps, usually have to resolder the chasis on both convergence and power supply chassis.
Dec 03, 2009 | Mitsubishi WS-65819 TV
Mitsubishi 65819
2-1 means no errors, what is it doing or not doing?
May 15, 2008 | Mitsubishi WS-65819 TV
Mitsubishi WS-65819 Sender Board problem
yes it can the cost is $350 sumwut dollars ,i got my tv for $54 and thats wut was wrong with it ,the board that is connected to your power cord is wut needs to be replaced sears can do the job but the labor is $200
Nov 30, 2007 | Mitsubishi WS-65819 TV
HELP
Self test: Turn on and Press the input and menu buttons on front panel together and hold for 5 sec. after 5 sec the power LED will blink a 2 digit seq. This will let you know what error code. Count the first blinks then a short pause then the second blinks. Example 2-3, 3-4, 4-1. Let us know what it is
Oct 20, 2007 | Mitsubishi WS-55807 TV
Mitsubishi WS-65819 got Fried by a mouse
Just replacing the board if its the main board is half of the repair. The memory IC which is usually located on the main board holds all the data for convergence,picture geometry,channel memory,color settings etc..So getting it to run is only half of the battle. Got to http://www.partstore.com and look for the main board. I couldn't however look it up because it says your model number is invalid.
Mar 14, 2007 | Mitsubishi WS-65819 TV
Open Questions:
Mitsubishi WS-65815 65" Rear Projection HDTV Logo
43 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
