Use remote control with power point - Computers & Internet
    Sergeant:
    Champion:
  • 293 Answers
What do you mean?
Posted on Apr 07, 2008
My aircon has stoped working..only thing i have done is replace batteries
Check if the batteries both are giving at least 1.5volts each. Clean the terminals of the remote control to secure proper contact with the batteries. Check if the negative terminal of the remote have enough pressure to keep the batteries firmly inside the remote control. Point the remote to the sensor of your air conditioner and press the power button. Changing direction of the remote control pointing to the air conditioner while pressing power button. If still air conditioner does not work clean the sensor eye to remove dust and switch again the unit.
Jan 05, 2018 | Cars & Trucks
How to configure UET-606 Universal remote for NIKAI LCD TV?
Get the UET-606 Remote
1. Make sure its switched on
2. Point the UET-606 Remote towards the TV
3. Press the SET + TV button at the same time - the Red LED on Power will Illuminated solid Red
4. Press the SET Button again while still holding the TV button
5. the Power LED will begin to blink red
6 Enter the code 136
7. Press the Red Power button several times [sometimes 60 times] until the TV set resets itself
8. if the TV resets itself - point the remote away from the TV set and press any button or the SET button until the Power LED stops blinking
9. you are now ready to go
Aug 20, 2011 | One For All URC 7740 Remote Control
My dell d630 won't recognize the infocus lp70+ remote control and I can't advance my power point slides?
Here's what the User's Manual says:
Using the Remote Control
To advance PowerPoint slides with the projector's remote, you
must connect the USB cable on the projector's computer cable to
the computer. See page 8 for more information.
Point the remote control at the projection screen or at the front or
rear of the projector (not at the computer). The range for optimum
operation is about 30 feet. If you point the remote at the
projection screen, the distance to the screen and back to the projector
must be less than or equal to 30 feet. For best results, point
the remote directly at the projector.
If you are displaying presentations in Microsoft® PowerPoint®,
you can use the remote's Previous and Next buttons to navigate
through your presentation while in Slide Show mode.
Jan 26, 2011 | InFocus LP70+ Multimedia Projector
Remote control not working with tv
The remote control is an acess to the TV device for example only from a distance. A remote controll for functionality would require to insert batteries a power source making possible communiction with devices requiring reception transmittion of signals. The remote is handheld pointed to the direction of TV requiring signal before button pressed woudl achieve response. a common button to start the remote control experience is pressing on the power button, that displays a signal on the TV. The TV should momentarily produce a sound and lighting effect,, and displaying on the dark screen a light blue screen. The initial signal response from remote control to TV indicates devices are functioning as required. Additional buttons on the remote controll could perform functions of several available.
The remote control has master button, menu on which every additional function is deriveable. Once the menu button is pressed with remote pointed in the direction of TV, should dicplay a list of options on the blue screen already established by power button. Every additional remote control device functionality is achievable by only after the first two buttons have been powered and pressed to display option results on a screen of TV. The remote controll buttons remaining perform complementary functionalities. For example, the arrow keys on remote control make movement of the options displayed on the screen, where a comfrimation button or identified as select allows to confirm remote functions displayed on the screen. A remote control could have several functionalities only accessible once made to display in screen. The three most common buttons on a remote control are First power button that powers on the TV, menu button that displays a list of functionalities on the powered on bl;ank blue screen, and using the arrow buttons on the remote would moves an indicator arround the screen area options. The selection button makes confrimation of the option.
Dec 02, 2010 | Philips Televison & Video
Remote does not send signal to tv
Gather up all the remote controls that you think are not working and a digital camera.Turn the digital camera on, all you need to do is look at is the digital screen while performing the process.No need for turning off all the lights (but may be helpful in seeing the IR signal).
Point the remote towards the lens of the camera as you would when pointing the remote towards the TV.Press and hold any button on the remote while viewing the screen on the camera. Note: some buttons may not transmit signals via default. Best button to try first is the power button.While holding the button on the remote and viewing the digital camera screen if you see a blueish light, that means the infrared signal is working properly, there is a problem with the direct connection (if its a universal remote, try setting it up, if its not, you're probably not pointing it correctly).
Sep 16, 2010 | Sony RM-Y167 Remote Control
NEED SONY CODES FOR PHILLIPS REMOTE
Universal Remote Control Simple Setup
* Point it at a TV set and press the Mute/Power button. (Mute button if TV is already on, or Power button if the TV hasnt already been turned on)
* Keep pointing it at the TV until the TV turns on or muted, most TVs respond in about 5 seconds, the most is up to 20 seconds. (Other universal television remote you find in stores take minutes to program and enter long confusing codes)
* Once the TV is muted or turns on, simply let go of button and you have total control. You can use the remote as if you had the original remote, and responds instantly. ENJOY YOUR FREEDOM of choices with our remote!
Most remote controls require minutes of programming a universal remote code into each television while you read the confusing instruction manual.
Jan 02, 2010 | Philips Magnavox Learning Universal Remote
Madden NFL 07 instruction booklet
There are two optaions for you to find one, one of the simpler ones would be to find a video game store and ask if they have the booklet in stock and they should be able to give you one, or you can try e-bay, im sure there is something on there. I hope I have helped you in anyway.
Wayne
Jun 26, 2009 | EA - Electronic Arts Madden NFL 07 for...
I have an older tv remote that requres a 3 didgit code the tv is a zenith and so is the remote
here is how you retrive the code...make sure tv is on
Step1..press and hold code search button till light comes on then release
Step2..press the TV button once
Step 3.point the remote at TV and press and release the power button while pointing at TV((you may have to keep pressing the power button several times)) once Tv shuts off hit ENTER
Step4..Press TV button on remote and there you go!!
GOOD LUCK!!!
May 09, 2009 | Zenith DBZN-311 Remote Control
Remote control
Remote of projector just control projector only and wont do questioned / asked job as power point slides are in laptop / desktop.
Sep 12, 2008 | Sanyo PLC XU35 Multimedia Projector
Doesn't work
Inside the remote is a ferrite antenna wrapped with a solid copper wire. Over time this large wire solder point cracks. I've had one that rattled. Carefully pry apart the remote and resolder.
Dec 12, 2007 | Bose RC-18S Remote Control
Computers & Internet Logo
59 people viewed this question
David Payne
David Payne
