Question about Motorola Mobility i880 Cellular Phone
The lcd is flipped upside down how do i repair that
    Problem Solver:
  • 17 Answers
You need to bring it to a Nextel repair shop and have the flip replaced, its the only fix a software issue that affects the LCD
Posted on May 27, 2010
4 Suggested Answers
  • 155 Answers
SOURCE: The lcd is flipped upside down how do i repair and
Hi
The problem you are experiencing has to do with the flex of your phone.All you need to do is to open your phone with a phone screwdriver and check the flex if it has not shifted from the right position then you would adjust it properly.
If it doen't work properly after that then you would need to replace the flex of your phone.
GOODLUCK
Posted on Jun 22, 2010
Techno777
  • 47 Answers
SOURCE: My screen is upside down N95
leave the phone switched on and remove the battery and sim card . leave for 10 seconds then insert the battery with no sim , turn the handset on , after a while when the phone has fully loaded leave it switched on and then remove the battery again , leave for a further 10 seconds and then insert the sim card and the battery when you now turn on the phone you should see the problem has been fixed , if however you are still experiencing the same problems then you will have to contact nokia and get a warranty repair .
Posted on May 10, 2008
timthorne911
  • 464 Answers
SOURCE: UPSIDE DOWN SCREEN IN MY I880 NETEXL FLIP PHONE
take the battery out of your phone with the power on. then try to turn it back on and see what happens. if still a problem take it to a sprint store. they can replace it.
Posted on Mar 31, 2009
Plays back on lcd screen upside down at times
When the viewport is completely flipped around so you can see it when you are looking at the lens, it automatically flips it upside down so it is right side up to the viewer. Make sure it is locked into the correct position to prevent this from happening.
Hope this helps
Dec 05, 2013 | Sony Handycam DCR-TRV520 Digital Camcorder
My bulb was replaced. We reset the bulb hours and somehow flipped the screen upside down. The projector is mounted upside down. What do I do? In trying to fix it, the remote quit working. I may have...
I guess you used factory reset, then picture flips back to table/ front mode.
In setting menu choose for ceiling ( R upside down icon) and set this to ON.
Jan 08, 2011 | Eiki LC XNB4 LCD Projector
I got cryptic answer regarding the problem that the picture on the monitor on my camcroder GZ-HM400 is upside down.
There is a switch within the camera that controls the orientation of the LCD image. When the screen is flipped upside down, the switch is supposed to tell the camera to flip the image upside down as well. If this switch is damaged, the camcorder gets the wrong signal and the image will be displayed upside down. This can usually be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
Oct 25, 2010 | JVC Video Cameras
Th e Viewfinder image flips upside down erratically. Meaning as I rotate the viewfinder it is suppose to flip upside down as it rotates towards the subject being shot. But lately it'; s started...
There is a switch in the LCD hinge mechanism that controls the image flip. It appears to be failing and can usually be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be diagnosed by a qualified service technician.
Sep 15, 2010 | Sony PMW-EX3 High Definition Camcorder
The image is flipped upside down and won't go back I think the camera might have been dropped
THIS IS A REPAIR SHOP TASK
normally there is a micro switch fixed at the awivl head of the lcd panel. when the lcd is rotated to 180 the switch gets engaged thus turns the image upside down. iF IT IS PERMANENTLY UPSIDE DOWN yhen most probably the switch has worn out.and its not resetting.
You could try a few gentle taps to see if it releases the micro switch
Please rate my help++++Thanks for using FIXYA
Nov 20, 2009 | JVC Everio GZ-MG130 Camcorder
Upside down image
These projectors are designed to be mounted upside down. Think of a projector that is ceiling mounted in a classroom. Change this setting in Menu - Advanced Menu - Setup - Mirror.
Jun 09, 2009 | Hitachi CP-X445 LCD Projector
Everything is flipped
in the video settings you will see an option that will flip it back to normal
good luck
Terry
Apr 01, 2008 | Dell E176FP 17" LCD Monitor
Sony handycam dcr-sr40 lcd display
flip switch is not working or stucked, a loose wire connected to this switch is also possible. you may open the unit and check for it. a pro fix is better.
Nov 06, 2007 | Sony Handycam DCR-SR40 Camcorder
Image won't flip when the lcd panel is fliped to 180 degree i.e when i flip the lcd panel towards the lense to do a self shoot the image, instead of appearing stright appears upside - down
normally there is a micro switch fixed at the awivl head of the lcd panel. when the lcd is rotated to 180 the switch gets engaged thus turns the image upside down. most probably the switch has worn out.
Aug 16, 2006 | JVC GR-DVL120 Mini DV Camcorder
Motorola Mobility i880 Cellular Phone Logo
281 people viewed this question
Top Motorola Mobility Cell Phones Experts
D. E. Hev
Richard Lane
Vernon Taylor
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
