Question about HP Compaq dx2200 PC Desktop
HP Compaq dx2200 doesn't detect RAM
Hi!
I have a very strange problem:
I have a HP Compaq dx2200 Microtower. I bought it with 256MB RAM and then replaced them with 2 Patriot memory 1GB each. The strange thing is that windows and the BIOS only detects 1GB! I tested using only 1 RAM and it detected 512MB. Also swapped the RAM slots and tested in all the possible ways. The RAM specifications are compatible with the PC. I don't know what's wrong. Additional Data: I bought the computer from a company.
Thanks!
  • HP Master
  • 3,051 Answers
Go here and supply the info for your system or mboard model to determine which G.Skil module part numbers are listed as compatible with your system or mboard:
http://www.gskill.com/configurator.php
If your system model or mboard model is not listed, or if it is listed but they don't list the module part number(s) you have, there is no way of knowing whether the ram will work properly in your mboard !!.
A common thing that can happen with ram, even ram that worked fine previously, is the ram has, or has developed, a poor connection in it's slot(s).
This usually happens a long time after the ram was installed, but it can happen with new ram, or after moving the computer case from one place to another, and I've had even new modules that needed to have their contacts cleaned.
See response 2 in this - try cleaning the contacts on the ram modules, and making sure the modules are properly seated:
http://www.computing.net/hardware/w...
If your ram passes a ram test, it's working fine, even if you can't determine whether it's listed for your mboard or system model anywhere
If you do a ram test, do that AFTER having tried cleaning the contacts and making sure the ram is seated properly - otherwise any errors found may be FALSE.
If the ram is incompatible with the chipset, or on more recent computers, incompatible with the memory controller built into the cpu, it will likely FAIL a ram test - that is NOT a true indication of the ram being faulty - there is probably nothing wrong with it, and it will pass the test if installed in a mboard it is compatible with.
NOTE: Sometimes incompatible modules (or matched pairs) won't work properly when more than one is installed, but will pass when by itself.
If you want to try a memory diagnostic utility that takes a lot less time to run a full pass than memtest86 does, this one is pretty good - Microsoft's
Windows Memory Diagnostic:
http://oca.microsoft.com/en/windiag...
It can be toggled (press T) to do a standard or a more comprehensive set of tests - use the default 6 test one first - if it passes one pass of that, use the latter one. A few of the tests in the latter set are intentionally slower.
If you don't have a floppy drive, see the Quick Start Information at that Microsoft link for how to make a bootable CD of the Windows Memory Diagnostic (you need Windiag.iso - you don't necessarily need to use the program they mention to add it to the CD).
If the part numbers of the ram modules you have ARE listed for you model, and/or in any case. if you STILL get ram errors.....
Some ram manufacturer's modules do not strictly adhere to the JEDEC standards that most mboards bioses use to determine ram settings.
In that case, the ram settings in the bios Setup that the bios has automatically chosen may not be correct.
Check the ram settings in your bios - the ram voltage, and the ram timing numbers - those should be the same as for the specs for the modules themselves. Often the ram voltage and timing numbers are printed on the label on the modules.
If the voltage setting or timings settings in the bios are different from the specs for the ram, change them in the bios. The timing numbers must be as close as you can get to the same, or slower timings (higher numbers = slower) - you won't notice the difference the slower settings make.
If you have a mix of different modules
- don't mix ram that different voltages arespecified for - the bios will force the ram to use the lowest voltage, if "by spd" or similar is used (default settings) - ram that a higher voltage is specified for is more likely to not work properly in that situation.
- the bios settings must be those for the slowest timing settings of all the modules, or slower (higher numbers = slower).
G.Skil is one of the "also ran" ram module manufacturers.
According to The Muskin web site, some "also ran" ram module manufacturers test their ram modules when they're by themselves in a mboard, to get the best (fastest) timing ratings. When you install more than one of their modules, the timing may not work properly with more than one module installed, but if you change the timings in the bios Setup so that the timings are slower (higher numbers) , the ram will work fine.
I have seen several examples of people who posted on this site having to do that with G.Skil ram.
Posted on May 27, 2010
  • 973 Answers
What is the max capacity RAM your computer can hold, some computers can only use a certain amount no mattter how much you install.
