Question about Jenn-Air JES9800A Electric Kitchen Range
Jenn Air JES 9800
Need to replace the glass surface. I have the new one just need to know the best way to go about --no direction came with it but was told it was a "consumer friendly" part .. any help would be great
    President:
  • 1,314 Answers
Pop me an e mail with your complete model number and ill help [email protected]
Posted on Apr 07, 2008
SOURCE:
My jenn-air 8430 cooktop left front burner cycles off-on in the HIGH position. What could be wrong?
I am assuming your cooktop is electric and your have a glass top, if so the burners sensor is bad and you might need to replace the burner. Again before buying anything and for me to help you, I would need a full model number. Some model have plate sensors and with no plate/pot burner cycles. Most of the time I find the sensor in the burner cant detect the heat and this ends up being a safety issue to protect the unit. All this information is based on the premise you have an electric cooktop and a glass surface.
I hope this helps.
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Oct 16, 2013 | Jenn-Air Cooktops
My glass surface broke on my Jenn Air stove, and I'm having problems finding a replacement part.
if you get me the information i will find you the top but they arent cheep ! you may want to look for used parts ?
Stove model
serial number
any other info you can find on it thanks Frank
Sep 24, 2010 | Jenn-Air 35 in. JEC9536ADS Electric...
How do I clean my new electric Jenn-air cooktop with its glass top? Do I need a special cleaner for the glass?
  • Step 1 Wipe up spills as soon as they happen with a clean dry towel. According to the Jenn-Air website, for glass top cooking surfaces, you should do this even if it is hot since it will be harder to clean up later. Be careful not to get burned.
  • Step 2 Use a cooktop cleaner once it is cool. You can also use dishwashing detergent and water or just a baking soda paste (made with water).
  • Step 3 Apply the cleaner to a sponge, cloth or paper towel. For more stubborn stains, you can use a non-abrasive or "scratchless" pad.
  • Step 4 Rub the soiled areas until clean. Rinse well, especially if you used the baking soda paste as that can leave a residue.
  • Step 5 Use a razor blade for burned on and crusty stains that will not come off using the previous methods. Jenn-Air states to hold it at a 30-degree angle to carefully remove the stain.
  • Or you can use this on the link below.
    http://www.amazon.com/Blue-Ribbon-88100-Cooktop-Cleaner/dp/B000HM5INA
    Good Luck and please rate 4 thumbs up for the free answer
    Jun 25, 2010 | Jenn-Air 30 in. CCE3401 Electric Cooktop
    Good morning; We have a new Jenn-Air black glass
    Any proprietary glass top cleaner should be suitable. Avoid using a wire based scouring pad but the Scotch type 'plastic/foam' cleaning pads are ok.
    Jan 04, 2010 | Jenn-Air Ovens
    I have a jenn-air 30 inch downdraft electric slide in range jes 9800- I have lost the owners manual. How can I get a new one? The power was off for several hours and I need to reset the clock/day. thanks...
    I have 30 inch slide in Jenn air and the black top is blistering and peeling. Jenn air replaced it one but the same thing is happening again. What can I replace this with.
    Jul 13, 2009 | Jenn-Air JES9800BA Electric Range
    Jenn-Air Cooktop replacement needed
    You can get a new cooktop surface from Maytag/Jennair for $229. It is a pain however to replace it. Where is the crack in your cooktop and does that crack pass directly through a heating element? If not, then you may be able to repair it. I broke the corner off mine, and then dropped the piece (now 5 pieces). I was able to bond them back together and you really can't tell it was ever broken. But, it takes some work.
    Apr 11, 2009 | Jenn-Air JED8430 Electric Cooktop
    Stovetop on our JES 8850 has shattered
    I would let the pro to do the job. if any thing goes wrong with the wiring, then you are responsible, insurance would cover it.
    you can cook on the part that the heating elements are not damaged by the crack.
    Apr 06, 2009 | Jenn-Air JES8850 Electric Kitchen Range
    Broken glass cook top
    The top can not be repaired. The glass must be replaced . DO NOT USE IT CRACKED!!!!!!!!!!!! This is very dangerous as it can explode from the temperature. Also this is a severe electrical danger as glass top units have exposed elements underneath. Any liquid at all can short it out and cause a fire. I don't know if it is worth repairing. I don't have the exact price for your cooktop but last one I priced was between $350 - $500.
    Jun 26, 2008 | Jenn-Air 30 in. CCE3401 Electric Cooktop
    Need Replacement Plate
    Look on the internet auction sites (ebay etc)
    There is quite a trade in them. Make sure match the dimensions of yours before purchase.
    Jun 11, 2008 | Jenn-Air JMC9158AAS Convection/Microwave...
    Pitted glass cooktop in Jenn Air Model JGC9430ADS
    Did you find anything out? We have had our Jenn-aire gas stove for 1 1/2 years and just noticed today that the surface has bubbled in a spot??? I did clean the oven last week.
    Sep 10, 2007 | Jenn-Air JGC9430ADS Gas Cooktop
    Jenn-Air JES9800A Electric Kitchen Range Logo
    364 people viewed this question
    Top Jenn-Air Kitchen Ranges Experts
    Thomas F. Schneider
    Paul Carew
    Ismael Rodriguez...
    Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
