Question about Maytag MDE2400A Electric Dryer
Replacing the heating coil on my MDE2400?
Hi folks ~
My heating element coil broke. Is there just a coil available out there? It seems silly to replace the whole element when it's clearly just a coil that needs to be restrung. I imagine a coil won't run $100+ either. *Someone* out there must make this coil or an equivalent. Thanks!
  • testingu May 31, 2010
    Hey there! Thanks for the reply.
    As per your site this is the part:
    http://www.appliancepartspros.com/part_d...
    As you can see though, I don't see a replacement coil. Only the full assembly. Any other options out there?
  • Maytag Master
  • 7,482 Answers
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
I am sure you will be able to find the new heating coil at one or both of these web sites
I will include these two web sites for parts and further help:
http://www.partselect.com/ http://www.appliancepartspros.com/index.aspx
Both also have chat assistance 24/7.
Good Luck, Hope this helps
Please do not forget to rate me, Thank you
Posted on May 27, 2010
Hi my dryer is only just over 1 year old so of course warrenty is up and it wont heat. it runs and circulates but no heat, my husband cleaned out the vent tube what else can we do?? it cant be major its...
it could be the heating element even though it is just over a year old, i have seen heating elements go out on 3 month old dryers, it also could be a thermostat the best thing to do is make sure it is getting the full 220 volts going to it, if it only has 110 volts the motor will run and have no heat and vise versa, then if that is good get to the heating element and look it over real good most of the time the heating coil will be broke into it wont look burnt just broke
May 04, 2011 | Amana Dryers
Heating element. How about just replacing the coil?
you can get a re-string kit if its the open type heating element round pan style and re-string it yourself for about $30-$40
May 27, 2010 | Dryers
Oven on RF263LXTT2 does not maintain a constant heat. Oven heats, but doesn't seem to continue heating at a constant heat during the baking process. Both coils heat up during the preheat. Seems like once...
The problem looks like a faulty electronic control. When you select baking, the broiling element should not come up.
Before replacing control assembly, test the temp probe located inside the cavity, check the wiring harness to temp probe and elements, and ensure that the fan is working if the oven is fan assisted.
Sep 18, 2009 | Whirlpool Ovens
Drying is not heating up.
try replacing thermal fuse. its cheaper than the heater element. this fuse blows when there is restricted air flow over the heating element. meaning clogged vent. you can ohm out this fuse. fuse is located at top left of heater duct with two wire leads going towards it. if its ok then remove heating element and look at coils. usually you can see one broke
Jun 24, 2009 | KitchenAid KGYS850LT Gas Dryer
No heat from dryer
You have a bad heating element and or a bad high limit switch. Check them for continuity with a volt meter. No continuity, replace the part.
May 24, 2009 | Maytag MDE2400 Dryer
JUST CHANGED MY GE DRYER TO A 4 PRONG PLUG, NOW NO HEAT
Sounds like your heating element is burned out (acually burned threw) when you moved it if the element was weak it may have broke in two along the coil wires.
Happens alot.
Feb 17, 2009 | GE Dryers
No Power
look for an "open" thermostat either on the heater can, or a thermal fuse has gone bad, probably shorted out when the element broke.
May 13, 2008 | Whirlpool GEQ9800P Electric Dryer
Maytag MDE2400A Electric Dryer Logo
124 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
