Question about Kodak ESP 3 Multifunction Printer/ Copier/ Scanner
Installed new ink cartridges, computer shows low ink- not working
Installed both black and color cartridges and computer shows
low ink and cannot get printer to work.
  • 973 Answers
I would unplug printer and they turn back on and see, if not ininstall and reinstall cartridges and see.
Posted on May 27, 2010
I have installed a new color cartridge but it still shows the cartridge is low.
Enable the extended services (hp printers toolbox)
OR:
Re-install device services- (go to control panel/printers and faxes and view all avail options/preferneces...)
You may have to use your HP printers Install.disk to enable/reinstall all/extra features.
Dec 01, 2012 | HP F4480 All-In-One Printer
My documents will not print the colored part. just Black and white
I would first check to see how low the color cartridge is. If it is out of ink, you will need to replace it.
Your Lexmark has two cartridges, one for colors and one for black.
To check the level of the ink cartridges, go to the Lexmark Solution Center. This is the software that was installed to run you Lexmark printer.
Check the cartridge ink level images that appear on each tab. If a cartridge is low, or if you have received an Ink Low message on the computer screen, install a new cartridge. An empty or low cartridge is marked with an exclamation point ( ! ).
To order print cartridges:
1 }}--> }}-->Open the }}--> }}-->Lexmark Solution Center .
2 }}--> }}-->Click the Contact Information tab.
3 }}--> }}-->Click Ordering Ink and Supplies.
For help installing a cartridge, go to How to install the print cartridge.
Dec 30, 2010 | Lexmark X6150 All-In-One InkJet Printer
How do I change the toner?
The Fax-2480c does not use toner cartridges.
This is an inkjet and so uses ink cartridges.
There are 4 cartridges, black, yellow, cyan (blue) and magenta (red). If any of these cartridges are empty, you need replace them.
This machine takes LC-51 cartridges.
You're probably out of warranty so jsut get refills... it's cheaper
Mar 25, 2010 | Brother IntelliFax-2480C Fax
I have a Brother MFC5460CN...I can't find the owners manual and I can't figure out where the ink cartridges are? I need to replace them
I found this on the Web site. You can download the manual for yourself. Just click on the link below. If you find this information helpful, pls rate me.
http://www.retrevo.com/d/ds/progress?doc=9adbcf37695f2981dab6cde6d0fdb2d1
Replacing the ink cartridges B
Your machine is equipped with an ink dot counter. The ink dot counter automatically
monitors the level of ink in each of the 4 cartridges. When the machine detects an ink cartridge is running out of ink, the machine will tell you with a message on the LCD. The LCD will tell you which ink cartridge is low or needs replacing. Be sure to follow the LCD prompts to replace the ink cartridges in the correct order.
Even though the machine tells you that an ink cartridge is empty, there will be a small amount of ink left in the ink cartridge. It is necessary to keep some ink in the ink cartridge to prevent air from drying out and damaging the print head assembly.
a Open the ink cartridge cover. If one or more ink cartridges are empty,
for example Black, the LCD shows Ink Empty Black and Replace Ink.
b Pull the lock release lever down and take out the ink cartridge for the color
shown on the LCD.
C Open the new ink cartridge bag for the color shown on the LCD, and then take
out the ink cartridge.
d Remove the protective yellow cap (1). Each color has its own correct position.
Insert the ink cartridge in the direction of the arrow on the label.
f Lift each lock release lever and push it until it clicks, and then close the ink
cartridge cover.
G If you replaced an ink cartridge, the LCD
may ask you to verify that it was a brand
new one. (For example, Did You Change Blck?) For each
new cartridge you installed, press 1 (Yes) to automatically reset the ink dot
counter for that color. If the ink cartridge you installed is not a brand new one, be
sure to press 2 (No). If you wait until the LCD shows
Note
If the LCD shows No Cartridge after
you install the ink cartridges, check that
the ink cartridges are installed properly.
Pls rate met. Thanks and Good Luck.....
Feb 05, 2010 | Brother MFC-5460CN InkJet Printer
My printer says install magenta what does that mean
It means for you to install the magenta ink. Magenta is a color. You have 4 colors. Yellow, magenta, cyan, black
Oct 14, 2009 | Brother Multi-Function Center MFC-240C...
I don't know how to change the ink bought this printer from a guy at work no manual
Lift the scanner cover from the right-hand side of the MFC until
it locks securely into the open position.
If one or more ink cartridges are empty, for example Black, the
LCD shows Ink Empty Black and Cover is Open.
Pull the ink cartridge hook toward you and remove the ink
cartridge for the color shown on the LCD.
and then take out the ink cartridge.
Remove the cartridge covers.
Each color has its own correct position. Keep the ink cartridge
in an upright position when you insert it into slot. Press down on
the ink cartridge until the hook snaps over it.
Lift the scanner cover to release the lock. Gently push the
scanner cover support down and close the scanner cover.
If you replaced an ink cartridge while Near Empty was
displayed on the LCD, the LCD may ask you to verify that it was
a brand new one. Example: Did You Change Blck? 1.Yes
2.No. For each new cartridge you installed, press 1 on the dial
pad to automatically reset the ink dot counter for that color. If the
ink cartridge you installed is not a brand new one, please be
sure to select 2.
If you wait until Ink Empty message is displayed on the LCD,
the MFC will automatically reset the ink dot counter.
If the Install message is on the display after you have
installed ink cartridges, check that the ink cartridges are
installed properly.
Hope that helps you!
Aug 12, 2009 | Brother MFC 420CN All-In-One InkJet...
Black ink not recognized
Select printer, properties.
Select printing preferences, select advanced.
Select more options.
Make sure you do NOT have Use color cartridge for all black printing selected.
(I had set that a while ago when my black cartidge ran out when the kids had a paper due - I forgot I had reset it. Once my color cartidge ran low, everything printed pink).
Let me know if that works for you.
Jun 05, 2008 | Dell 924 All-in-One InkJet Printer
0% color ink
We cannot bypass the color ink check, since the all-in-one uses little amount of even the color ink to print in black. Once check the expiry date of the color cartridge and clean the copper contacts of the cartridge and reinsert it again and then try to print. If the issue still persists replace the color cartridge and check for the result, if we experience the same issue even after replacing the color cartridge then the issue is with the all-in-one.
Apr 12, 2008 | HP Officejet 7130 All-In-One InkJet...
Color problem
Chances are your othe cartridges were low...
When you install a new cartridge your printer does a head cleaning, and it uses alot of ink...
If the others were low, your printouts will show magenta as its the only color left...
Feb 10, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Ink low error
Hi there the ink cartridges are designed to be used once. Most of these new ink cartridges have a set chip on it once you have installed a new cartridge it registers that a new one has been installed and resets the ink counter for that cartridge. When you refill the cartridge it doesn't reset the chip.
I don't know how to reset the chip but the best suggestion I can offer is to purchase a compatible cartridge that has been reset.
Thanks J
Jan 12, 2008 | Lexmark X83 All-In-One InkJet Printer
Kodak ESP 3 Multifunction Printer/ Copier/ Scanner Logo
355 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
