Question about Refrigerators
I am replacing a compressor on a Whirlpool refrigerator. The compressor is part number 8201557. I am looking to replace it with an Embraco compressor Part number ff11.5bkw. I need to know if this will work out. The whirlpool compressor is priced very high. I do not have a cross reference for Embraco compressors. Can you help me out? Thanks!!
  • Steven Humphrey May 27, 2010
    Thanks for your help!! Would have made a serious error that would have cost far more money!!
    Genius:
  • 1,416 Answers
what you need to know from this point is that this two compressors are not compatible with them self base on the reference you have explain to me
what you need to do to fix up your refrigerator in other to carry out it function effectively is that you will have to get the same part number of the old compressor i.e (8201557) so as not to damage your refrigerator's comdenser and the capacitor
please note,
that replacing a whirlpool refrigerator compressor with part number (8201557) with Embraco compressor with part number (ff11.5bkw) will not work out because they are of different capacities
Good luck and thanks for using fixya.
Posted on May 27, 2010
Will the 8201555 compressor be an adequate replacement?
According to the information from your model number given the compressor should be 8201557 but that changes to W1039990 this is a complete kit. But if your good at changing this you can use a FF8.5HBK compressor which will be about a third of the cost. I hope this helps. Good Luck
Mar 24, 2016 | Jenn-Air JCD2297KEY 36" 22 Cu. Ft....
Need to identify the prongs on my compressor. embraco egy90hlp wiring diagram
PDF]General Index - Embraco
www.embraco.com/DesktopModules/.../Arquivos/MP01EG.pdf
EmbracoApr 7, 2011 - Figure 6b Series EM - Compressor Model Identification Code . ....Compressor Wiring Diagram T Series (electrical component with terminal ...
Embraco PW 5.5A compressor - pins layout? - Refrigeration Engineers
www.refrigeration-engineer.com > ... > Domestic
Sep 4, 2008 - 4 posts - ‎1 author
My fridge-freezer quit working tonight - it's probably over ten years ... It's an EmbracoPW 5.5A, and the pins form an upside-down triangle, ... So, I want to try hard-wiring it but I'm struggling to identify the compressor terminals.
Identifying Compressor Terminals: Start, Run, and Main ...
fixitnow.com/wp/.../identifying-compressor-terminals-start-run-and-main...
Sep 9, 2010 - Let's say you're gonna do some tests on your refrigerator compressor to see if it's okay. Or, you need to figure out how to wire up a generic ...
Refrigerator compressor electrical question - AllisChalm
Jan 18, 2016 | Refrigerators
Replaced compressor in g.e.profile refrigerator
HI,
I need a model number of the unit to assist you, this could be a fan wire or a compactor wire. So a model number is very important to know what you have and get you the correct information you seek. Thanks
Aug 31, 2014 | Refrigerators
Amana abb2224dew repairman installed part # 8201786. This was to replace the compressor start up. Worked for a week, then same buzz click sequence occurs. Looked up part number. Part is for mostly...
The replacement compressor kit is #12002633 from Amana (Now Whirlpool).
In this kit are the following New model compressor, relay/capacitor, jumper and instructions.
Kenmore does not make appliances rather all of the other manufacturers produce for them.
That part number is for Whirlpool Start Relay/Capacitor and as long as the compressor is the right horsepower for the relay it makes no difference who made it. (Techumseh or Embraco)
Apr 29, 2011 | Amana ABB2224DEW / ABB2224DEQ / ABB2224DEB...
I purchased an Amana refrigerator that has been making a humming noise and will not keep food cold or frozen. what' wrong? The model # is ABB1924DEB, and I purchsed it in 2005. is it included in their...
The recall was for units that had embraco compressors. the relay would burn up and not start the comperssor. (hum and click) some amanas had tecumseh compressors. They would just scize up and not run (hum and click)No recall. remove the back cover and see what name is on your compressor. If its hot and trying to start, Embraco needs new relay, Tecumseh needs to be replaced with a embraco compressor.
Dec 01, 2009 | Refrigerators
Installing compressor
It is likely you received a service port necessary to remove and replace the refrigerant in the failed system. Add a photo? It should be capable of clamping around 1/4 or 5/16 copper tubing and then piercing through the tubing via a schrader valve in the 5/16 flare nipple. Needs to be capped with a metal cap when you complete the job. Be sure to neutralize if you have an acid burnout condition from the failed compressor... copper windings burning in the absence of oxigen with all that hydrogen rich coolant makes for very high H+ concentration (i.e. ACID). The pH is minus the log of the hydrogen ion concentration so that number will be low.
1) add the service port
2) using your service hose and a transfer pump, remove refrigerant
3) test for acid and neutralize as needed, replace filter dryer anyway
4) replace compressor with make-up oil as measured from the failed unit and any collected with the refrigerant... use new oil only
5) pressure test with dry nitrogen
6) vacuum and hold 26+ inches Hg, more in cold areas
7) charge refrigerant in by weight specified on label
8) allow to equalize before starting, do not start in extreme cold since liquid refrigerant could be in the lines
9) recycle contaminated or acidic refrigerant
10) test the charge using a superheat/subcool setup if the system is not performing satisfactorily
Nov 07, 2009 | Refrigerators
Bad Compressor, valve sticking in the compresser
Contact Whirlpool Customer Care about this. There has been a serious problem with the Embraco compressors they are using.
May 15, 2009 | Whirlpool GD2SHGX Refrigerator
Whirlpool side by side compressor replacement?
uk price is about £250 fitted i done one about 2 months ago. or thats what my company charge
Feb 14, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool side-by-side melted relay.
Maytag (owned by Whirlpool since 2005) has issued a recall on the compressor relay due to fires. Whirlpool brands are not listed in the recall but it looks like they should be. The problem goes back to Jan 01 according to the Consumer Product Safety Comission.
Whrilpool Compressor
They are oil cooler lines. Your unit does not have an oil cooler so leave the plugs in & don't mess with them. Trust me just put the same compressor in the same model today. Appliance tech 10 years.
Oct 29, 2007 | Refrigerators
Refrigerators Logo
279 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
