I have been using satellite service which uses channel 3 but I have now lost channel 3 when I try to use the menu button and progran channels all channels turn white how do I select the channels I want to use.
  • waltjvh May 29, 2010
    Yes very helpful and was very much appreciated
    so thanks again.
    Walt
  • 566 Answers
Hi walt
I`m going to help you with your tv but first;
Could you tell me the brand name and model number ?
Also the same for your satellite receiver if possible.
Posted on May 27, 2010
  • 6 more comments
  • waltjvh May 27, 2010
    Hi sorry about the lack of info on my first posting.
    MAGNAVOX Tv
    serial nr. is 38338451 so this is an older tv.
    walt
    Hi if I use the menu buttons on the front of the tv and pick program all channels, it will go through all the channel numbers and turn them all white there must be away to select which channels you wish to use.
    thanks Walt
  • Jacques Marin
    Jacques Marin May 27, 2010
    Hi again walt
    Magnavox and i would also need the model number.
    Or can you describe what kind of inputs you have at the back of your set?
    Ok sorry again about lack of info but anway the
    model nr. is XS2550 C101
    INPUTS ARE MENU CH VOL POWER
    UP DWN UP DWN + - ON OFF
    Thanks for all your patience
    Walt
  • waltjvh May 28, 2010
    Hi again well I was playing around with the menu and hit the up channel button and the channel nr showed up at the top of the screen so I kept pressing the button utill I got channel 3 and then on the menu i used save channel button and saved chanell 3 now I have the satellite system back again.
    But I now have a new problem when I exit the menu system I have a good picture for about 2 minuets and then the screen turns jet black with only about 1.5 inches around the outside where you can see some of the picture thats in behind. This TV is about to drive me crazy so please help!!
  • Jacques Marin
    Jacques Marin May 28, 2010
    Hi again walt
    Glad you got the channel problem fixed.
    For the other one , it shouldn`t be a problem.
    What you have is the closed caption(CC) on and in text mode.
    I don`t see your remote but there might be a button that says CC
    Hit it until it says caption OFF
    Otherwise you`ll find it in your menu under caption or closed caption.
    Just turn it OFF
    Let me know how it goes
    Hey right on and thanks a lot, I changed the caption to off. now I can actually watch TV now without going crazy.
    Thank you very much.
    Walt
  • Jacques Marin
    Glad it did the trick and feel free to ask any questions before(or after) you accept this answer.
Wont find channels on auto channel search
Ensure that you have a good connection to your antenna/cable/satellite, and that you have selected the proper signal type in your TV menu.
If you are using a cable box or satellite, you might need to search for an analog signal on channel 3 or 4. If your cable/satellite box outputs an HDTV signal, then search the digital channels. If you are using an antenna, search for digital channels and set it the TV to Air in the Channel menu.
Apr 07, 2014 | AOC Televison & Video
Lost remote. Must do manually on t.v. Two problems:\r\n1) I cannot get channel back on channel 3. It skips from 2 to 4. 2) TV has large black box on screen covering most of screen. I can push buttons...
Try website like Remotes.com to buy the tv original remote to used.U will used the tv original remote to turn to channel 3 with ease.After u have the tv original remote push the menu button go into Closed Captioning functions turn off like TEXT 1,2,3...The big black box will not appear on the screen again.Tv used it manually control buttons up and down channels trying to get to channel 3.U will never get it to tv channel 3 because tv channel 3 was not save on it memory list of on the tv turn manually channels buttons programming memory.Tv have a manual button said MEMU button on it tv front bazel frame?Yes.Might could used the Menu button on the tv frame to get in to turn off TEXT 1,2,3...to stop the big black box to show up on the tv screen again.
Aug 17, 2011 | Toshiba 36A50 36" TV
How do i tune the channels on a toshiba rc3910
Hi
Before tuning the set to auto tune mode, make sure the antenna or cable, whatever may, connected to its appropriate sockets at the back of the set firmly. To make it autotune:
As new services are broadcast, it will be necessary to
re-tune the television in order to view them.
Auto Tuning will completely re-tune the television
and can be used to update the channel list. It is
recommended that Auto Tuning is run periodically to
ensure that all new services are added. All current
channels and settings, i.e. locked channels, will be
lost.
[1] Select the SETUP from the main menu by using
Up or Down buttons. Press OK and Setup menu
will be displayed.
[2] Select the Installation from the Setup menu
by using Up or Down buttons. Press OK and
Installation menu will be displayed.
]3] Select Automatic Channel Scan from the Installation
menu by using Up or Down buttons and press OK.
A screen will appear warning that previous digital
programmes and settings will be deleted. Select Yes
and press OK to continue with the Auto tuning.
The television will start to search for all available
stations.You must allow the television to complete
the search. When the search is complete the Auto
tuning screen will display the total number of
services found.
* After search is completed for digital channels, a
message asking whether to search for analogue
channels appears on the screen
** Press the OK button to search for analogue
channels. The following menu appears on the screen
for analogue channel search
OK.
Jul 10, 2011 | Toshiba Televison & Video
I pressed the menu button on my remote and went to channels then I went to antenna scan and lost all my channels how do I rectify this problem?
just go to menu and choose turbo/maunal search or go to channels and press right arrow key on your remote it will revert back to its previous settings
Dec 06, 2010 | Televison & Video
Remote was lost. Tried to adjust the station and now I cannot get the TV to go to channel 3 so converter box will not work. Itied a universal remote did not work. Help
I assume, that the TV is skipping chan 3 when using the Channel buttons on the TV.
