SEARS Model 110 Washer My Washer did not flush the water from the first part of the wash cycle last night. I have turned the dial to see if it would do a drain, spin or neither worked. But it does intake water. I was able to drain the water by removing the hose and sending the water into my sump pump. No spin, no pump out on all cycles.
  • Washing Mach... Master
  • 19,396 Answers
Hi.
The problem is probably the pressure switch. Before replacing the pressure switch, the hose connected to the pump must be accessed to find eventual blockage.
The pump can be tested jumping its contacts to energize it directly, or reading volts from timer control while cycling. For safety reasons this tests must be done by a trained technician.ow th
Here an article explaining the reasons that can cause drain problems like yours.
You find the diagrams to locate the pressure switch in the Sears part website also listed on page linked above.
Posted on May 27, 2010
MAV4755A Top Load Washer: When I turn the dial to start wash cycle, nothing ...
if press button selection, make sure that no 2 buttons are pressed
Jan 27, 2018 | Maytag MAV4755A Top Load Washer
Kenmore 80 Series - machine won't rinse or spin
Manually move the timer to the SPIN mode and turn it on.
If nothing happens, replace the lid switch.
With a model number I could be more specific.
Feb 27, 2009 | Kenmore 24032\24036 Top Load Washer
Top load Kenmore 800 washer will not fill with water
OK - I have a solution to my problem with this washing machine. Nothing would work except for one of the spin cycles. I thought it was the main switch - the cycle selection and start switch - but I was wrong. The service tech replaced the switch behind the fabric softener. It's the switch that controls the water levels. Part # W10292584. Our government is forcing the manufacturers to put controls on the washing machine to save water. It's a bad idea and is causing lots of problems. Tech says he's replacing them on a regular basis. Less than $100 if you do it yourself. Hope this helps.
Feb 23, 2009 | Kenmore 22422 Top Load Washer
Washer will not fill
not your timer / if anything its eather the water valve or the water slector switch
Nov 23, 2008 | Kenmore 24032\24036 Top Load Washer
SEARS/KENMORE MODEL 110 WASHER
if you are using a rubber drain hose look for a kink for flattened area this could be restricting flow out of washer replace hose with the plastic hose that comes with it..also ck hoses and pump for restriction ( socks ,thongs) lastly remove pump and ck impeller for severe wear impeller should be almost same diameter as pump case if it's a lot less replace pump
Aug 29, 2008 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
26 people viewed this question
Top Washing Machines Experts