Hp Compaq dx2200 MT RAM Problems
Firstly, you have to know that you can upgrade RAM as Double or Half of your pre-installed RAM. For example, like your pre-installed RAM is 256 MB, you can only upgrade RAM of capacity 128 MB or 512 MB. Secondly, check your previous installed RAM's speed that is shown in Ghz. You can only upgrade RAM to its similar speed, otherwise you get slow performance of PC.
Jul 18, 2010 | HP Compaq dx2000 Microtower PC Desktop
HP Compaq Business Desktop dx2200 - P4 524 3.06- Beeps
Continuous beeps mean that the power supply or motherboard are faulty.
Jan 20, 2010 | HP Compaq Business Desktop dx2200 - P4 524...
Hi what is recomended system for 3d animation?
intel core 2 duo
with atleast 4 gb ram and dedicated graphic card atleast 256mb.
Oct 22, 2009 | HP Compaq dx2250 Microtower - Get 3...
I have a HP Compaq dx2200 microtower. When I turn
Ed it sounds like a RAM problem. How much ram do you have. These days you need at least 1g. How big is your hard drive. You need to have at least 10g constantly free at all times. This might mean a larger one. You may be running 2.0 devices but is your system truly 2.0 or higher. Go to start, run, try this:
  • Right-click My Computer
  • Click on Properties
  • Click on the Hardware tab
  • Click on the Device Manager button
  • Scroll down as needed until you see Universal Serial Bus Controllers
  • Expand that by clicking on the boxed plus sign in front of Universal Serial Bus Controllers
At this point you should see something like this:
usb2.png "... on most machines the presence of 'Enhanced', even only once, means that all USB ports are USB 2.0 ports ..." Note the highlighted line: "Standard Enhanced PCI to USB Host Controller". While the exact text may vary, the key is the word "Enhanced".
If it's "Enhanced", it's USB 2.0. If it's not, then it's USB 1.x.
Now, wasn't that obvious?
Important: on most machines the presence of "Enhanced", even only once (which it typically is), means that all USB ports are USB 2.0 ports. Typically a machine will have only one type of port and this tells you which kind they all are.
The one exception to this scenario is a machine with USB 1.1 ports that has a USB 2.0 expansion card added. In this case I know of no way to tell which is which, other than simply knowing you added a USB 2.0 card to a machine with built-in 1.1 ports. Obviously in a case like this, the built-in ports are 1.1, and the added expansion card ports are 2.0.
Hope this helps.
JimmyC
Sep 24, 2009 | HP Compaq dx2200 PC Desktop
Factory settings with the cd rom disk
The best thing would be to do a fresh install of the operating system,Do you have an OS disk?
May 11, 2009 | HP Compaq dx2300 Microtower - RT950UTABA...
Only 128MB or 256MB detected Compaq 12XL400 laptop; 3 diff sticks
I think the Smallest and slowest Ram stick needs to be in slot 0
Apr 18, 2009 | HP Compaq Presario SR1110NX PC Desktop
Booting error
This is One of the Known Issues on Hp Products...
There are Updates Released by Hp for Most of the Model facing this issue...
The Products for which the Solution (drivers) have been Released so far in the DX series are...
  • HP Compaq dx6100 Microtower PC
  • HP Compaq dx6100 Slim Tower PC
  • HP Compaq dx6120 Microtower PC
  • HP Compaq dx6120 Slim Tower Desktop PC
  • HP Compaq dx6128 Microtower PC
  • HP Compaq dx7200 Microtower PC
  • HP Compaq dx7200 Slim Tower PC
  • HP Compaq dx7208 Microtower PC
  • HP Compaq dx7300 Microtower PC
  • HP Compaq dx7300 Slim Tower PC
  • Your Product is not listed.
    You got to Report with the HP and they Will update you once they have a Driver for you,
    However what you can do is try and run BIOS update if Possible.(it may not be Possible in a Boot issue though).
    Jul 17, 2008 | HP Compaq Business Desktop dx2200 - P4 524...
    HP Compaq dx2200 PC Desktop Logo
    1,032 people viewed this question
    Top HP Computers & Internet Experts
    Tony
    Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