You can try 2 things.. First see if your converter box will use chn 4. Usually there will be a very small switch on the back of the box marked with a small 3 on one side and 4 on the other. If so, use that till you get a replacement remote.
If that's not an option, you can also, Re-scan the channels on the TV. to find all available chn for memory.. BUT FIRST making sure that the converter box is on and working.
The TV shuold then detect that there is a signal on chn 3 and make it available to the chn buttons on the set.
You will have to use the menu buttons on the set to do this.. Hopefully one of the buttons is the menu call up, then you use vol or chn buttons to navigate it.
Hope this helps
Dec 03, 2010 | Televison & Video
I have an old daytron tv, with no remote, how do i get it on channel 3
always toggle through the tv/video button to make sure your on the correct source. usually the menu button is pressed, then the up/down and left/right button navigate the menus.
make sure your vcr or satellite receiver is on and set to use channel 3
press the menu button on the tv untill you get to channel settings, look for auto channel setup or search. If the signal is coming through on ch3 and the cable is correctly installed from the source to the tv, this will find the broadcasting station and lock onto it.
If you dont have a menu button on the tv , it could be hidden behind a small door,
if still no menu button, you will have to find a replacement remote to set the channels.
Apr 03, 2010 | Televison & Video
'satellite' icon not available to retune digital channels
Updating the Channel List Automatically You can update the channel list when the broadcaster adds new Services or if you move the TV to a new location.
1. Press the MENU button to display the menu. Press the ▲ or ▼ button to select "Digital Menu", then press the ENTER button.
2. Press the ▲ or ▼ button to select "Channel", then press the ENTER button.
3. Press the ENTER button again, to select "Country".
4. Select the appropriate country by pressing the ▲ or ▼ button. Press the ENTER button to confirm your choice. Even though you have changed the country setting in this menu, the country setting for Analogue TV is not changed. (Refer to page 11 of the user guide)
5. Press the ▲ or ▼ button again, to select "Auto Store". Press the ENTER button. When it has finished, the number of scanned services will be displayed. The existing favourite channel list will not be deleted when the channel list is updated. To stop the scan before it has finished, press the ENTER button with "STOP" selected.
6. Press the EXIT button to exit. If the signal status is poor, the "No Service found! Check the aerial connection" message is displayed. Check the aerial connection and the try the procedure again
Sep 30, 2009 | Samsung LE40R73BD 40 in. HD-Ready LCD...
Can't change channel using the remote or buttons on tv
Simple Fix
I had the same problem, couldn't change the channels with the remote or on the side of the TV. This was for a Vizio 37"
Here is the fix:
1. Turn on TV
2. With remote, press the Menu Button
3. Go to Antenna Menu
4. Select Auto Search
Let it search, it could take several minutes. It may not finish to 100%, mine got stuck at 79% for 10 minutes. It's fine if that happens, go ahead and cancel.
5. It should be done, your remote will work perfect along with the TV channel buttons.
Sep 07, 2008 | Vizio L32 32 in. LCD HDTV
Program channels
TV SETTING
1. Press the MENU button.
2. Use or button to select the TV setting menu, then press or button.
3. Use or button to select the Channel no. setting and use the or button
to change from AIR (over-the-air broadcasts) to CABLE (cable/satellite broadcasts).
4. Use or button to select the Tuning mode and use the or button.
5. Use or button to select the Auto tune and press or button to
confirm the selection. The unit will immediately search through all possible TV
channels and store those channels with signals in memory. After this is complete,
the unit will switch to the first channel found.
6. To exit the MAIN MENU and return to the normal screen, press the EXIT button.
Note : In DVD mode, this option is not available.
Remarks:
1. Channel no. : 2-69 channel for Air mode, 1-125 channel for Cable mode.
2. Tuning mode : Air or Cable mode are available.
3. Auto tune : Searches for usable stations and stores them in memory.
4. Skip : ON - Skip weak channels. OFF - No channel skip.
5. Fine tune : The frequency changes to allow fine tuning.
6. AFC : Auto frequency control.
7. MTS : Select the Mono sound/Stereo sound/Secondary Audio Program (SAP).
21
TV SETUP
MTS (Multi-channel Television Sound) SETTING
This feature allows reception of sound other than the main audio for the program.
3. Use or button to select MTS menu, and press or button to select the
options (Mono, Stereo, SAP)
4. To exit the MAIN MENU and return to the normal screen, press the EXIT button
on remote control.
Note:
• MTS only operates while in TV mode.
• The SAP (Secondary Audio Programs) feature allows a TV station to broadcast
other information, which could be audio in another language.
RESTORE SETTING
If you reset the TV to the factory settings, all your present settings on picture &
sound will be erased and replaced by the factory’s default settings. However, picture
setting in PC mode and parental setting will not be erased.
Jul 15, 2008 | TruTech PLV1615T 15 in. LCD Television
Can't clear channel off screen of Sony Trinitron with remote
Press (on your regular remote for your satellite) the t.v. button, then press info, this worked for me and I tried everything. another viewer posted this solution and it worked great! this is not the original remote, it is the satellite remote.
Nov 22, 2007 | Televison & Video
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
