My CD drive is kind of erratic. It can read some new blank Cds but cannot read most old ones. Any ideas on how to restore the drive to its normal function?
  • 4,737 Answers
This is normal, most Cd/Dvd writers become weak when they are used over and over. But, in rare cases, they themselves restore the same condition as they were, there is no reason, perhaps the lens or the internal parts regain their functions. Sometimes replacing the lens solves this issues. The result is even better on some drives. I suggest you to replace the lens. I had the same problem with mine (two drives), after replacing, one of them is very much better and the performance is excellent, unfortunately the other one was thrown away since i became useless. But before you do it, please check your cable connections and the condition of the cable (Ide or sata or power cables), in most cases they are the culprits. I hope this helps. I wish you good luck.
Posted on May 27, 2010
  • francis_tail May 28, 2010
    Thank you for your advise. Can I replace the lens without replacing the drive itself? If I can I think that would be cheaper and better.
  • Lebanon Raingam
    Lebanon Raingam May 28, 2010
    Yes, of course you can replace it, but I don't recommend if you are going to take it to the repairing shop to get it repaired. When they ask you additional charge for servicing, that'd be not much different than buying a new Dvd writer. In India a reliable Dvd writer costs around $25.
    In case if you know how to replace the lens, that's your chance to get started.
    Good luck and once again thank you for using FixYa.
It reads CDs, but DVDs: "Please insert a disk in drive.."
DVD SOHD-16P9S drive doesn't read any kind of CD or DVD
hi,there is no problem in drivers .
check the hardware parts
there are 2 possibilities in your case
1.the laser beam which reads the dvd or cds is malfunctioning
2.ensure that the cable & buses are properly connected
in case laser beam is damaged you got to get it repaired for proper functioning
all the best
Dec 19, 2007 | Lite On SOHD - 16P9S Internal DVD Drive
My CD/DVD drive is: HL-DT-ST DVD-RAM GSA-H55N I have XP Home. I have burned numerous CDs in the past and more recently burned several DVDs. Today I wanted to burn a CD and found that suddenly my CD is...
Because they handle two kinds of media, combination drives essentially have two optical pickup assemblies in one package. CDs and DVDs both look the same, but they need different laser light wavelengths to read and write them. It's not uncommon for a drive to go bad the way you're describing, where one kind of disc begins not working while the other kind is unaffected.
An optical assembly is two parts: the laser to generate the light for reading and writing, and a sensor to pick up the light that is reflected for reading. Over time the laser power drops, and there's not enough light for the disc to be read reliably or, as in your case, to even detect the disc. Since you say you've burned numerous CDs, you've put more wear on the CD side, so it's probably just worn out.
There are internal adjustments to tweak the laser power and information is out on the Web about how to squeeze a little more life out of the drive. But the cost of a new combo drive is so low now that there's no reason not to simply replace one when it fails. TigerDirect is one company I buy lots of parts from, and they have two drives that are just $20: this one if your current drive is a SATA type (narrow data cable), or this one if your old drive is an IDE drive (a wide 40-pin data cable). I'm just using those for examples, since there are many other sources.
Another option is to get an external USB burner, and then you'd have a drive you could use on different computers if you wanted, and you wouldn't have to go through the effort of replacing an internal drive (although it's not difficult).
Dec 19, 2010 | LG GSA-H55N DVD-RAM Burner
I CANT READ DVD IN MY CD DRIVE BUT VIDEO CD IS WORKING
your dvd drive has become faulty...it lost the potential to read DVD...but still it will read all kinds of CDs....try cleaning the dvd lens once using lens cleaner....
if it still does not read then you need to buy a new dvd writer...
it is not recommended to repair the old one....
it will not work good even after servicing,it may work for one or two times again it will not work....
new dvd writer for desktop computer will cost around 1100rupees....
for laptops you it will cost even more....
its better to buy an external dvd drives in that case for laptops....
Apr 20, 2010 | Computers & Internet
Dvd rom combo cannot read cds. I have an LG dvd rom combo which I buy as an external drive enclosed on external closure. Since i use it for intalling purposes i seldom use the drive. Intermitently it reads...
try to use with a CD cleaner and do a thorough cleaning - repeat several times. If doesn't help, you need to replace the drive. I experience that same kind of problem with 10 out of 50 computers even if the drive is not used always...some part or mechanism must be deteriorating.
Aug 10, 2009 | LG 32LG30 32 in. LCD HDTV
CD drive wont read blank or music CDs
It sounds like the drive is ready for replacement. It may be that the laser lens is dirty so the drive never detects a disc, or it's gotten too weak from age and use. Replacement drives are very cheap, so the best thing to do is replace the drive. You can get a DVD burner now at Newegg (www.newegg.com) for $25.99.
Apr 17, 2009 | HP Compaq FS7600 17" CRT Monitor
My cd is well ....i have no idea
Sounds like a tough problem to have because half of the CD drive is working fine (the reading part) but half isn't (the writing/burning part).
Here are a few suggestions:
1) try a different CD writing program, if the Wizard says the CD-Rs are full, try a version of Nero or a freeware burning program.
2) if, when you load the blank CD, Windows says that it's unable to burn it, it might not be a CD that your burner can recognize. If you are using different or new CDs, try another one or borrow someone else's blank CD. I've had it happen where a set of CDs that I bought were bad and couldn't be used. Also, some cheap CDs don't work on some CD burners.
3) It might be a bad CD drive. If it's an older computer, you might have to get a new CD drive. Before doing this, I'd try reinstalling the software and drivers for your CD burner and try both the suggestions from above. Good luck
Sep 09, 2008 | Compaq Computers & Internet
CD ROM
1.Try updating your firmware by contacting Dell technical support.
2.Try Calling a Local Technician To check for loose connection or Check it your self.
3.Reset your BIOS Settiongs
Kindly give a feed back to Improve my statistics and to see If it was helpful for you...
Thanks and Regards
Mar 28, 2008 | Dell Dimension 8200 PC Desktop
CDROM drive does not read some CDs
best and most affordable solution - replace the cdrom drive.
Sep 23, 2007 | Toshiba Satellite P15-S479 Notebook
Computers & Internet Logo
19 people viewed this question
David Payne
David Payne
